Nice crate. I like the "broken wine glass" symbol for FRAGILE !  ;)
Jack
Current buildUS Constellation
Druxey, not too far but it will go into a warehouse storage until the library is finished being renovated which might be another year before the model is reinstalled. I have seen the results of flimsy crates in the past. The goal is to make sure that the model is well protected until it is needed.
Michael
Edited by michael mott
I am thinking that a couple of stretcher bearer handles screwed to the long sides formed from a couple of 1x3 shaped at each end might work. then two or four people can move it relatively easily. The crate weighs about 110lbs. the model is about 100-120lbs sitting on the base.  for maneuvering in tight spaces but where there is lots of room they can move it with a pallet jack or fork lift.
Michael
Manual handling is far less risky than a fork lift or other mechanized method!!!! Unless you want to do the restoration all over again....
Heavy duty castors might be a better alternative.
Edited by druxey
It does keep him busy, druxey ...
Carl
Better slap a label with something like "Do NOT use a forklift.  Hand carry only".  I have seen some labels like that many years ago for delicate electronic equipment.
When I first started as an engineer in 77, we had a computer that had a Removable Hard Drive. The drive housing came in a crate about 2X2X6 feet! The removable portion was about the size of a cake holder, the ones you put a finished cake in. The "This Side UP" labels were about 4" square and had a hollow Arrow symbol On the frond was a clear tape, and inside the arrow were red foam beads along the bottom. If the crate was tipped on its side or upside down, the beads would flow downhill, and get stuck on the tape. There was two labels, one at each end of the crate. Thus we could tell if it had been mishandled during shipping. One day a drive came in with one of the arrow labels installed upside down. Our boss saw the label, with the beads stuck on it, and without checking the other label, or the other printed "This Side Up" labels painted on the crate, called the shipper, and cussed them out! Only later did he tell us about it, at which time we pointed out that that label, was upside down, not the crate!
Ron Thibault
A magnificent job, Michael. I just went back and looked at the first page of the build log. What a transformation! You have good reason to be proud of your achievement. I take my hat off to you, sir.
Steven
Thanks everyone for following along on this journey. A couple of small Items completed the work today. The gratings on the starboard companionway And the installation of the flags. I had to do the house flag twice because the first time it was upside down. I can say that the house flag can be raised and lowered though.
I had some etched copper from Scale Link that I picked up in 1979 from Puffers opposite Kenton Railway Station. after cutting the size slightly oversize I slowly sanded it with some 600 grit until it just fit snug. I used a toothpick with beeswax to pick up the piece to place it for final gluing.
Then I decided to reprint the house flag in red rather than the blue one.
The ensign was also re printed on some light weight silk-span, I decided to shape it after setting it to the stern flagstaff.
And now.....She's done!
When we get back from Whitehorse I shall crate her up after the inspection.
Onward and upward.
Michael
Thanks for letting us tag along, Michael.  Looking over your shoulders to see what was done has been an experience that most of us will never have first hand knowledge of.
 A long and challenging journey, Michael, and the result ... I wouldn't be surprised she looks better than before with all the TLC you have given her. I hope she'll be out of the dark, into the spotlight soon
Carl
Congratulations on completing a long and painstaking restoration, Michael! You've done a beautiful job on Albertic. I can only hope that your client is truly appreciative of the craftsmanship that has gone into the model.
P.S. In the second photo (starboard companionway grating), is that bilge keel slightly loose?
Ditto what everyone has said above.  Fantastic job. Thanks for taking us along,  I learned a lot from your restoration.
Jack
Well done Michael !
 Love to see the "Albertic" in a wonderful condition again
after all those months and weeks of restoring this beautifull ship it must be a touching moment when she leaves your home again, onwards to your customers new  display station...
Nils
Current builds
-Lightship Elbe 1
Completed
A great achievement and an educational tutorial on how to do a restoration - many thanks Michael it has been a pleasure following this log.
cheers
Pat
finally I get to check on your progress here............and I find your nearing the end!   a huge congratz to you........you've done such a masterful job on her.......looks absolutely gorgeous!   must be rewarding to finally get to making the crate for her return  ;)    so happy for you!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
A masterful job, Micheal, from start to finish.  An encyclopedia of interesting problems and innovative solutions.  Bravo.
Ed
Thank you all for your support and counsel while I undertook this restoration. Your collective encouragement and valuable comments helped immeasurably.
I am now looking forward to the final inspection by the client and then it can leave the modelshop freeing up valuable space for the next occupant of the workbench. I am going to enjoy having the extra room to work on the cutter over the next little while.
Michael
I don't know how I missed the conclusion of this project, Michael. As others have already said, you did a masterful job, and what a treat to see such a historic model restored to her former glory! Well done!
