We now return you to your regularly scheduled build already in progress.....
Well, it's been a while since I've posted much of anything. My temporary shore job went temporarily bust just after Christmas (it all came down to a numbers game, there are simply not enough ships running this year to justify the overhead expense blah blah blah (we'll see what happens in audit season!)). Anyway, I'm not out of gainful employment, they've sent back to the fleet (yeah...what fleet?!) at any rate. Long story short, I've had some free time on my hands, so I figured I would start hacking my way through another build.
If some of you may recall, I've got two frigate kits sitting around waiting to be built. As the title suggests, I decided to tackle the HMS Diana first. I didn't take any photos of the early part of the build, mostly because at the time my head wasn't in to documenting for posterity, every minute (mis)step I went through.
Reviewing some of the other build logs (Ray's and Jason's), they pretty well sum up all the pitfalls to watch out for when building this kit, and there are many! In general I found the CnC cut bulkheads leave a lot to be desired in terms of cut accuracy, in many places I had to sand down or shim up in order to get a smooth run of planking without dips or bumps.
I've finished the first planking, and I made an attempt to try something like the method that Chuck espouses for his builds, and ended up with (to paraphrase Douglas Adams) something that almost, but not quite entirely, doesn't resemble it. But it was good practice. I found that the kit was short 4 strips of the first planking material. But rather than order replacements, I found I had enough long scrap pieces lying about that I could reasonably cobble together the missing planks without compromising on the strength of the hull. You may be able to spot one or two of the odd planks in the attached photo.
At the moment I am currently marking out the gun ports. As has been observed, the included template is pretty much garbage. It's a lot easier to take the base dimensions given in the instructions and draw out the ports using a ruler and dividers. Around ports 7 and 8, I found the distance between the ports needs to be slightly greater, around 37mm as opposed to 30. This is where the entry ladder and fenders will eventually go.
Going forward, I intend to replace much of the kit supplied second planking, and last week I ordered a good supply of castello boxwood from Crown Timberyard. Below the wales will pretty much be kit stock, as it will be largely covered by the coppering. I am going to try to make any of the exposed walnut planking look more tarred than painted.  I have no intention of using the kit supplied copper plates, I find the Amati plates much better looking and far less.... pimply. I also intend to replace all the blocks, rigging fittings, deadeyes etc., and rigging line. I will probably replace all of the guns, as I'm not a fan of the supplied versions. That oversized bowling ball of a cascabel and weird muzzle shape detracts from their appearance, but the two largest size guns that Chuck sells do match closely with the dimensions of the supplied guns (discounting the aforementioned bowling ball).
I would have some more photos, but the battery on my camera ran out of juice (I really should check these things more often). I'll have some more photos soon.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
nice to see you posting again andy, will be following you again if permission is granted
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kevin, no need to ask permission, you're always welcome!
I got the batteries charged so here are a few more photos as promised.
I used the kit supplied tanganyika for the deck. I expected it to be splintery, but useable. After sanding the edges, I used a pencil to simulate the caulking. I've seen a lot of discussion on whether to plank the deck before, or after installing the false deck. I suggest doing both! OK, now you're confused, but it's really not that complicated. After marking out the centre line and the butt shift, I planked the centre section only, until all the hatch ways and other openings where surrounded. There's still more than enough spring in the false deck to install it as once piece.
The other two photos show the first planking at the bow and the stern. Not much more to show for the moment.
Andy
USF Confederacy
Nice progress, Andy.  And welcome back.
Welcome back.  you are right there's plenty of spring in that deck. I installed mine in 1 piece.
Keep up the great work,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Welcome back Andy! Looking forward to following along with this one!
hamilton
Welcome back Andy. Nice to see you posting again. I'll look forward to following along with this one.
Missed your friendly and interesting stories but good seeing you back in the shipyard.
This first planking looks excellent, good enough to pass for the final planking.  Good luck with the job situation.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Looks like a nice ship you have there! I will follow as well, if I may.
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Hello again everyone, and thanks for all the likes and comments.
Time for a small update. I've been busy lately with the gun ports. I was reasonably satisfied with the layout on the starboard side, so I decided to start hacking them out. It's not 100% accurate, but it will be one of those things that separates my build from everyone else's.
As has been identified by other builders, the forward gun ports cut through two of the bulkheads. For my approach, I decided to laminate leftover pieces of first planking in order to build up the thickness and support the bulkhead extensions. For the first layer, I offset the planking by starting with only a half width plank to improve the overlap between layers and make for a stronger structure. So far no observed issues and the bulkhead extensions appear to have retained some strength.
I've also made a stab at the lower counter. The instructions say to simply plank the area, but I read in Jason's log where he created a template. I used some 1/32" basswood sheet I had kicking around to create my own version.
Moving on, I need to verify all the port side gun ports to ensure things line up as closely as possible before cutting them out. I've had to redraw the forward ones a couple of times already. But I'd rather waste sand paper and a pencil lead and re-do it as many times as needs be!
Any day now I should receive my order from Crown Timberyard as well as my first order of replacement bits! Can't wait!
Andy
USF Confederacy
Wow - the planking looks amazing - even at this early stage I can tell she's going to be a beauty!
hamilton
Hi Ben, glad to hear you're getting back into it. I'm looking forward to seeing your next update(s).
Ed, thanks for the kind sentiments. I'm not totally sunk, but just undergoing my own personal recession! Hopefully I'll have some stories to share soon enough.
Thanks again to everyone else and all the likes, and especially all the compliments, they are very much appreciated.
So a small update on the goings on last weekend.
After re-checking my measurements, I've begun to cut out the gun ports on the port side. In some areas it looks like you need to put on a pair of those old blue and red 3-D glasses in order to make sense of all the lines. But it all works out after a fashion.
To help break things up a bit, I decided to intersperse one monotonous task with another equally monotonous task, and began lining the starboard gun ports. I'm using the kit supplied walnut for this task, as the end product will be painted anyway. The instructions say to use the 6mm strip, but I found the job easier by adding widening the strips to 10mm by adding a 4mm strip. It means I'm not fudging around trying to get all the angles right, and in some cases the thickness between my bulwark and outer planking is a bit over 6mm anyway.
Not much more to add for the moment.
Andy
USF Confederacy
Look'n good Andy...... nice to see you back in the shipyard!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
So.... One of you, not sure who, was hoping too hard that I'd get back to work soon!
Seems like fate has a sick sense of humour, as I was just getting underway to head up to the cottage for the May two-four weekend (aka Victoria Day weekend), the first long weekend of the summer, when the stated objective is to do as much damage to as many cases of 24 bottles of beer as possible, the dreaded phone call came... Stupid hands free blue-tooth... No excuse to not answer....
But I digress, at this point I'm not going to say not to work, even if it is only for a few weeks (allegedly). So I'm off first thing tomorrow morning, and as usual all building comes to a halt, and I was so looking forward to playing with that most excellent castello boxwood that arrived in the mail just a couple days ago... Oh well
Andy
USF Confederacy
Andy, have a good trip and make a few dollars to buy more tools and wood.  That seems to be the way it goes...   Cellphones are the bane of our existence.
Great to hear the good news on the work front Andy, but timing really sucks! We'll still be here when you get back, though I can't promise the same for those beer cartons..................
Ship is looking good. If no more work had arisen shortly you might of had to change your MSW name!!!!
Work safely and look forward to a new update.
Regards, Scott
Completed builds:
Awaiting construction:
Jeez Andy, I nearly missed this.
Good to see you back with tools in hand mate, it's been a goodly while.
Diana's looking splendid and is in skilful hands.
Shame about still getting screwed about by the job, but, it does keep the wolves away from the door, or in your case, doors.
I've locked onto you now mate.
Be Good and Stay Safe
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
I might be a little late in this offering, but I could babysit those cases of beer for you if needed :cheers:  :)
Hey guys, thanks for all the well wishes. :)
So the "allegedly" has now been expanded, possibly until the end of June, which I really don't mind too much, as long as I get some time up north at the lake in July.
Andy
USF Confederacy
Happy birthday Andy.
Cheers,
                       VOC Ship Surabaya
