Magnificent!
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
@John Allen
Thank you for your appreciation, and all the others for the many LIKES.
Here is an update on how to make the main and fore takle.
The fixing of the eye bolts on the channels was done with an iron wedge that goes through the bolt. Here is the implementation in model making.
Hermione-belaying-points-for-topsail-halyards.jpg.7d503ee0aa997ea4116f4522b3c9ca63.jpg
Quelle: http://jbriggers.se/projects/
Unglaublich schöne Arbeit Johann,
incredible work  !!!
Nils
Current builds
-Lightship Elbe 1
Completed
Hello,
I continue with my report as follows.
For the Ratlines, I bought japanese silk, which is very thin.
On the next picture are thin ropes of this silk 2 x 3 with a diameter of approx. 0.35 mm can be seen. The thick rope is 1.15 mm thick, which corresponds to the thickness of the shrouds.
Before I do the ratlines on the model, I test on a device.
ratlines-dcece8aa-dc8b-4e61-8304-b7d66a90a3e-resize-750.jpg.a155757270223da18ac92fdb8ff03b3e.jpg
Edited by archjofo
@hedley
Hi,
Thank you for your interest and your nice words.
Thanks also for the LIKES.
Here I show my further attempts to the ratlines.
According to the monograph on La Creole by J. Boudriot, the thickness of the ratlines is 21 mm 1:1 or 0.45 mm in 1:48 scale.
At the request of a model colleague we received the follogwing Information from Gerard Delacroix.
In the years 1760/80, the ratelines were actually 1.2 cm according to the specifications, but later, after 1800 and at the time of the La Creole, we find larger dimensions.
Thus, the ratlines of the lower shrouds were 21mm. The topmast shrouds had therefore 19 mm and the topgallant mast shrouds 17 mm.
But purely from the subjective feeling, I feel that as a bit too thick for the lower shrouds of La Creole. Therefore, I have made another attempt with 0.40 mm, which corresponds to 19 mm in the original.
Edited by archjofo
Johann,
Excellent work! I just discovered this thread this morning, and I have sat here for about 10 hours reading it from start to finish!
I have learned a great deal from your work - it is like watching the construction of the real ship. I really appreciate the research you have put into your work!
One thing I have been puzzling over is what to do with the loose ends of the gun tackle. I have seen other methods but they didn't seem practical for me, except perhaps when the ship was open for visiting in port and to put on a show. Your method of looping the rope and securing it with small stuff makes sense. This keeps it out of the way but readily available. Another similar method was to loop it over a belaying pin or cleat on the bulwark.
I will continue reading your build log with great interest.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
Hello Phil,
thank you for your interest and the nice comment.
Thanks to all the others for the many LIKES.
For a change, I make in between blocks with fittings
for the fore topsail sheets. These blocks are 32.5 cm long; in 1:48 scale, this is 6.8 mm.
DSC08805.thumb.jpg.ea1a9757a9a8a71495de326b3e6f4a35.jpgDSC08836.thumb.jpg.01e38b8d1ae14eb1ae70254476afeff9.jpg
As always an excellent job, the detail in every corner where you look is incredible...
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Amazing metal/wood work....such a pleasure to watch.
Rob
Current build:
Finished build:
Current build(On hold):
Hello,
thank you for the nice notes and the many LIKES.
Before I continue with the ratlines I have to do the following:
Along the bulwark of the French corvette, a series of blocks, serving for diverting, for example, halliards and other ropes, were hung in eyebolts.
These blocks had iron fittings and hooks. I made them in a proven way.
DSC08838.thumb.jpg.44ac12118353748d9246729b0b1b99dd.jpgDSC08839.thumb.jpg.2b0be9d08be280ff8f25b576631d33d6.jpgDSC08842.thumb.jpg.3cadddb01668f2aed4361dd5bfdd3d95.jpgDSC08844.thumb.jpg.2059eef771849d3e473b11358b8d3980.jpgDSC08846.thumb.jpg.5bdf4213017fe67d2fa1730da0b89e58.jpgDSC08851.thumb.jpg.c7dd14e618dc6d6d548700a7423d98cd.jpg
2 hours ago, wefalck said:
Is there an abonnement button for the 'like it'-button ?
Maybe you should go for an auto "like it" button
Carl
Hi,
thank you for the positive comments and the many LIKES.
After a short break I continue with the double blocks 4.5 mm long. These were fastened along the bulwark at the height of the waterway.
Source: B. Spinnen, Pariser Model
So far I have glued the block strops.
But that does not correspond to the original.
So I tried to make the block strops with a splice.
Here's the first try:
    I myself, would be very happy to be able to make either version!  Those are great looking hooks, where do you get them?
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
