The thing that I do like about this scale is the many options for experimenting with processes. Today I made a small form for making the dorade vents and used some .003" brass shim stock to see how easy the shape would be to replicate. here are the results.
The first annealing
second annealing
After 4 more annealing s
it was looking promising
A bit more trimming with some small scissors and a dab of paints
So now I know that they are possible I think some heavier shim-stock say 006 or 008 might be better then some proper patina.
Michael
The advantage we have with this scale ... you experiment a lot! I love this build log, from start to finish it has been one big lurning curve for me, thanks for that.
Back to business at hand, doesn't the brass get rather weak when annealing? Wouldn't "tapping" it into shape keep it stronger? It turned out real good though!
Carl
Carl the process of annealing allows the metal to stretch as it stretches it work hardens and so each time it is annealed it allows for a bit more stretching. I would not be able to form the brass or copper into such an intricate shape without the annealing.
Michael
But there is a distinct difference between iron and brass annealing, I suddenly realise that iron hardens when cooled down, whilst brass doesn't. My mistake
Carl
Thanks for all the likes and fine comments. A bit more work today first order was to make a couple of left and right Dorade vent forms first a 3/4 diameter end mill then into the side with a 5/16 these were then cut to create the right and left sides.
Switching gears to the companionway the side panels needed to join with the front and rear cross panels, for this i chose dovetails the same as the skylight.
The initial cuts for the pins were done with the small back saw and the jewelers saw.
Next they were clamped in the vice with some tool steel guides
and cleaned up with a few files.
Then the pins were transferred to the sides and the dovetails marked and cut with the jewelers saw and cleaned up with the files. the front panel required the most dovetails. you can see the primary vent forms in the background I worked on the starboard form first using some .008" brass and also made a domed plug from maple to assist with forming the main bowl section.
Here is a shot of the companionway dry assembled with a scrap panel to see how the new vent looks.
It is much more durable in the thicker brass, but I think I need to work the form a bit more, the tube section down to the box will need to be opened up a bit to form a better flow it looks a bit restricted. I will also keep it polished.
Michael
Thanks Bedford.
Here is a shot of the progression of the vent.
I have been working on the structure of the companionway it is basically dry assembled at the moment.
I keep leaving the card on the top, because I actually like the contrast between it and the sides.
Michael
Hi Michael,
the result on the vents is very good, & I've learned something new from this.
On the companionway top colour: I feel that having a different colour to the top (from the sides colour) lowers the apparent height of the overall structure, which in most cases looks better on a boat as it elongates the overall lines. I also feel that a paler colour makes it look a bit wider than with a darker colour, so again I feel that it looks better.
Hi Mark I am firming up my thoughts and a white top will likely be the final choice, with a canvas type texture.
Here are a couple of views of the companionway glued up with the solid panels that will be installed closer to the finish.IMG_0100x1024.jpg.51d8093eadc95a3e5ec08cf207d4652b.jpg
I am now shaping the cross members to get ready for the fixed portion of the top. I still need to cut the channels for the slide on the hatch.
I have been out sailing for the past few days, with Maria.
Michael
Mark I am not quite sure what you mean, but here is a recent shot taken by one of the club members.
Also I made a new set of Dacron sails from some old sails that were given to me. What a difference in light airs The ten oz canvas ones are good for strong winds but are not good in light air.
Michael
Cheating on Judy taking a damsel out "boating" ;)
There is time enough this winter to continue on your build, Michael. When I see the weather at your side, I would be doing the same if I had the oportunity. Enjoy while it lasts!
Cheers
Carl
catching up on your progress Michael...........the parts you create always amazes me.   such wonderful work!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Back to the build. Thanks for all the fine comments.
I have done a little more work on the companionway adding the slide track and rough fitted the solid roof section.
Once the companionway is basically assembled, only three more dorade vents to form. The next step will be to cut the openings in the removable deck section then it will be ready for the structure and decking.
Michael
Oh Brian you have outed me, I have known this all along and the personal name for this cutter in all my files is Kingfisher The Model Maker plans also call this boat Kingfisher There are a few other pictures of CK482 which I have in my files but I am unable to share them because I do not have the source.
There is another model on this forum with this name so I did not want to put up this name, also I only used the basic bulkhead lines from the MM plans and then developed my own, and drew upon the general fleet for other details. I have copies of the Stone plans that are available for download on the "smackdock" here is another one that would make a great model it is called "pioneer" and another one from the register "Maria"
I really like these boats. I am glad that there is a resurgence in restoring and preserving these vessels.
Michael
A small update, I have started to reinforce the opening in the deck for the new removable companionway and skylight section.
and while waiting for the glue to dry I made a few more studs for the cradle structure these are 2x56 threads and steel nuts with brass studs.
Michael
Well now I have a bit more room
Kingfisher is back to center stage at last.
Today I will finish off the bolts in the proper cradle, I had to lower the topmast because the long table that Albertic was occupying is about 5 inches higher, but that is OK for the moment. And I fixed my chiming mantle clock, I had missed it's sweet sound.
Michael
Thank you all for the wonderful support.
Today I finished the pivoting cradle supports for the bow, it seemed like a lot of time to just make a few studs, bolts, and the pads.
I used a thinner foam pad for the bow pads
I just need to add a couple of chocks each side of the keel now to lock it in place from moving side to side.
Michael
PS it is snowing again!!!
Hello Mark,
The cabin cruiser on the lower level is this one
I was warned about not starting another project until I had finished some that are still being worked on. But you know how that works 😀
Michael
