Hi Jack.
Wow your boat is truly a master piece.
If weren't for the wood grain on your table I would agree with Yves above post. Real nice workmanship.
Such a nice looking boat. With lots of character and style.
Regards Antony.
Edited by AntonyUK
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hi Mr. Jack...
The boat, Falkusa is done brilliant, this is an outstanding sample... But You have touched me with the crates !
It would be nice to see the higher version of the sail (just a thought), it makes her to be charming. this could be shorten to about 3/4 ... But, the truth, the glass cover would be heavier...
Can't wait to see the buckets !
Edited by MarisStella.hr
Considerations about the sails of the Gajeta . .
The Gaeta (Gajeta) Falcata (Falkusa) seems to be a very versatile boat. We learned how this boat can be used with two hull configurations, one with high sides, optimized for sailing and one with lower sides, most suitable for fishing with nets.
But its versatility also manifests itself in its sails. Let's think about them.
The following image shows three Gaeta configurations, from left to right:
a- sails with "high" main sail; the main sail is very high, probably suitable with light winds;
b- sails with "low" main sail; the sail is not triangular and mounts a beam even belo
c- no masts/beams and sails; configured with low sides suitable for fishing; the rudder has been removed.
y4mXs78TVnBiexnWXUr0bfQolawWN5f6sVZMYOAv
The following image shows a Gaeta in configuration type (a); for my taste this is the most beautiful and majestic. And here we can also look at another variant: the double jib, interesting . .
y4m8tB-HobmzxIk9P5_oGLMcGfsom6XpCfKChqZB
Here below the boat is in the configuration type (b): lower sail, jib fastened half way on the bow beam, although we have seen that it can be fastened on the top of the bow beam. The main sail may seem triangular but seems to be rolled on the lower beam and for this reason doesn't look like in the image 01 . .
y4mItzZjsFegFDT_5PZqjcCXPyoaLRCi3b09UF1h
Here are other images with an apparently "low" sail but with a real triangular shape. Images 04, 05, 06 and 07. Let's say this is a new type . .  we'll define Type (d); obviously this is another sails configuration !!
y4maEkqG55LogEGlUwFhEWy1Kq8kj7JrhRUKSfLP
y4mKywSi0RuJ5GkeAGi8_emhhdkc0FPDrGNp7-yV
y4mMzschrT-pa1GV4ej2QYGoVI2VPTll9IRboybc
y4mVJV-UOAPY7FCu5yUZ7gjqxwD7RNApSxSvM5_D
For now I have not found more configs, but it's not said that they do not exist.
For reasons related to the size (height) of the plexiglass cover for the showcase, although my preference goes to the sails type (a), I decided to adopt the
configuration type (d).
The kit features pre-sewn, well-made sails. Unfortunately they are for the configuration type (a) and to transform them into sails type (d) there is some work to do: the main sail needs to be ex novo rebuilt. But here some problems arise: I do not have the same fabric and so I should also redo the jib; but I'm also a dud with the sewing machine, so the result could be bad if not worse.
So ? Simple, I will install the original jib and the main sail tied to its beam as in the images below . . With this solution I just need to cut the big sail to the right extent and the game is done; once rolled on the beam its wrong shape will no longer be visible . . Hyper-pragmatic solution . .
See you next time, Jack.
08 Alla fonda 01
y4mS1LBagsQqYbpWMgRSCFoWW9OUQQsNvl8XqLug
09 Alla fonda 02
y4mnmbXpch3tQhhKJZCFc7ac4fQN6FtjnX7hpWSA
10 Alla fonda 03
y4mAdRQp9cyjif94fByo6Ys-w7BwKrHNLZ2LgwnI
Edited by jack.aubrey
There is one point to consider about the sails, I think: the "high" rig that you prefer will also be very cumbersome and require a huge glass case. I would personally go for the 2nd type which is also very beautiful in my opinion and need a considerably less high case.
Tuesday 15 August 2017
I almost finished the buckets !! Now it just miss the painting of the brass handles with "gun metal" and they're over.
Today my wife did a very good job with sails that are almost finished . . I need now only to hold the wire knots with a drop of glue.
Two photos of the buckets where you can see also a small detail of a sail.
y4mDGWthgo6iy5P78ixdbPaDYyA49tsNqQUeJuU_
y4mQUfjQhownuWV9SgtZqK7uo6P5tLuC-S2wkpT6
Goodbye, Jack.
I love the buckets and the sails, Jack.  I had to look twice as I thought at first they were the real thing.
Thursday 17 August 2017
Having finally finished all the various detail components, yesterday and today I was able to begin working on the masts and its rigging. The pictures below show the work done so far . . far from being near completion. However, the goal is behind the corner, maximum another week, then it will be time to setup the beach of Comiso on the displaycase . .
See you soon, Jack.
y4mNDVGQWOMWishgWG6bJxczGZn09fmXt_2CbruA
y4m8eNUcVJtdSzGI8cIu7SfqdpA4BTHFqKQXt5Tr
y4m-eKy38gIsxwnQvoVEZjEb5CeOC86Vi--HchBR
y4mi3ADhBErVSzNeV7PMXUZIlgC67yf0jTBKB3SN
y4muJwK0jB4SK4K0sW5ppiEw0X5FvLHIU0gyk-02
y4m5oqTGTa9rV_yniT_IAVOvMnwRxtibgoWdPDdM
Tuesday 22 August 2017
At this point the model is practically finished . .
Now I have to prepare and apply the rope curls to add realism to the edges of the running rigging and then there is nothing left to do.
In the next days I'll focus on the setup of the displaycase basement, according to the idea I described some time ago (rocky beach, various accessories left on the beach, etc.)
Soon, Jack.
y4mbet_oLTzhWmub0IlU0OfKmW_1lmmCE3MWshPL
y4mjKv5wA6QK9GY0ZN-u1xRYDeC6Qn-pfCoElI5G
y4mmPm2gYi6sc564FX8aEa9i3Kk6t4k4wNGsScGC
y4mbam0liievZy6c9jp5Gaa8EMUFpAOzd4K38sII
y4muYk8o6vbor7puvsffR7edsR8nUNj3GqPwlGLw
2 hours ago, yvesvidal said:
Jack,
It is a little marvel. I cannot wait to see how you will decorate the base and re-create a section of beach.
Yves
Thanks Yves for your very positive comment, thanks again, Jack.
Other new images . .
y4mzBQ9MsVTllQDJQvTgsGKteyaYrfwBa6DI1_XL
y4mN9t16RAvRBZou3TN5-m5EePkJA7oqv3wt3BQd
y4mQvbaqxcHfG__81y5dkH4Xkjfj_ZJxcOyCI8V2
y4m7CF8x_Cq1rbWufsaqlZAPkuguk6-8KnThRgo7
y4mDgsuw9UQKxr5KMC2vpM9he2X_0VrqfV2A9pqP
On 22/8/2017 at 7:26 PM, yvesvidal said:
It is just amazing. These sails are a masterpiece. Please congratulate your spouse.
Yves
Thank you very much, Yves, for your comment; thanks again, Jack.
Wednesday, August 23, 2017
I've finished with the last rigging details, like the rope curls at the ending tips of the running rigging.
With this last activity, the model by itself is truly over . .
Now only the display case is missing in order to close the shipyard.
y4mNstSywkWVA9-Ovs0W49Yq8YMoZpUKYd44NGtx
y4m5LO9m-8GRgeB4ReEOIaoewQ-KOQGJMncgiVmb
y4m-OPoaNwOM4RHukI2UcWAyD_lWGpgFB3z9g3CF
y4mG26sDvUBRSjcVLamZ-s-kTZcbbi9mflS-CiZK
y4mqNpRlJIdsfu-d194ZAuFLCUiC7VH384OTN43N
y4mDqlBqChcRaZ6AF_8DLKPyhNoaUt7oI6p8eNiH
y4mpWGF6yPZQEtTYoysijS6WDQPuC-x0l2Who09l
Just amazing. Again and again I am learning that these small boats are so appealing to me. Thanks for sharing.
"A smooth sea never made a skilled sailor."
Completed: Smuggler
Hi Jack.
What a fabulous build.  Your modeling skill's are first class.
MarisStella make some very fine examples and you have just boosted there sale's no end.
Cannot wait for your next build.
Regards Antony.
Completed Mayflower
an awesome sailboat model Jack,
love the look of it, very realistic !
Nils
Current builds
-Lightship Elbe 1
Completed
Many thanks for your positive comments, friends . .
Saturday, August 26, 2017
I put inside oars and a couple of accessories, just to understand that much of the material I prepared will be better if positioned on the (future) beach . .
The next images will show the model inside its display case . . probably by the end of next week, bye, Jack.
y4mSGLJdyA5p1SXA3jR50nWJ6udcNUVnH_SGf0Tc
y4mZ47PoAQl8WjJQ1NKD2LiyXl4wwVcD1ty0Qwrj
y4mUvU4nBZ-jB7-vws276EEAvKAsb49kwjdc9UE1
y4monV7eDaYAbXHBI4s0LEWHgNerNl423HKUQrLL
y4m2gGSgVIspvfR1i3DTUzdQRCbur0e5nt2bj1Cg
Monday 28 August 2017
I'm working on the display case base . . In particular I'm preparing the so-called "beach". To hold the small pebbles of the Elba Island beach called "200 steps" I used vinyl glue, laid abundantly on the wood basement.
The work is not yet finished because I think it is better to make another layer of this sandblast and then apply the larger pebbles individually. . I now have two new sizes . .
Interesting experience. We will see how the situation evolves.
See you soon, Jack.
y4m3PNP6JLGO1WkkAn3kzaI3-gmWHOwkoVOAQyBj
y4m7RljYIT5tKuXDIUkquawoxFFLtAChCMkAwQ1j
y4mmZ1zeXDlA5cfnBYWt1_aNwSwZxemwGMO-X7Uf
y4m6NT3gBthyf2f9Ecv48w5hF5D2eG4J8I43nTcE
Wednesday, August 30, 2017 - Finished
These four pictures show the finished project, under its plexiglass cover . .
Due to reflexions and low light the photos are rather poor, but they still make the idea of how the whole complex appears.
Now the adventure is really over.
A further batch of more detailed images, as my customary, will follow soon.
A warm greeting, Jack.Aubrey.
y4m-B-_nNkx3raTMy5fm6uxjFQHCPLbHwOwSfvEf
y4m6HcF-EEW4jhhJmO6F_Rs8HWFE1bzWxh_DsjOt
y4mO0IFrUJyLwois70cI0lKKqYCKJUmt0v7rfU8E
y4mL10CVzIBjiXwkG-8nNYDNvsyl1cFZiLqGxxFs
