Posts posted by Stuntflyer
Joe,
I use a Nikon D5100 on a tripod. I chose this camera for its low price yet it has a really good 16 mega-pixel sensor.
I only use prime lenses. Zoom lenses are okay, just not as sharp.
Closeup I use the Nikon AF-S Micro NIKKOR 60mm f/2.8G ED Lens.
Further away I use the Nikon AF-S DX NIKKOR 35mm f/1.8G Lens
Mike
- KenW, Hubac's Historian, rafine and 22 others
25
Thank You, Maury and for all the "Likes"!
The quarter gallery framing and aft-most gun port turned out to be my week's project. The 5/64" X 1/4" strip along the top of the quarter deck bulkheads was made from basswood. I sanded the bulkhead tops to the correct angles for a smooth flow of the strip. Getting the symmetry from one side to the other took patience and repeated eyeballing. The framing of the quarter gallery required a bit of experimentation. There are a number of angles on each strip and no two strips are the same, except for the two gallery entrance strips. Rather than waste precious boxwood, I used basswood strips to find the correct angles. As an example, one strip had angles of 70° and 10° on one side, 6.5° and 5° on the other. A disc sander with multiple adjustments comes in handy. After completing the horizontal strips I made the two aft-most gun ports. Lastly, the quarter gallery entrance strips were added. The plan detail proved to be very useful for getting exact measurements.
All strips were inserted standing proud, allowing for shaping to the hull shape when fairing. I faired the work leaving a wee bit more for later on when I start work on the lower hull. I'm always trying to stay one step back until I'm sure of where I'm going.
Mike
- paulsutcliffe, KenW, Erik W and 33 others
36
The shop has been a busy place lately. In preparation for the quarter deck clamp/stringer in the waist and Forecastle deck clamp install, it was necessary to remove the small temporary filler pieces between each frame. My method is to wrap the fillers (3-4 at a time) with a moist paper towel and apply a hot clothes iron to the surface of the paper towel. The steam penetrates and loosens the joint. Needle nose pliers can then be used to remove each piece. Final sanding of the exterior hull will be completed later.
Using this height gauge, vertical measurements were taken from the shear plan at various locations and transferred to the interior hull. The thin boxwood strip was glued to the gauge with CA and pushed through between the frames, so tic marks could be added.
The quarter deck clamp which becomes the stringer in the waist is installed above the upper deck clamp.
Mike
- hexnut, Bluto 1790, Nirvana and 29 others
32
Building continues with the stern framing. I was lucky enough to get the frames laser cut for me. I used a simple cardboard template to install them at the same angle as shown on the plans. Next, the five sills were added. I made these from 5/32" x 5/16" strip. These angles were tricky to get right and there were a few throwaways. The sills were set flat, not pointing upwards. The final step was to add the four laser cut lintel filler pieces. In a few places, I found them to be a tiny bit too short between the frames, so I cut new ones from 1/4" sheet boxwood. The interior and exterior surfaces were then faired. I was told that these surfaces will eventually be thinned down even more.
In preparation for the bollard timbers the area behind the stem was reduced to a thickness of 1/8".
Mike
- billocrates, Bob Legge, Beckmann and 30 others
33
Shawn,
I started out using graphite paper as a transfer method. By the time I started work on the frames, I switched over to Elmer's School Glue and plan drawings which were made from a printed copy. There are times when graphite paper comes in handy, like when I transfer a scarph joint shape. So, both work, just depends on the application.
Mike
All of the work since my last post was done on the build board where the bulkhead former was held securely by the longitudinal channel and the three vertical supports.
After adding the bulkheads, the hull was faired down to the half breadth in preparation for the gun port framing. I used a 36" x 1/16" x 1/4" x balsa strip as a batten to establish a smooth run for the framing. After completing one side, vertical measurements where taken at each bulkhead and transferred to the other side.
The gun port framing and fixed block supports were added. This time, I drilled smaller 1/32" holes through the supports.
Bulkheads had to be cut for proper gun port location at the bow.
One of the two lower deck platforms installed.
Mike
The ones I purchased open to 60mm and are 100mm long.
Mike
- ChadB, druxey, aviaamator and 2 others
5
I just finished the port side platform clamp. The clamp was held in place with Wolfcraft clamps which can go deep into the hull. After gluing the aft end of the clamp, another balsa template was used to set the position of the forward end of the clamp.
You'll notice that I have been fairing the exterior hull. For the most part it is done. Just need to do a bit more work at the stern. Also, I left a 1/2" or so of extra thickness at the top timbers. After the Forecastle deck clamp and stringer in the waist are attached I will final sand the top timbers to an even thickness along the hull.
Mike
I thought it might be a good time to do some catching up. Hard to believe it's been 4 months since my last post.
In preparation for adding the lower platform clamps, I installed a beam recessed to fit around the inner post. I will use this to align one edge of the aft platform clamp
Only one side of the hull will be planked. The other side (open side) will only need two short clamps that represent the length of each platform both fore and aft. Measuring from the draught onto a balsa template made it easy to locate the lower platform position.
Here is the aft platform clamp installed after using the same method. Clamping was tricky.
I have actually made more progress than what is shown here. However, the lower platform clamp stills needs to be added on the planked side of the hull. I'm waiting for some deep reach clamps to arrive before I install it. This and more to come soon!
Mike
- Ryland Craze, Jack12477, Erik W and 36 others
39
Nope, the effort to correct the twist only led to more frustration. The new BF is a lot stiffer and stronger than the original. My plan is to keep it vertical during the gun port framing and planking above the wales. I will keep a watchful eye on it as I move ahead.
Mike
- FrankWouts, mtaylor, Mirabell61 and 7 others
10
The bulkhead former will be held vertical while adding the bulkheads. Chuck designed these laser cut supports and longitudinal pieces from 1/4" stock. Laser char was removed from any area that will come in contact with the keel or lower stem. The slotted holes allow for some in and out movement. The bolts are M1.6 x 22 and the nuts are recessed into the bottom of the build board. They are secured with thin CA. Blue painters tape was used to make up any thickness variation between the keel and bulkhead former. Although the BF is held securely, it can be removed without loosening the supports.
Mike
- Jorge Diaz O, KenW, JpR62 and 14 others
17
We had a great time at the Northeast Joint Clubs Conference last weekend. Lots of beautiful models on display. My girlfriend, Ofelia, did most of the picture taking. I Finally got to meet a number of MSW members while I was there which was really nice.
Now that I'm back in build mode, I managed to taper the knee of the head and complete the gammoning knee and extension piece that sit above it. Templates were made from the plan drawings and transferred to 3/16" boxwood sheet.
Mike
- Erik W, Tigersteve, mtaylor and 19 others
22
The three section bulkhead former is joined and the bearding line completed. The rabbet strip, knee assembly, keel sections and false keel sections have been added.
24 gauge copper wire was used for nailing the joints. Holes were drilled with a #76 drill bit (.020). This allows the wire to be inserted with a slight press fit into the holes. No gluing necessary.
All of the keel joints were filed flush where the garboard plank will be. To do this I used an equaling file that is only 1/32" thick. http://www.ottofrei.com/Glardon-Vallorbe-Equalling-Special-Thickness-Precision-Files-LP1185?custcol19=14
I placed a plank along the upper edge of the keel to show the result.
Mike
Thanks, Chuck! Looks like I will have to order more wood to manage the larger scale.
Mark, I too look forward to seeing what advantages the larger scale brings. Right now everything looks huge.
I wasn't going to, but I finally decided do the box joint at the lower stem. Guess I was nervous about messing up what was already done. I spent most of the day on it and I'm really glad that it's done.
Mike
- Dubz, capnharv2, FrankWouts and 16 others
19
Once I got started, it wasn't long before I realized that I couldn't untwist the hull without removing all the filler blocks and gun port framing. In hindsight I should have supported the stem and sternpost while doing the initial work. This is something I had done before, but for some reason didn't remember or see the need to do it here. Go figure! Anyway, after talking with Chuck, we decided to go up in scale. In the end I think it will show more detail and will look better at 1/4" scale.
Mike
- druxey, Ryland Craze, KenW and 10 others
13
Thank you, Nils!
All of the gun ports are now faired. I've started work on the stern framing. Again, I won't be using the laser cut kit parts. These six frames were cut from boxwood sheet. The slotted bulkheads allow for accurate placement of each frame, though it was necessary to make very slight adjustments to insure that the aft edges remained parallel to each other. Looking ahead, I can see that it would be easy to shift the frames out of position while adding the lower sills, lintels and Quarter Gallery Framing. I will keep a close eye on this. So far, things look good.
Mike
Thank you very much, Hubac'sHistorian and for all the "Likes".
Moving ahead, I added the fixed block supports to the hull. Hard to believe that these would take several hours to make. Holes were drilled with a #70 drill. Once the blocks were in place I was ready to do a second fairing of the hull. One gun port upright loosened early on, so I decided to add basswood filler pieces between the gun ports and bulkhead extensions in order to strengthen the uprights. This will all be hidden later on.
So far I have one side of the hull pretty much done.
Mike
Thank you for the kind words, Ken!
I have been hard at work finishing up the gun port framing. Lots of different angles along with the usual throwaways. In some areas, like the last few stern ports, compound angles had to be used in order to get a good fit. Having a disc sander with angle adjustments made the work much easier.
The few of the forward ports are set at different angles from the others. These angles where taken from an overhead view on one of the plan sheets. A balsa block was made on the disc sander to match the angle and width needed. It was glued in prior to adding the upright.
On the same port the bulkhead extension was cut away to allow for the proper placement of the aft upright.
Mike
- Seventynet, KORTES, Canute and 25 others
29
HMS Winchelsea 1764 by Stuntflyer (Mike) - FINISHED - 1/4" scale
in Member Build logs for the HMS Winchelsea
I've been working on a few things over the past week.
The quarter gallery framing and surrounding area was faired some more. The tops of the two outer stern frames were reduced in thickness from 1/4" to 5/32" in order to match the thickness of the inner frames. The entire area was then faired to establish a smooth batten run down the hull. You can see how much material has been removed compared to the photo above from an earlier post.
Next, the entire hull was faired with the exception of the two filler pieces under the lower counter. I started on them, but remain unsure about the transition from one to the other. Hopefully, this will become less confusing after I talk to Chuck this week.
I did manage to add the fixed blocks. 1/32" Slots were milled for each of these. I did not mill the slots on a strip of wood that was the exact width required. Rather, I used a much wider strip. The advantage being that it was not necessary to mill the slot to the exact angle and position on the strip. Paper templates were cut from the plan drawing and the slots carefully removed with a #11 blade. They were then aligned over the milled slots and adhered with Elmer's School Glue. With the template as a guide, the outer edges of each block was sanded down on the disc sander to the proper width all around. The sheaves were made from slivers of wood cut from discs of the same thickness as the slot. Each sheave is thinner than the actual block, so they can recess slightly into the block. A #2 pencil was used to darken the sheave slot and the actual sheave.
Mike
