Mike,
If you continue like this, you might end up with a better model than he one in the Hamburg maritime museum ...
Carl
You hadn't one ... :huh:        ;)
Carl
Hi Mike,
     The progress may be slow but what you do is quality workmanship.  At least you can find a few hours a week to work on Oliver Cromwell.  I'm so damn busy I can't even do that.  Fall is just around the bend and model building, at least for me, picks up.  Hopefully you too will find more time to work on your model.
Tom
Thanks for the nice words and likes! That really helps to find more modelling time :)
Finally got the micro-drill working, so now the clamp installation goes faster.
After marking the treenail locations with the pencil, they are accentuated with the scriber (I know, bad use for the scriber):
That is required to avoid the drill wobble, it is not very balanced (chinese crap):
And then install the boxwood treenails - these ones are not just for looks, they are injected at least few millimiters into the frames and glued, hope that will make a strong bond between frames and deck clamps, to avoid the hull cracking and twisting during the dry winter months.
Edited by Mike Y
I'm playing catch up, Mike.  She's looking fantastic.
It may be Chinese crap, Mike, but you still have a very good result in spite of that so called crappy thing ...
Carl
Carl, yes, even this "drill" is better than manual drilling. It is just a pity that there is nothing in the market for a proper quality micro drills. All drills I found while googling were similar hand-made "cheap motor + chuck + few wires" construction. I love working with good tools, this one is not pleasure to work with, but it gets the job done.
Many thanks to Gaetan, now my livingroom corner looks even more like a shipyard, with the Arsenal de Toulon drawing on a wall ;)
Just realised that I screwed up the transom a bit.
For some reason I thought that inner planking and deck clamps in that area fully cover the transom wings. Also, I was expecting some sort of stemson, but at the stern. I thought that inner planking will terminate there.
Well, I was wrong. TFFM and other build logs indicate that transom wings are just left open, and inner planking terminates on the rear-most cant frame.
Like here, on Remco's Kingfisher:
Or on Albert's Naiad:
And here is what I have. Nevermind the glue spots on the clamps, they are not sanded or scraped yet, but you can see that they expect to terminate on some big timber in the middle of the transom (which, apparenly, does not exist), and the wings are ugly on the right side, because I was going to hide them under planking. Whoops! :)
Will try to reduce the impact of the screw-up by shaping the transom wings carefully, so they will look nicer. Shaping them in such confined space is a challenge, but seems like I have no choice.
Luckily, that area would be barely visible under multiple layers of deck framing, but it is not an excuse to leave it in such a bad shape! :)
Edited by Mike Y
Human error follows us where ever we go Mike ... it sticks like glue, and we see it in our endeavours ... at least you get the opportunity to correct it
You know the adagium:
Assumption is the mother of all f... ups
Well I've had my share in programming ... and in modelling too
Carl
Ah, so you can relate to it, well then ... watch out my friend, for you'll be frequented by it when you least expect it ...
Carl
One more timely lesson learnt.
Thank you Mike.
Now I just have to remember!
(That is the hard part)
Alan O'Neill
Shaping the clamp ends in situ was a bit tricky..
Transom wings were shaped with sandpaper and scrapers and finished with xacto blade:
Result:
It is still clear that transom wings are made out of two pieces, and the gap between the pieces is still visible, but it is kind of better than it was. Sigh... Will do better transom on the next model!
Luckily it looks good from the outside, and the inner part of the transom would be barely visible under three layers of deck framing ;)
Thanks John!
Finishing the planks with some sandpaper, mini scrapers and xacto blades. The mini scrapers were surprisingly useful!
Covered the frames with the masking tape to avoid scratching them accidentally:
Final result, with tung oil applied.
The exposed side of the hull would be left as is (with deck framing, of course), things like breasthook, fore and mizen mast steps, etc - would be cut in half with one side omitted. That is to avoid obstructing the view through the hull.
If something will need to be glued to the finished side - will use treenails and/or monofilament. Or epoxy.
But hope it will not happen :)
They are not perfectly symmetrical where the bending is significant (+/- 1mm, not more), but this would not be visible if I manage to make nice and even deck framing, perfectly aligned in all projections (because the deck beams are higher than deck clamps, recessed by roughly 1 inch). How hard could it be, right? :)
HI Mike,
I love this build and your workmanship is absolutely first rate!!
Can I ask where you found those small scrapers from a few posts back. I've been looking for some and have not had any luck. Thanks.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Hi John,
Thanks!
The scrapers are amazing, I am using them very often now. They are removing much more material than xacto blades, and they can get into any small places because of the small size. The edge do not have any dents.
Bought them here: http://www.axminster.co.uk/lynx-mini-cabinet-scraper-set-504698
I also discovered them on MSW in somebody's build log, but forgot who that was...
Quick googling shows that you can buy them in US, for example, here:
http://www.woodcraft.com/product/158977/lynx-mini-scraper-set-4pc.aspx
http://www.grizzly.com/products/Lynx-Mini-Scraper-Set/T26658?utm_campaign=zPage
http://www.japanwoodworker.com/Product/158977/Lynx-Mini-Scraper-Set-4pc.aspx
etc etc
Some "build snapshot" photos. Tung oil finish is especially beautiful under direct sunlight. It is such a pity that it is a not a good idea to display the model in the sunny place :( Damn physics!
Bill, I do not think this term is clearly defined, but it is typically equally spaced frames with no shifts.
Also, he popularised the jig that helps to build the hull upside-down, as you see in the beginning of the log.
Bill,
"Hahn style" involves a lot and the modeler can go with as much or as little as they wish.  As Mike pointed out, there's stylized framing, the jig for working upside down (and also right side for the interior).  There's also minimal if any carlings used during decking process.  No knees, etc.  Simplified keel, stem, and stern deadwood.  I'm thinking there's a bit more but I'm in the middle of a "senior moment" on those points.
Mark has described the style well. Hahn also used ebony (yech!) for his false keel and wales. This is not the best specie of wood for the job for a variety of reasons (discussed elsewhere), but avoids painting or staining.
