Thanks guys for the kind words and for all the "Likes".
Right now I'm trying to decide whether to fair the exterior hull or continue making deck clamps. ;)
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
  • 4 months later...
I thought it might be a good time to do some catching up. Hard to believe it's been 4 months since my last post.
In preparation for adding the lower platform clamps, I installed a beam recessed to fit around the inner post. I will use this to align one edge of the aft platform clamp
Only one side of the hull will be planked. The other side (open side) will only need two short clamps that represent the length of each platform both fore and aft. Measuring from the draught onto a balsa template made it easy to locate the lower platform position.
Here is the aft platform clamp installed after using the same method. Clamping was tricky.
I have actually made more progress than what is shown here. However, the lower platform clamp stills needs to be added on the planked side of the hull. I'm waiting for some deep reach clamps to arrive before I install it. This and more to come soon!
Mike
I just finished the port side platform clamp. The clamp was held in place with Wolfcraft clamps which can go deep into the hull. After gluing the aft end of the clamp, another balsa template was used to set the position of the forward end of the clamp.
_DSC8433.thumb.JPG.bdcaad89f6e3f353e006924b2f5e07c5.JPG_DSC8434.thumb.JPG.83d38c13d51ee3082e2cdd3d21907f02.JPG
You'll notice that I have been fairing the exterior hull. For the most part it is done. Just need to do a bit more work at the stern. Also, I left a 1/2" or so of extra thickness at the top timbers. After the Forecastle deck clamp and stringer in the waist are attached I will final sand the top timbers to an even thickness along the hull.
Mike
Edited by Stuntflyer
Thank you, druxey!
Clamp source:
https://www.fruugo.us/wolfcraft-mt-70-precision-spring-clamp-clamping-width-max-7-cm/p-18753538-41049855
Mike
1 hour ago, bobcat said:
Does anyone know where to buy the Wolfcraft MT70 clamps in the US?
Thanks,
Bob Friedman
Bessey makes a near-identical clamp available on Amazon. I haven't tried them but uses other Bessey clamps for larger woodworking and love them.
https://www.amazon.com/Bessey-XCL2-SET-Clippix-Needle-Spring/dp/B0749RZBZJ
Completed Models:
Triton Cross Section
In Progress:
Brig Eagle
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Mike,
Are you using the graphite paper transfer method for all the necessary parts that need to be copied from the plans?  Or did you use a copy machine to make copies?
Interested in hearing how you transfer your templates to wood to be cut.
Thanks
Shawn
Shawn,
I started out using graphite paper as a transfer method. By the time I started work on the frames, I switched over to Elmer's School Glue and plan drawings which were made from a printed copy. There are times when graphite paper comes in handy, like when I transfer a scarph joint shape. So, both work, just depends on the application.
Mike
The shop has been a busy place lately. In preparation for the quarter deck clamp/stringer in the waist and Forecastle deck clamp install, it was necessary to remove the small temporary filler pieces between each frame. My method is to wrap the fillers (3-4 at a time) with a moist paper towel and apply a hot clothes iron to the surface of the paper towel. The steam penetrates and loosens the joint. Needle nose pliers can then be used to remove each piece. Final sanding of the exterior hull will be completed later.
Using this height gauge, vertical measurements were taken from the shear plan at various locations and transferred to the interior hull. The thin boxwood strip was glued to the gauge with CA and pushed through between the frames, so tic marks could be added.
The quarter deck clamp which becomes the stringer in the waist is installed above the upper deck clamp.
Mike
Your framing looks excellent Mike,
Nils
Current builds
-Lightship Elbe 1
Completed
The two forecastle deck clamps were added today. They sit below the stringer at the aft end which allows the forecastle deck beams to sit flush with the top edge of the stringer. At this stage the hull is quite strong.
Mike
Excellent workmanship!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Really nice progress in the last few month. Very well done, Mike
Regards Christian
