Hi All,
We've had some really cold weather here. -25F last night. That means lots of
time in the workshop. :) I've started the outboard planking from the wales upwards.
Here is the batten strip placed to set the run of the wales.
The first layer of the wales have been added as well as a thin strip added bellow
the gunports. This serves a location for the molding to be placed in a second layer
as well insuring the run is smooth.
Then the planks were added between the wales and the molding strip.
She looks a little sloppy now but once I finish the planking between the gunports
I'll give it a quick sanding to clean it up.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks Bob. Mind if I throw it in the mail so you can plank the hull? ;)
Rusty
I’ve added the planking between the gun ports. Pretty straight forward.
Still a lot of sanding to do.
Here you can see the stern framing with the reference line it will need to be
sanded down to prior to planking the Transom.
Rusty
Thanks gerty.
Bob it'd be money well spent as I'm always learning from you.
Rusty
Hi All,
The transom has been planked but like everything else needs a good sanding.
Here you can see how interior of the outside stern frames have to
be thinned down to about 1/6".
Next I'll have to do the fashion pieces and start planking the hull.
Rusty
Thank you Ben and also the "likes".
I've made the fashion pieces and placed them. At this point I'm supposed
to add the second layer of the wales. I decided to delay putting them on until
I run the first couple of rows of hull planking.
The plans shows a drop plank near the bow. So I'm running the first two strakes
with the drop plank before lining off the rest of the hull. A card template was used
to find its shape and then cut from a boxwood sheet.
Next up will be a lot of planking. :)
Rusty
Hi rusty
Jumping on board to watch your build, I have a Syren waiting on shelf for me
after I finish my Endeavour. From what I have seen so far your build
will be a good one to get some tips and ideas from and to see how
it should be done.
 cheers Chris
Edited by Cabbie
At this point I'm supposed to add the second layer of the wales. I decided to delay putting them on until I run the first couple of rows of hull planking.
I wish I had thought of this when I was at this stage, Rusty.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Thanks Chris and welcome aboard!
Thanks Mike. Unfortunately this revelation came from screwing up the Wales on a couple of other builds. :)
Rusty
Hi All,
After placing the first two strakes it was time to line off the hull. The hull
was divided into two bands of 9. Each band was laid out using tick strips
and a planking fan as Chuck described in his log. I also added the second
layer to the wales now. I will wait to paint them until the hull is fully planked.
Here is the first belt fully planked.
Rusty
Nice work, Rusty.  Do you mask off the not-the-wales planks or ???  Curious since most seem to paint the wales first.
Thanks Chuck.
Mark I've free handed in the past. If it doesn't go well this time I'll start over and mask it off.
Rusty
Freehand?  Thy hands are steadier than a rock, good sir.  I salute you.  :im Not Worthy:   If it were me, everything but the wales would end up black.  ;)  :D
Edited by mtaylor
Well I've been successful in the past so I'm game to try again.
Getting tougher every year though. ;)
Rusty
Hi All,
Well I've completed the hull planking and the square tuck. Taking ones time,
using the planking fan, planning out the belts and run of the planks actual
makes for a very enjoyable experience. No more forcing planks and getting
an uneven planking job. Follow Chucks description and methods and you won't
be disappointed.
Also you'll notice that a work area cleaning was recently completed!
I'll be out of touch for a couple of days so I'll apologize now for any late response.
Rusty
Thanks Nigel. Yes I use a pencil on one edge.
Thanks Chuck. Oh it's sooooo much more fun although I think knowing now what you've
taught me I would have done a much better job on the Confederacy.
Rusty
Rusty nice work on the hull very clean, you must be pleased.
Michael
Thanks Al. It's a great build and between the instructions and all the help here you can't go wrong.
Yes Michael I am and thank you.
Eric You're glad just like I am to follow behind those great planking jobs before me.
Seven weeks Is more like a dozen during the winter here and semi retirement. Within
a month everything will slow way down. :(
Rusty
Well I’ve been able to get some time to work on the Cheerful and all the
treenails have been added. I went with the simulated ones as Chuck
described. I decided to go very subtle with the color of the treenails.
While doing the treenails the clumsy hands came to visit and a couple of
planks suffered some damage. So a minor tear out and repair was in order.
It’s fun to do stuff twice. :D
The molding have been place, wales have been painted black and a coat
of wipe on poly applied.
Rusty
Great looking hull, Rusty.  I agree on "doing it twice makes everything twice as nice".   My grandmother used to say that and didn't get it until I started model ship building.  :D
