Beautiful work on the triple block.  The lettered cover plate is a brilliant touch.
Dan
Every part of this boat is so well done it would be nice to have that “I shrunk the kids” machine to become small enough to sail her yourself.
As for sail winch I saw a 5 foot boat, with big sails, where the owner used a reversing screwdriver/drill with a torque control for the winch.  I'm sure you'll work something out.
Bob
Current build:  SS_ Mariefred
Fantastic work. It's been said here before but worth repeating - Reading through your log is like reading a 'Wooden Boat' issue.
Oh Wait! This is a real boat and you're just telling us it's a model.
Kenneth
Ye gads! Lovely detail, Michael. Just as well she's not a three masted square rigger. You'd be building blocks forever!
Thank you all for your kind remarks and for all those who pushed the like button.
I did a little work today on the bracket to hold the main-sheet tackle to the deck.
First some sketches after looking at a few on the web.
the block of brass was 2 inches by 1/2 inch by 7/8th inch. using a 5/16 ball end I roughed out the main block.
Then with files after the rest of the machining got the block to the final shape.
A little more work with finer files and some wet and dry sandpaper then a buff in the dremmel
A pin machined down from some 3/16th with a 2x56 thread for the cap end.
Next the central unit that will be sandwiched between some rubber buffers each side, that the shackle and lower block attach to.
Michael
Michael........the Metal Maniac......hmmmmm,  has a nice ring to it  :)   sweet stuff!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I had posted this last night but....
Again thanks for all the positive comments and for the likes.
Yesterday I finished up the deck part of the main sheet tackle. first I used some rubber like insulation from some heavy wire.
I slipped about 3/4 of an inch onto some 1/8th inch diameter brass rod and parted it off into some 1/4 inch long sections.
then made the small sliding part after grinding up a form milling cutter. after fitting it up I spent the rest of the day making the two single blocks and fitting them to the deck.
I swung out the boom to finish threading the rope plus I wanted to see how much rope I would need it turned out to be almost 18 feet, with about 1 foot laying on each side of the cockpit as part of that distance.
All I need to do to finish the main sheet control now is to add either a couple of cleats to the deck or to set in some bits and also to fit a proper bit of hardware to the boom.
I have also been looking at the whole way the rudder assembly is fitted and the way it penetrates the deck. The tiller attachment area is a bit small and I don't like the fact that it is fixed.
Michael
Yes, the sheet takes a lot of rope and multiplies every time it passes through the blocks.
I can almost imagine myself walking that deck and getting ready to sail.
Bob
Michael
I so much enjoy reading of your latest R&D. I take so much useful knowledge from seeing your creative abilities at work.
Thanks for sharing, seeing the parts made as real working models helps to understand the physics of the rig and how it works. From a person the was completely ignorant of anything about ship/boat rigging when 2013 started, I have come a very long way in my understanding. I can only get so much understanding from reading, your build log has given me not just the visual finished product, but the processes of how its made, why its made that way and how it is ultimately used.
A perfect example would be the picture of the block assembly. The one picture where you show the line clearance... I always just thought the opening to have equal distances between the block and sheave, but I now see that the opening is only opened for the line and close on the opposite side. The light bulb went off as to how much stronger this would make a block assembly. The realization of this asymmetry in the horizontal plane of the block assemble was just an example of why I find your build log SO OUTSTANDING.
Please know that your mentorship to so many of us is greatly appreciated. I stopped rigging my pilot boat build as I wish to modify the kit inaccuracies and am watch your masterful work as an online apprenticeship of sorts.
I really like the personalized block brass piece. Such an amazing touch. Every time I leave your log I think, ok what else can Michael do that will be more amazing and without fail I always come back to see a job that just keeps becoming more engrossing. Your build log is like a great novel that comes in installments and one can't wait to see what happens next.
Be well my friend.
Would love to spend time in your shop learning the underlying techniques and skills you bring to your work!!
Cheers,
pop by anytime Jay the tea kettle is always on.
One of my own little fantasies Bob.
It doesn't seem to matter whether you are working with wood or metal
Sherry I love working with both materials, the beauty of boat models is the variety of materials that one gets to work with.
Keith thank you for you very nice commentary about my build log. One of the most important things for me is to understand the how and why of what I am making and if my account of what I am making is helpful then the sharing is worth the time it takes. I feel so much more informed from all the amazing builds on this forum that my own knowledge expands every day I log in.
John Thanks for your kind words
they look full scale; until I see your hand in the photo
Ah mark its all smoke and mirrors. Thanks for the compliment.
Today was a fun day I finally finished the main sheet attachment to the boom.
First I did a forging test with some 1/4 inch brass stock I necked down about 3/4 of an inch to about 1/8th leaving a 1/4 inch long full diameter at the end. this was annealed and forged on the railroad anvil four times to flatten out the end.
After seeing that the forging would work for what I needed, a length of 1/4 inch rod was cut to 2 1/2 inch length with the centre necked down to the 1/8th diameter.  both end were then forged to the same shape as the test piece on the railroad track anvil.
after bending the curve into the smaller diameter (if I were to make another I would make it about 1/4 inch shorter) the unit was set up in the vice for drilling. A block of maple the same width as the boom was sandwiched between the ends to support the brass flange while the holes were drilled and then counter-bored to create flats in the slightly tapering flattened flange. The centre hole is 1/8th to allow a brass Chicago screw to replace the pin holding the clew out-haul sheave.
next the hole was reamed to ensure they were aligned.
after clean up.
removing the temporary pin.
fixing the new tackle
Done
Michael
Just fantastic work, Michael.
so cool Michael.......... in so many ways,  a life-like replica!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Again thank you all for the kind comments and for all the likes.
Forging--beyond my comprehension how you do it, and do it so well.
To answer you question, The original test piece was annealed at the other end.
then a small hammer was used to flatten the end
after about 6 or 7 blows the brass has become work hardened
After a second annealing and another 6 or 7 hammer blows the step was repeated because again the brass becomes work hardened
a third time for the annealing and another 10 or so blows, as the metal flattens a larger area needs to be hammered so it takes more blows, the weight or force of each blow remains pretty constant from the beginning to this this point, one gets into a rhythm just like any other repetitive task.
A fourth time was repeated as before, to get the new end similar to the first. on this test piece (I did not accurately measure both full diameter lengths at each end because they were done at different times, on the piece that is attached to the boom the ends were both turned before the flattening to ensure the same volume of material would squash out.)
After a clean up with the wire wheel the centre portion is annealed to soften it to be bent around a piece of rod.
The rod diameter need to be close to the final shape because there is very little spring to the brass after it is annealed, as it is bent it begins to work harden again which is good because the final shape needs to be hardened enough to retain its shape. the aluminum scrap here is 1 inch in diameter
next a smaller diameter piece of wood was used, it was a conveniently smaller diameter, to close in the ends a little tighter than the main curve
then the piece was squeezed onto the block of maple that I used for the final one that is on the boom this was so that the drilling could be done without the piece deforming any more.
The drilling was explained in the last entry in the build log.
I hope this helps to see how easy some of these tasks are when you break them down into their small steps.
1 Turn to diameter
2 heat to soften (annealing brass, heat to red then quench in cold water)
3 shape with hammer
4 reheat , as many times as needed to gain the desired amount of flattening
5 shape to final form
6 machine holes and finish shaping with files.
7 polish with emery and steel wool.
Michael
I and I assume many others appreciate your posting with images on this form. It's kind of being there in your shop and working alongside you.
Mike, thanks once again.
S.os
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Beautiful metal work Micheal,
I can imagine the fun you have in creating those lovely Fittings
Well done !
Nils
Current builds
-Lightship Elbe 1
Completed
