What a beautiful boat, Johann.  A work of art by itself.
Happy new year to you.
Edited by mtaylor
Hello,
many thanks to all for your positive comments and the likes.
It pleases me again about your feedback.
With the New Year I have started the construction of the two cutters (petits canots) of the French Corvette.
Here are the first impressions:
Edited by archjofo
Hi Remco,
thanks for your nice comments.
Here I want to show you the basics for the construction of the two boats.
Compared to the original model of the boats from the Musée national de la Marine there are
various deviations from the plan of J. Boudriot and drawings from the Atlas du Genie Maritime.
As a result of my review of these documents, I choose therefore the construction of the cutter is substantially based on the drawings from the Atlas du Génie Maritime and J. Boudriot.
That's the theory; soon it then continues with images of the model practice ...
Edited by archjofo
Ganz toll Johann!!! You'll be boot builder #1 from MSW. Soon you'll be able to make them with your eyes closed ;)
Looking good (again)
Cheers
Carl
Hello,
thank you for the nice compliment and the Likes!
And here it goes merciless continue by boat building ... :D
The framework for the first cutters for the French corvette is ready so far to planking.
The second bulkhead framework is already in progress.
Your boats will become better and better, it's absolut amazing
Regards Christian
Exquisite work Johann.
Michael
I keep revisiting this log and wonder how is this all possible,... and yet,. all the step by step photos are right there, and even all close up!!!!   ...leaves me in awe...........
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Hello,
thank you very much for your interest and kind words, that´s a great honour for me and appreciate your comments a lot. I am pleased, I can share my hobby with you all.
I also find here plenty of great inspiration watching your wonderful models and inspirative technologies.
Thank you for this pleasure.
Here's an update of my building report:
After completion of the frameworks it goes with the planking on.
The plank width is 2.5 mm. 10 planks must be installed per boat side.
Edited by archjofo
Not easy to use full length planks on hulls like this, they twist and turn making them everything but a straight plank in any direction. My hat is off to you Sir, I took a short cut and broke my planking on my boot hulls in sections.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
beautiful work Johann,
its a pleasure to watch these boats being built relating to technique and accuracy
Nils
Current builds
-Lightship Elbe 1
Completed
You have a nice collection at present, any further small build plans. They do look marvelous ... and it seems so easy when you do it!!!
Carl
Hello,
about the positive reactions and comments, I am pleased and thank you for it.
On the following pictures can be seen the incorporation of Rowlocks.
The next detail is prepare.
The gratings in the bow and stern of the boats are very delicate.
Those are delicate...  :o   The dimension is the size of the wood used in the grate, correct?
Very nice gratings Johann!
I still have to test this method.
Just to be sure for my correct understanding: you start firstly cutting in cross-grain direction with the deeper cuts, then cut along-grain with the shallow cuts, then fill the along-grain cuts with battens as wide as the shallow cut depth, then sand the opposite side until the grating emerges? Is this the correct sequence?
And the saw blade thickness must be the same as the battens thickness and the cuts spacing (=steps)?
and how thick is the blank you start from, and how deep are the cuts (deep ones and shallow ones)?
Thank you so much for your patience :P
Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
Hi Fam,
thanks for the nice comment.
You've understood correctly. It should be noted that the
the deeper grooves extend in the direction of the wood grain.
The timber blank has a thickness of about 8 mm.
The deep cut has about 3 mm, and the shallower cuts are 0.8 to 1 mm deep.
However, I have the grooves made with a milling cutter 0.8 mm.
Meanwhile, I have made a grating,
which you can see here.
Edited by archjofo
