Ciao e grazie a tutti, siete tutti molto gentili, queste ultime coste sono abbastanza difficili da realizzare perché ho pochi punti di riferimento, infatti queste coste non sono disegnate.
Hello and thank you all, you are all very kind, these last coasts are quite difficult to achieve because I have few landmarks, in fact these coasts are not drawn.
Un Saluto
Beautiful, precise framing. Very well done, Daniel.
Excellent work Daniel,
its a pleasure to watch this model grow !!
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice indeed, are you still using walnut wood for nailing, and what's the thickness?
Ciao, grazie Dirk e Luc, stò utilizzando il legno di noce per la chiodatura in tutte e due i lati della costa, per simulare un perno passante, lo spessore è di 0,5mm. nella realtà 24mm. circa.
Un Saluto.
Hi, thanks Dirk and Luc, I'm using the walnut wood for nailing on both sides of the coast, to simulate a through pin, the thickness is 0.5mm. in reality 24mm. about.
Greetings.
I assume you must mark the positions of the drainage holes very carefully before cutting them off the model! Beautiful work, Daniel.
On 8/2/2018 at 7:38 AM, Forlani daniel said:
Hello everyone, this is the system I adopted to paste the various pieces of the coast.
    That is an ingenious little clamping system you've got there for making your frames!  And while most people using those layout forms actually try to cut notches for the frames, you just use spacer blocks.  It appears that by leaving the smooth curve of the hull form intact makes it easier to get your frames to also remain aligned in a smooth curve.  Smart! :imNotWorthy:
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Hello Daniel, I just found your build. What a superb job you are doing, I am inspired by the way you are able to use manual control on your mill to create a curve, I know that it is not easy to do. Your assembly of the frames looks like a very good way to clamp them. The exploded view of the successively smaller frames for the bow is almost like an installation sculpture. beautifully executed wood work. I shall continue to follow along.
Michael
Wundebar Daniel, !!
Nils
Current builds
-Lightship Elbe 1
Completed
