Macchi C.200 Saetta by ccoyle - FINISHED - Modelarstwo Kartonowe - 1/33 - CARD
I am making agonizingly slow progress on this model, literally a couple of parts here and there every couple of days -- really having to push through on this one.
In the meantime, I pulled the trigger on purchasing two additional Halinski kits to add to my stash, a Kawanishi N1K2-J Shiden-Kai (George) and a Messerschmitt Bf-109E-7/Trop. Both kits have been sold out at Halinski's web site for ages, and I have been scouring the internet off and on for a couple of years now in search of the N1K2-J. I knew of one web site that had that kit, but their shipping charges are astronomical, so I held out while looking for a cheaper source -- never did find one. When I recently saw that the expensive shop still has a copy, I decided to order it in spite of the stiff shipping charge. I added the 109E-7 to defray some of the cost and added laser-cut frames and a canopy to complete the deal (the site didn't have those items for the Kawanishi, but Halinski still has them). Let the waiting begin . . .
I'm hating this model at the moment. I'm not hating the subject -- the subject is fine, and the artwork is lovely. No, what I don't like at the moment is the design of the kit and its very apparent shortcomings.
As you may recall, I have been slowly working on the landing gear, which have some very tricky and delicate parts. I got those bits done -- not great results, but at least they're done. Then came the gear doors. First we have the brackets that mount the doors to the struts. There are three of them, and they're all labeled as part 62. Not 62a, 62b, and 62c -- just 62. And there is no way to easily tell from the diagrams which order they're supposed to go in from top to bottom. I made an educated guess, and I don't think I guessed correctly.
Next we have the landing gear diagrams. This frontal view shows the main gear door reaching up to about 2 mm shy of the wing.
Yeah, about that . . .
Yep, that's closer to being a 10 mm gap. Some more surgery is in order. 😑
What's really annoying about this is that this is the third Marek Paczynski design I have attempted, and every one of them has had design issues (one proved unbuildable). Worryingly, I have a bunch more Paczynski designs in the stash. 😒 But, I will press on with this one, since it is so close to being done.
Stay tuned!
I hope that carrying on goes well, Chris.  I'd hate to hear you had a massive bonfire of those kits.
I wish I could make bad models look so good as you do Chris. My one and only card model experience was with what I feel was a poor design, but it's probably more the fault of the modeler in my case than it was the kit. I dropped mine into the bin and counted it up as a learning experience. Looks to me like you're going to wind up with a fine-looking model on your shelf due to your skills to make a silk purse of a sow's ear.
Wow. In doing more online research regarding the landing gear, I have become even more mortified about this kit's design. Not only are the gear doors not the right length, it turns out they are not the correct shape, either. On top of that, the torque bars are wrong as well -- the kit places them on the front of each strut, but pictures of the actual plane online show them on the back. 😑😑😑
Ignorance would have been bliss in this case.
EDIT: Just discovered that the locator marks for the door brackets are not in the correct locations and do not match what is shown in the diagrams.
Since the gear design is obviously a complete cluster-you-know-what, I'm just going to slap the main doors on and call them done.
59 minutes ago, Javlin said:
Looks like you overcame and persevered Chris looking mighty good from here!!
Ah, but the trials just keep on giving! Turns out the propeller is also wrong, based on a thorough internet search for photographic references. Of course, the designer doesn't mention (well, maybe he did, but it's all in Polish) what he used for source material and where he obtained it. So, I will be making some alterations to the propeller structure as well. Happily, it is the last major assembly, so after this it should be smooth sailing.
The Big Reveal!
So, after finishing the propeller, which differs significantly from the kit version, there remained only the venturi, pitot tubes, and antenna mast. Glad to be done with this one. Enjoy the pictures!
Great build Chris, it looks great and the kit deficiencies you highlighted do not detract from your skills in building it. :champagne:
Andrew
Completed (Kits):-
Superb finish   Chris   - Top Notch  build.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hard to believe this is card.  Wonderful build, Chris.
Difficult subject. very well done...
Nice job Chris... It's the difficult ones that are most impressive....
And this one impresses...
Quote:
Despite all the problems, it turned out a great model. It looks to me every inch like a MC 200.
Congratulations,
Dan
