Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
7 hours ago, semorebutts said:
I hope AK Interactive airbrushes ok as I have zero experience with AK paint.
Looking froward to seeing how this paint works for you. I have the same set. I will be using at least some of them on my Houston build.
I think I am leaning toward the rail gun build as well. We have had a number of Missouri builds as of late and besides I know almost nothing about the history of the rail gun and following the builds of others gives me an education while I watch.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
I've bought some of it as well.
It would seem wise to try out the paint first on an old model you don't care about losing if it gets screwed up. I have read that others found reducing the paint to be tricky, perhaps because they did not use AK Interactive reducer? I don't know but it's worth proceeding with caution rather than ruining an expensive model. Retarder for acrylics should work with any brand as long as it's acrylic but test it first.
'arry,
What's a few pounds more or more ... fortunately I couldn't buy it as I'm unable to carry it presently ... you need to build a shed around it :blink:
Carl
I started today by masking  off Mr. arado.
then i airbrushed model air “black green”  I then pulled off the masking tape and hoped for the best.
501C2B96-236A-4881-B371-F8AB8B54B3B9.thumb.jpeg.ac1baa0bde6a81eb5d73ac380198fe33.jpegFFC2B356-7F64-4C4B-A1AF-4353AAD1874D.thumb.jpeg.db9dc9dbff0dbcf99b50032c538c706c.jpeg
well thats acceptable.  Time to brush the engine black.BBC9B9A9-1536-4418-BF08-87AA2A236AD0.thumb.jpeg.eb75b47cd32ffe528cd8f9427c343456.jpeg
next I placed the canopy in postion and added tiny drops of glue all the wAy around it.
i then brushed light sea grey onto the struts.
last I added the prop.
5933ED0B-FFC3-4D1B-82FC-4115D34C5238.thumb.jpeg.a9adb2673f7e9b56e639b236af7877d4.jpeg1486BF1D-61CC-415D-A279-253B7033FC07.thumb.jpeg.06a5a7dd48d8c754863c74fd439c60bd.jpeg
i just have the decals to do now I think.
Depends if the shading should pass over the decal or not. If it does it's easy, than it is "Yes", you'll be inventive enough for the other possibillity ;)
Carl
What I do: I spray a layer of gloss lacquer, add the decals, when fixed,  spray a layer of clear lacquer, satin or mat, and after that shade or weather or whatever
Carl
Thanks Cog. Turns out my shading stuff is barely visible on the plane anyway.  It’s only good for grey ships.
I put some decals on.
F3D9D927-56F2-407A-90F3-61F58FE1A2C0.thumb.jpeg.c38a37b88594389889a767ac1afc55f9.jpegA6A37AC3-E04B-4007-82D6-F5A8717D4938.thumb.jpeg.be4efa49fcc2c642a536eef46a5b9b25.jpegFB07BE89-AE5D-4CBD-B5C6-E6E6E988761A.thumb.jpeg.b661a1e5ae61bae6b2baf85bb193af74.jpeg
and placed it on the ship. I didnt glue it yet.  My question is should I paint the 2 pontoons grey like the struts?
82572355-CF56-467F-9002-844A4EA75900.thumb.jpeg.ef2cbcf4b23b8a947fee9114d126235e.jpegECFCFE79-C955-4F83-B2CD-D2661230330E.thumb.jpeg.b7e5d2c5c29221bc79ab23ebb124b47d.jpeg1AC15B75-894E-4411-B4DE-E139EEC3E90F.thumb.jpeg.d4ef609969259176e461469d899cb308.jpegE0D0B1F1-80D9-4A60-B7F6-D75B00C4113A.thumb.jpeg.cacb35b156039df280b8ba52b493d397.jpeg
Edited by semorebutts
1 hour ago, yvesvidal said:
The floaters should be painted in the same way as the plane. Here is a picture from the LargeScale plane forum, where all experts are painting their Arado Ar196 in the same way.
Yves
If you are concerned about it Smore the very bottom of the pontoons would be the same color as the bottom of the plane and it shows in the pic look at the forward part of the back pontoon and the piece jutting out the bottom of the front pontoon at the rear.Camo. ;)
I have been enjoying your build log immensely. I really like your high end glue applicator😋
Thanks for sharing.
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
On 2/17/2019 at 5:18 AM, semorebutts said:
I finished the rigging.  I didnt want to go to crazy so I kept the rigging lite.
5C65E2F8-9701-4B69-B9E2-A14EFF327D01.thumb.jpeg.91a2fe278c49d92c561458adba7ee968.jpegE307EAAD-8D71-445A-B787-122647707B67.thumb.jpeg.975b657874671208f6f23ed8eb61fd12.jpegE52DAF6A-CFB7-4136-878B-6ACC9D5F0DE3.thumb.jpeg.98e4444e3877cc2a436873def3d1c7c5.jpeg
then i started painting the arado.  The first coat is down.  I used model air paints.  Definitely different than tamiya.
43D0B495-5AF9-40DB-86F1-D815B6D1C4A9.thumb.jpeg.e4c32beb5864c32c2ca6869d409a0607.jpegF1E54D78-3E13-4D2A-93B3-F6923A68948D.thumb.jpeg.138ed7108f0e8ed29697b2fafefd5881.jpegDE190BA3-8DCE-42DD-8DE4-30404FA4B135.thumb.jpeg.24f1dbb1282842aef5c1165e9f50c6a5.jpeg1DD6CDD0-DD6C-4A38-8BB9-C6FA64F059DF.thumb.jpeg.6b001db460aaaab8e1523018d6b4bbed.jpeg
Hi Great build, are you going to use white glue to have clear canopies?
It’s been very fun guys!  I almost have everything I need to start the missouri so hopefully in a week I will be starting that.
To close out this build I  I wanted a better camera than my iPhone. unfortunately I had no luck so here are photos of my finished Bismarck with my camera phone, crappy lighting and terrible background.
Also I don’t know how to put the word “finished” in the title of this build log...😕
5B755438-2EEF-4FAC-A0D4-58DC1B8F2345.thumb.jpeg.250a06a70a22d6979e0c7e09be410d87.jpeg5B9423B3-451E-44B8-AB69-96CC0233D82D.thumb.jpeg.1ef325ba0f61e54d472d9f9967980122.jpegEE8FF9D7-4904-4A7E-99CF-60BD2F7FBD05.thumb.jpeg.17313ef79888efe60884dc1ade9baafe.jpeg8EEECD4B-5219-4EE3-8D42-7C1183FAF711.thumb.jpeg.088feea8ea852805cd5ababae2ba75bd.jpegF5967B93-B2E6-451F-8DCF-F7E03C8E17B7.thumb.jpeg.ce787b9437a1a444348a439267963cc0.jpegDCE514CC-44EF-48D9-96F4-8431A4B321BA.thumb.jpeg.1071cdcb51c21fb0227e5b651cb09dbb.jpegDCE514CC-44EF-48D9-96F4-8431A4B321BA.thumb.jpeg.1071cdcb51c21fb0227e5b651cb09dbb.jpegEE490FD9-93A3-4561-9892-E8801D71D4C1.thumb.jpeg.a9bc827a0940d13aeeec55147ad85c28.jpeg
Haha there is a piece of rigging near the funnel I didn't snip off yet  9C213AF7-EA50-4430-A67A-2B45BEEC7D8B.thumb.jpeg.a16524a1b47624fda7e34dd2f6afd028.jpeg75EA31F3-7889-43E4-B127-916683B82581.thumb.jpeg.c0cf3528c16122d98c954ca6981c2163.jpeg1F9F39D6-9C85-4CED-A9BB-AF477C8DB523.thumb.jpeg.7f3fe0eb87d372ae1052c414a90f2282.jpegDD393EE6-AC3E-449A-B3EA-01BDFF433663.thumb.jpeg.8ace56531c0ce3ebf423db7554902dcc.jpeg42DEC2F3-0BDE-410E-88F2-05D57E3551B3.thumb.jpeg.5045c533d460374bca6fa325b639ed88.jpegB6976F86-19A5-4C5C-84E3-BA2E0F1B3925.thumb.jpeg.fad7e316f8f24d6befd469658368dfe2.jpegECF4A800-5DB7-47E3-BDE2-9DEB866DEBD9.thumb.jpeg.cf28f6b48b53c247d635702fa8e9e433.jpeg6D755170-C7CC-4CD5-98E8-6742829978E6.thumb.jpeg.db3c819d6cda6408a1b80b19e87552c5.jpegFA3D4E59-78BE-469A-90AD-04A727F5DC82.thumb.jpeg.18cf9aff78816faf3c874bfe23f1510e.jpeg4149E567-C86B-4E31-BEB3-06E323D0FED3.thumb.jpeg.69c6a3819b8e0ef5cb1e1208e6c8cfd5.jpeg93ED2DE4-B78A-42ED-90CB-47FC9AC5EA9F.thumb.jpeg.a6fc7cdf2aaaf965744c65f185d8fb8d.jpeg6B414F32-1BC0-4045-8DF8-5901D7B9FE15.thumb.jpeg.6fe01dee549a2223030370dec8835157.jpeg88E3417C-6864-4C27-972F-15AD787ABE52.thumb.jpeg.f66b7aaf5ae73bbd25b0cc76fa4ef212.jpegB4193A1A-54AE-4ABE-BEDF-989624041DCE.thumb.jpeg.43d5e8e53ff49b7bad233696ec26bafe.jpeg2CF03467-D121-4A4F-A1C2-DDBDA8957303.thumb.jpeg.8151f1d4a8566c6f7dc5b61169d2d7fc.jpeg
Well done she is looking Superb  what a credit she is to you,   I agree about the mobile phones using them for a camera  - If you use them for close up work they can be really good  - they do need a certain technique though  - basically  tolding them really still,   all my pics are with my old 20 yr old mobile phone.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
That’s an awesome piece of art. Really great work- it’s been a pleasure following the progress. Can’t wait to see Mighty Mo!
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
It's been great following your build and seeing a masterpiece come together. Congratulations on your superb rendition.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Looks great, Semorebutts....     I changed the title for you.    If you need to do it on another project, open the very first post and scroll to the bottom of it.  Hit "edit" and you'll see that the title can be changed.
