4 hours ago, Omega1234 said:
Hey Nils
Ok.  I'm sitting here wondering...Mmmm, is there ANYTHING that Nils can't do?????
The simple answer seems to be a resounding NO!!!
Top job, Nils.
Cheers
Patrick
You're correct Patrick, and all that I can hear is a loud NO, all over the globe along with viva Nils as a repeating chant!
Havagooday to all
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
This is to sincerely thank  - Steve - Keith - Rob - Grant - John - Daddyrabbit - Hartmut - Mark - Patrick - Greg, .......
I am simply overwhelmed with so much appreciation and compliments and am pleased the model (even if not completed yet) is so much liked
Steve,
thanks for following on regularly, glad you like it....
Keith,
as she is laying alongside of the fitting out quay, nows the time for adding many details that were going round in my mind....
Rob,
if they wish, MSW members can book a free first ride...
Grant,
thanks for your kind words...
John,
there shall be lots of small detail adding, the command bridge shall be a bit tricky, as well as the ships boats
Daddyrabbit,
I`m quite pleased she worked out meeting my own approval in that scale (I had some doubts in the beginning)
Hartmut,
thanks for your kind compliment...
Mark,
nice words, much appreciated, many thanks to you..
Patrick,
thanks so much for your nice words...
Greg,
thanks for following the build and your kind compliments along with the progress...
Nils
Current builds
-Lightship Elbe 1
Completed
super progress since I last looked in Nils!    really looks sweet!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you very much Denis,
made 2 additional smaller watertanks for the aft boatsdeck today and added the fill- and discharge tubes on all three
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work, Nils.
Bob
Current build:  SS_ Mariefred
Many thanks Bob, Daddyrabbit and Greg,
for your nice words
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for catching up with the build B.E.
and for your words, I`m pleased you like it...
Nils
Current builds
-Lightship Elbe 1
Completed
small update :
all the fastening points for the funnel guy wires are placed. In order to check if they go clear with the structures and they do`nt foul the vents and the boats, I put on preliminary thin polyester threads that resemble the tin coated steel wires that will be attached in their place and each one spanned with its own buckle screw. It looks like all is clear to go....
Nils
Current builds
-Lightship Elbe 1
Completed
thank you so much John and Greg,
for your kind compliments, much appreciated..., the final guy wires shall be of dull silver color and less dominating
nils
Current builds
-Lightship Elbe 1
Completed
Very impressive, Nils. She's starting to look "all dressed up". I would have expected those "funnel stays" to have something to tighten up the tension, or slacken it for that matter.
Cheers
Carl
Cheers
Thanks Carl,
please ref to my post-text  #2112,  for tightening the wires there will be turnbuckle screws attached to the deck, (Spannschrauben) for each "funnel stay".
These black threads are only preliminary for checking reasons as mentioned....
Nils
Current builds
-Lightship Elbe 1
Completed
44 minutes ago, cog said:
Thank you Nils. I seem to forget things ... to much interesting news on this site!!!
You`re always welcome Carl,
Nils
Current builds
-Lightship Elbe 1
Completed
33 minutes ago, albert said:
Nils your model is  fantastic.
Albert,
thanks very much for your compliment...
Nils
Current builds
-Lightship Elbe 1
Completed
Cheers
Hi Carl,
in answer to your earlier question, I would like to provide this illustration :
this is what the funnel guy wires will be like, here I started with funnel 3 + 4
The steel wires are 0,3 mm diam. normaly used for wire controlled model aircraft. The fact that they are tin-galvanized coated provides excellent soldering possibilities. The buckle screws are smallest I could find (M1,4 left /right thread), I blackened these chemically.
The small center drilled nickel beads are from a fashion jewelery store
Nils
Current builds
-Lightship Elbe 1
Completed
That impressive rigging work on the funnels, Nils.  It looks wonderful.
Thank you very much for your kind comments Mark and Carl,
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils -- Fabulous!  What your work shows me is that a ship from the early 20th century has its own grace, and is no less complex than one of those architectural beauties of the 18th century (such as your own Pegasus).
It's all very, very fascinating.
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
I agree Martin,
thanks for your words,
that was also a strong criterium for choosing this build. I also love the nostalgic charme of these ships....
Nils
Current builds
-Lightship Elbe 1
Completed
Fantastic job on the guy wires Nils.  Good work practice to test alignment first, before fixing the permanent wires.   Saves a load of headaches.
Rob(Launch date is soon arriving ....)
Current build:
Finished build:
Current build(On hold):
Rob and Bob,
thank you very much for your compliments for the wires.....
Nils
Current builds
-Lightship Elbe 1
Completed
