The biggest lesson that this forum has taught me is that each of us, regardless of level, is working hard at every detail. Even if we don’t see it in the end, taking things seriously is something we have to stick with. So I slowed down the shooting and tried to make the details as perfect as possible. Thank you for your support and attention to my friends!
One of our members whom I haven't seen posting of late has this for his signature: "Do each piece as a model and at the end of the day, you have created more models than many do in a lifetime.".   I may not have it correct but it has the thought.
On 8/31/2021 at 3:26 PM, bitao said:
I'm tired of sawing and sanding wood. I'll do some outfitting for a change. Start with the metal boiler. As long as the size of the parts and drawings accurately match, will not be affected by the hull deviation. The drawings are 1:36 and must be converted to 1:60(60% of the drawing size) before being made. In order to beautiful and firm, the main body using block copper milling processing, the basic use of riveting parts. The utility model avoids the unsightedness of the welding and the unsteadiness of the adhesive. The precision of machining is required higher.
Hello,
sehr gute Arbeit. Top.
Karl
Sensational joinery; your attention to detail and the quality of your work is outstanding.
cheers
Pat
 Beautiful.
bibito and all other friends
Where can I purchase the important measuring and marking instrument you use. And whether there is a drawing and preparation instructions for those who wish to produce it independently. Thanks
The measuring tool pictured should not be hard to find online. Just to accommodate the construction of the hull, most of them have been modified and re-processed by me.
To complete the construction of the bottom of the hull. Get ready to move to the next level, because some of the parts need the upper beams to be positioned, so parts of the structure need to be pushed back.Thank you for your attention
  Man - I just love stumbling across new builds that I have not seen before and being treated to elegant work such as this.  So precise - really great stuff!
18 minutes ago, Alex M said:
Hello Bitao,
just readed you build log for first time... I'm out of words. It is really incredible!
Alex
Where you been Alex? The rest of us have been mesmerized by this log for months!
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
