Nigel,
There you go again "raising the bar" sweeeet work!! A pleasure for the visual senses.
Cheers mate
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thank you very much indeed B.E.,Michael and Nick :)
sadly B.E.,we currently live in a most unpicturesque part of Yorkshire,I hope to be within 'spitting' distance of the 'white horse' if we ever get moved,so that should change ;)
I think one of my biggest influences in the choice of woodtones Nick,is Dr Mike's Rivoli,I am simply in awe of this model and his use of colour
Kind Regards
Nigel
Currently working on Royal Caroline
Nigel,
Oh My!! I so had to find this ship model. With all due respect here is a link. Yes beyond Stunning.
http://shipmodels.com.ua/eng/models/elite/le_rivoli/index.htm
PS: I will, off course remove this post if I've over stepped on your log (:-)Though I'm sure that there would be an interest. (I could not locate his build here at MSW)
Michael
Michael
Under the table:
Completed:
Vasa-Corel -
No problem at all Michael,I nearly posted a link myself :D I thought a pic would show instantly what I meant.If you like the pics,you will love this
http://forum.modelsworld.ru/topic8019.html
And yes,he built two!!!more economically viable as he does this for a living :o
Kind Regards
Nigel
Edited by NMBROOK
The stern chaser ports have now been lined with Ebony and I have also lined the hole for the tiller arm.The linings on this hole need to be flush with the stern counter,so I figured it easier to assemble a simple Ebony box.This will be trimmed and sanded flush with the counter after being left for a couple of days to ensure the glue is fully hard.Apologies for the pics,not easy to pick the details out when everything is black :huh:
Kind Regards
Nigel
Hi Nigel,
Lovely work as usual and I like the recessing on the liners of the chaser ports. The relief shows up nicely even allowing for the black colors. Will you leaving these ports open in the finished model so this nice detail is visible?
Also, what is the wood under the ebony...swiss pear? The light reddish color makes for a very nice contrast against the ebony. Sorry if I missed this info in an earlier post.
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Thank you very much Nigel :) Yes the ports will be modelled open.The brown timber is indeed swiss pear and part of the counter framing.This will be covered by a boxwood moulding and the lower hull planking.
Kind Regards
Nigel
I have finally fitted the remaining glazing bars in the lower stern windows(yes another five to go above these and numerous ones on the deck bulkheads :rolleyes: )
The three on the right are complete,the two on the left have had the bars sanded flat and awaiting another coat of matt poly.
I have now moved on to fitting the balcony floor.Three copper pins were bonded into the edge of the floor and correspond to holes drilled in the transom.The softwood former underneath is temporary,it is purely there to hold the correct camber as I had a small amount of springback when the floor was released from it's jig.The floor has been epoxied to the transom and lower edge of the planking.The protuding sides will be trimmed and sanded flush when the epoxy has cured.This will also release the softwood former which is held with blobs of epoxy at each end.
I am looking forward to the next stage,I had a lightbulb moment this week.I have worked out how to produce decorative paneling in boxwood with an ebony architrave detail.It is based on DrMike's technique for creating these panels,but with my own twist.All will be revealed in due course ;)
Kind Regards
Nigel
I'm a big fan of the black timber,... it looks really classy!  This project is well on its way to being something special.......
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Thank you JP :) Yes I am big fan of Ebony,it is a pig to work with,but you can produce effects that would be an absolute nightmare to achieve using dyes or paint.
Kind Regards
Nigel
I have successfully completed the two pocket doors that will go either side of the stern balcony.The lightbulb idea worked :) I have taken MANY pics of the actually quite simple process.To make it easier,it will be in several posts.
Part one :P
After making a template for the angle(all the panel detail on the stern comprises of parallelograms :rolleyes: ) I cut two doors and the top and bottom angle was set on the proxxon disc sander.The blank comprises of 3mm ebony laminated with 0.6mm boxwood veneer.The parts for a fixture for the miller was cut from scrap MDF and boxwwod strip.The MDF was perfectly square and parallel(this is important later on ;) )The guide for the proxxon sander was kept set as this will be used later.Note the only reason the ebony is so thick is that the back will be shaped to mate with the inside of the hull planking.
TBC
Kind Regards
Nigel
Part two
Standing the mdf on edge and using some scrap strip as a spacer,the first boxwood stop was glued to the MDF(this ensures it is parallel to the edge).The rest of the fixture was then assembled,the pics are self explanatory,but note the doors are only glued with tiny spots of epoxy at the corners,the boxwood is thoroughly glued to the MDF.
Next the fixture is set on the mill table,the sander guide is used to set the angle so that the grooves running across the doors can be milled.
Kind Regards
Nigel
And finally part three
Using a dremel ball end cutter 1.2mm diameter the grooves were machined between the lines previously marked in several light passes,the total depth being 1.5mm.The fixture was then moved parallel to the table to mill the vertical grooves in the doors.
After a light sand the corners were 'squared' using the tip of a scalpel blade and job done.
Now to make the ebony panels these sit into so they can be fitted on the model
Kind Regards
Nigel
Good work Nigel,
"Mordaunt" is coming on very nicely..
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful doors and an excellent technique.
Great work, never would have thought of using the square from table saw to do that.
  Excellent !
Thank you very indeed Jeff,Grant,Janos and Don :)
The bevel guide was actually off the Proxxon disc sander Don.The idea being,that the angle set was used to sand the ends of the doors to the correct angle and had been checked on the model.The table saw has a similar one(the guide is actually fatter on the saw one),but cutting the ends on the table saw would have risked material breakout on the trailing edge.
Kind Regards
Nigel
