Awesome modeling Toni,
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Now that should ring everyone's chimes.  Looks like an English bell and not a Tibetan bell.    :)
Thank you everyone for the nice comments and thanks for the likes.  Now it is on to the quarter deck framing.
Toni
Member IPMS
                           Utrecht-1742
  • 5 weeks later...
I cannot believe it has been so long since I posted.  Amazing how life gets in the way.  I was finally able to get some work done this weekend.
There is an iron knee connecting the transom with the inside of the hull.  This is not a simple "L" shape.  It needs to twist inferiorly to clear the undersurface of the quarterdeck half-beam. I made the knee out of castello and then painted it black.  There is nothing unusual in the construction of the quarterdeck.  There are no stanchions.  The only carlings are related to the capstan step and the deck fenestrations.  I find it easier to begin aft and work forward (ie narrow to wide) for better access.  There are hanging and lodging knees for each beam except there is no hanging knee at beam 14 as this would have interfered with the quarter light.
The framing above the sternpost appears to be at a different angle than the rest of the deck in the last picture. This is an optical illusion.  The plans show the bulkhead on the fore side of the beam, not underneath.  Because this is a laminated structure I glued a thin shim on top so it would look neater.
Toni
Member IPMS
                           Utrecht-1742
Beautiful work, Toni.  The bulkhead partition looks great in place.
Thank you gentlemen and thanks for all the likes.  I hope to get a few more beams in place this weekend.
Toni
Member IPMS
                           Utrecht-1742
It is hard to believe that it has been over a month since my last update.  Work on the quarter deck beams has been progressing very slowly but I hope to have them completed within the week.   The pictures were taken before any finish sanding.
Toni
Member IPMS
                           Utrecht-1742
Thanks for rubbing it in, Greg.  I'll bet they look almost as good as yours!
Toni
Member IPMS
                           Utrecht-1742
A nice way to close one and open another year Toni, nice progress and the beams look good even without sanding.  Always send a bore scope down to look at those details ;):)
cheers
Pat
Edited by BANYAN
Adding the quarter deck beams makes your model look much closer to finished - assuming you are not going to spar her! Looks great, Toni.
Happy New Year's to everyone.  Brian, I am using mica for my windows.  Pat, I actually have put flexible scopes into the hold.  There is a lot of sawdust down there!  Druxey, the closest I would get to spars would be stub masts.  I find rigging horribly tedious.
Toni
Member IPMS
                           Utrecht-1742
