Thanks to all ☺️, the hinges are soldered with tin, therefore, soft soldering, I found a suitable tube, but I think I will redo them, as they are a bit big, the doors I made them as in reality, with uprights in which I practiced the mortises, the crossbars in which I made the tenons, the lower drafts, which fit into a groove, and the irons, wedged between the crossbars
Tiziano
The use of two slightly different shades of wood is brilliant as it shows off how well you did the joinery.  Did you use two different species of wood or pieces of the same species from different billets, or???    Thanks
Allan
2 hours ago, allanyed said:
Non vedo l'ora di attraccare a La Spezia a settembre e spero di incontrarti di persona e vedere questo modello da vicino e di persona. Ti mando un PM mentre ci avviciniamo per vedere se possiamo incontrarci.
Ciao
Allan
Off corse, Allan🙂
Look at you two, showing off your fancy nautical terminology! Are the hammock battens the sawtooth things that look like they are for making a grating?
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
Indeed, they are.  :D
JD,  they are a pain in the neck to make and glue/pin into the side of the deck beams, but look great if well done.  If you leave off a few pieces of deck planking you can hang a few hammocks secured to the battens (and sleeping sailors) so they can be seen.  Lavery has about a page and a half of text and layouts of hammocks on pages 180-181 in The Arming and Fitting of English Ships of War.  One of the drawings of the  lower deck of HMS Bedford 1775 can be seen in low res on the RMG collections site as well.   https://www.rmg.co.uk/collections/objects/rmgc-object-86584
Allan
Wow. Guess I just gotta keep on learnin'.
JD
JD
stunning work
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
