Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Happy birthday, Mark.
Bob
Current build:  SS_ Mariefred
Link to comment
Share on other sites
I think we had this conversation last year about us being a day apart, only don't remember the year - mine was '49
Hope you had as good of one as I had...
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Link to comment
Mark: there is a fairing issue at the stern here (perhaps I'm coming in on this conversation a little late). The curve should be nicely radiused, without any sudden turn. I've attached two examples here: one is a full-bodied ship, the other lean and mean.
Hope this is of some help.
Link to comment
Thanks for the wishes, my friends.
Druxey, there is indeed a fairing issue.  I've studying this and it looks like the low transom piece is the culprit.  Giampiero pointed this out also.  I've been scratching my head, double checking the plans.  The only way to fix this is to rip off the last three (maybe four) strakes at that stern and re-fair.    I was hoping to avoid that, but...  what needs to be done, needs to be done.
Link to comment
Hi Mark,
I've been following quietly along for a while and trying to catch up on all the history of your build.
Seems like today is the ideal day to say that your Licorne looks absolutely fabulous and that I especially admire your determination to do whatever it takes.  :)
Happy Birthday!
:cheers:
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Link to comment
Happy Birthday Mark....... Hope it was a good one!.......... you'll be a lot happier redoing those strakes :)
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
To quote Shakespeare's King Henry V: "Once more unto the breach, dear friends,"
Or maybe Daniel (Dafi):   "Mass Destruction!!!! hihihihi!!!!"
Bottom photo is the mod to be made... I need to arc more.   Planks are stripped, power sander and sanding sticks at the ready...
Link to comment
Ugh! I prescribe an ice cold adult beverage of choice, a comfortable chair and birthday cake while enjoying a fireworks display.
Each revision brings a better result, kindly sir. Your work is amazing!
Back to quiet lurking, I remain,
Your ob't servant,
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Link to comment
Sorry you had to undo and redo Mark, but it's your B-Day and I'm with Wayne on this one. Pull up a frosty and an easy-chair and enjoy the day.
GEORGE
Link to comment
A somewhat late birthday wish, Mark. And I hope the work you do now will preclude a Version 3.
Slainte, birthday boy!
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks for the birthday wishes.
I'm going to avoid Version 3.0 at all costs.  I'm comfortable with ripping things apart and putting them back together.
As a footnote, I'll probably open a sub-log like Danny did for the ship's boats but not until the first one is nearly done.  I want to try to use Chuck's method but at 1:64.  There's three boats, the longboat, the cutter, and the barge.  Keel's are 1/16" thick cherry, frames are 1/32" cherry, and the planking is 1/32" holly.  I hope I can pull those off.   It'll be a bit as I'm making the drawings (as well as for what I need for the main build) and testing on the laser cutter.
Link to comment
I agree with Wayne and George - pull up a frosty one and celebrate your birthday - you're still three hours behind us here in the east lots of time left to celebrate
Link to comment
Lessons learned at this point on framing, fairing, and planking....
I guess I should say that it's not that I lacked the courage but more of the knowledge of deciphering the plans, supplementing them with the correct information and translating it all in my head to a course of action.  And then I got side-tracked...  anyway, after working through the side-track for the last 30 days, I'm re-focused and back on course.  Solution.. try not to get side-tracked by new toys... think further ahead.. instead of 10 steps or 20 steps... look 100 steps.
The problem stems from not fairing the aft frames as far as the Hahn frame drawing show and the lack of knowledge on my part in setting up the transom timbers.   I guess I should have done a better documented ship first....
Same goes for the garboard strake.. I wasn't thinking that far ahead when I did the rabbet.  I've been working through the problem and have a better result which should show when I put that strake in.  Seems I didn't get the bevel quite where it should be in the aft section.
Next update will be after I get everything re-faired and sorted out and the now four strakes of wide planks replaced...  If you hear foul language from the west coast, ignore it.. it's just me sorting out things and venting to myself.    But it will be fun.
Link to comment
Sounds like you've got the thought process in place.  Your honest narrative gives all of us a reminder of how what we do today can impact a year down the road.  Your strength is that you forge ahead with the required modifications rather than simply 'make do'.
Fine work, mate.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Mark: if you have been working from Hahn's drawings, the problem lies with his drafting, not your construction accuracy. I've noticed this issue with other Hahn models and ones built from his plans. Cold comfort for you, but....
Link to comment
It's indeed cold comfort, Druxey.   I should have paid more attention when I was planning this build but I plead ignorance.   I've stumbled upon several issues already and this is just one more.  But... it's wood, it can be fixed.  Time to go make some more sawdust..... and a template or two for symmetry.
Link to comment
Being the conservative builder that I am especially when it comes to major changes, I've done some serious reshaping of the transoms.  I think I'm close but I'd like some other opinions.  I've blue taped down some thin battens.  If it looks good, I'll start bending the real wood and planking.  The ends of the existing planking are not a problem.  I have some fashtion pieces that cover the counter timber ends and the hull planking timber ends.
Link to comment
Much, much improved, certainly, Mark. Perhaps even a tad more, if there is enough wood remaining to do so. You'll be glad you did this, and you'll find reinstalling the planking will be much easier.
Link to comment
Thanks Druxey.   Will do some more.  Getting a bit thin but I pack from the other side if need be.   And it's looking a whole lot better in the testing.
Link to comment
On the road again ... Mark, you said it yourself, since it's still reachable, you can add some thickness when you are taking off more than you like ... still looking solid
Edited by cog
Carl
Link to comment
It's all doable and it's all good... ;)    And to be very blunt, if it weren't for MSW, I would never, ever tried scratchbuilding.  The help and encouragement is priceless. So a big thank you to everyone.
Link to comment
Hi Mark -
Yes, much much improved.  You can't go far wrong if you follow Druxey's suggestions.  Your progress up the learning curve is well underway and you are going to be very happy that you took the step back before you took the next step forward.
And a belated Happy Birthday.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
