Sweet work on the bollards.  Even partials aren't that easy and you did them well.
Thanks Bob and Mark and everyone for all the likes!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hi All,
The framing of the gun ports is moving along nicely and one pleasant thing I learned was that
there are no sweep ports to worry about.
A batten strip was pinned to the bulwarks at the previously marked reference lines and a smooth
run was established. I then marked the bulkheads for the final placement of the sills. The sill and
lintels were cut from boxwood.
At the bow the bridle port fell over a bulkhead and the bulkhead had to be cut away prior to framing it.
To add the lintels a piece was cut at the correct height and long enough to sit on both sills this
gave a consistent height and eliminated the need to measure each one.
I have done the preliminary sanding to the out board side.
On to the transom soon!
Rusty
I'm starting to see the sheer line.  Glad to see the old spacer stick in play.
No sweep ports !!!!  Is nothing sacred????
Looking great!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Outstanding work and great build log. You are making it easy to follow and are doing a great job of describing what you are doing with both text and pictures. I can't wait for Chucks book and plans to be available.
Al D.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Hi Chuck, Not gonna happen. The planking of the hull will take a loooooong long time if
I hope to come even close to your work..
Thanks Augie. They are so much fun aren't they!
Thanks Mike and Ben.
Thank you Al D. The practicum and plans are outstanding. You will love it.
Hi Bob, The pleasure is all mine.
Ok I've squirreled myself away most of the last few days and have made a good deal of progress.
Here is a picture of the plans depicting the stern framing.
There are eight stern frame sections  that fit into the slotted bulkhead section.
The next step was to add the sills for the stern lights and the lintel filler pieces above
them. I used both the plans and the transom cut out to alien everything.
In case you can't tell I'm having a ball here! :)
Once it all dried the stern was sanded smooth. I then added framing the quarter
gallery entrance and the aft-most gun port.
Rusty
Hi Rusty
Wow this is nice! For a journey into scratch this or Chuck's Cheerful is my choice (I have plenty to do while I wait). Great build and a stunning ship.
Cheers
Alistair
Current Build -
Very nice Rusty. It's such a shame that you're not having any fun at all! ;)
Thank you all for the likes. I see that you are all "liking" it as much as I am! ;)
aliluke, It is a great adventure into scratch building. The Cheerful looks like a wonderful
project too and that will be a build waaaaay down the road for me too.
Hi Bob, and I always look forward to your posts my friend.
Hi Grant yes it is such a shame that I have to toil away at this day after boring day. :D
Alright then. On to the hance pieces. These were cut from boxwood and are oversized
width wise. Once glued in place they were faired to match the hull lines. I have only
faired the outboard portion of the hull at this point.
To give you an idea of the length of the practicum this completes the third chapter.
In the forth chapter I will be planking the hull from the wales upward.
Rusty
Thanks Dirk.
Hi Ben, Yep I'll probably be able to start laying some planks after I get back from the CT conference. :)
The first step in chapter 4 is to plank the lower counter. I used boxwood strips for this.
The method Chuck describes has the planks wet in water for about 15-20 seconds and
then edge bent and clamped. I probably soaked them for about 45 seconds. A hair dyer
was purloined from the admiral and using the hottest setting the planks were dried. Once
they cooled they were removed from the clamps and there was little spring back.
Here is the counter planked. The outer edges still need to be faired.
Rusty
Now Grant, that is an invitation to much innuendo :) - sure is better than looking at the south end of a north bound camel though! ;)
Oh by the way Rusty, very nice planking; the boxwood looks great!
cheers
Pat
Edited by BANYAN
Beautiful work Rusty. Glad your having fun. Just think you will be using the lathe soon to make all the cannon's. just think of the fun and mess your going to have.
Wacko
Joe :D
Go MSW :) :)
Thanks Augie, It will be fun to see everyone again.
Yer scarin me Grant! :o  :D
Hi Pat. Although I haven't seen the South end of a North bound camel it brings images to mind that make me shudder. ;)
Hi Joe, The build and lathe are both a lot of fun.
Hi Dirk, Please don't ever hesitate to add a comment critiquing or questioning my work. That's what this is all about. :)
I believe you are commenting on the evenness of the curved pieces using the clamps. I failed to say a couple of pieces
did not make the grade and were tossed. That was the only picture I took. Once the pieces were bent to their shape the
first one was placed and matched the exact curve of the stern framing pieces. It had to be flexed about a 1/32" to match
the curve. The rest of the pieces were then placed to follow that curve. When I do this again I will cut a template and
bend to conform to it. It would sure save on the waste as well as being more even.
Rusty
Hey Ben, 260 miles vs 910 was the determining factor. If I could swing both I sure would! :P
Rusty
Now it is time to add the fixed blocks to the outside of the hull. These blocks are simulated
and do not pass all the way through the hull. A small hole was drilled at each end and then
the center cut out to make the sheave slot. A small piece of wood was then fit into the slot
with a groove cut into it to simulate the sheave. The blocks are then placed against the hull,
the sheave hole position was marked and then the hole was drilled through the hull. This will
ensure proper alignment when placing the inner block later on.
The gun port opening have their first coat of paint applied and you can also see the batten strip
attached to the hull marking the location of the first row of planking.
Rusty
Rusty you make me want the book for this model even more. As usual Chuck has made the idea of scratch building seem possible. I also wonder how much of this is due to your skill?
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Thanks all for the likes.
Hi Floyd, Chuck is making me look good not the other way around. Any kit that has Chucks plans and instructions
(Syren & Confederacy) could become a scratch build. They are that good. I'm sure that if someone has a couple of
models under their belt they could build the Winnie too!
Hi Augie, That is the same red I used for the Confederacy. It is Red Ochre from Admiralty Paints.
Thanks again all!
Rusty
Rusty, I have not said alot but have been following your build with much interest. I have to say it is a very nicely done build and I always enjoy following someone like you. Thanks for sharing.
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Thanks Bob. Ah the planking. That is going to be one of love hate relationships I'm afraid.
Hi Pete, Thanks for stopping by and it's always nice to hear from you.
Well I'm sure you can tell I've been away for a few days and also busy now that spring has
finally decided to show up. I was cleaning the workshop in preparation of starting the planking
when I sucked a bit up. So I figured it was a good time to see how my experiment was going.
Back on MSW 1.0 Elia mentioned that he had a Oneida Systems Dust Deputy  hooked up to his
vacuum and it worked well separating the dust and wood pieces and keeping them from clogging
the vacuums filter.
So this past Christmas the Admiral got the Dust Deputy for me and I hooked it up in early January.
Usually after a month's worth of heavy cutting and sanding I have to clean my filter as I start losing
suction.  It's now been 4 full months and no loss of suction. I took it apart and measured a little over
7 inches of saw dust and debris in the bucket. I opened the shop vac and there was almost nothing
in it. I took the filter off and there was just a thin layer of dust on it that I blew off and it was as good
as new.
 Now I have no interest in this company but if you have clogging issues like I did I recommend giving it a try. http://www.oneida-air.com
Ok the shop is clean and it's supposed to rain Thursday and Friday so hopefully I'll get some shop time!
Rusty
