HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Thank you Frank!
On the last picture one can see something, that I was bothering about since some time.
The monogram appears sitting quite thickly on the barrel. I already used the thinnest material available from my supplier, 0,2 mm equals 2 cm in original. The original monogram is about 5 to 10 mm mm but has much more washed outlines.
Time to tinker a bit and to see what still is possible :-)
Two versions were spooking around my wired minds for some time - lets go for the phantoms :-)
Version 1 sinking the monograms with a soldering iron.
Worked surprisingly well, it was quite easy to sink it evenly ...
... until I saw the bulges of diplaced material all around. Difficult to take out, ok forget it.
Version 2 were thin castings, like those I do successfully for the coat of arms of the entry port.
Took two monograms and hammered them into the poly ...
... casted twice ...
... but missing a good form success was not coming. Some carvings of the form did not help.
Then came version 3, gluing the monograms and filing the edges off.
Looked great without color but with color splashed over ...
... merda ...
Ok trial number 4:
Took a monogram and sank it by half into a poly ...
... broke it out ...
... and took the poly as holder to file down the backsides of the monograms down to half ...
... and bingo :-)
Some other side theaters of war ...
... rolled the wire for the thread rod with the filr to give it some structure ...
... and carved the bearings of the trunnion out of Evergreen.
On the last picture one can see that the sliding part has to slide over the mounts of the wheels, so it means, they have to be flush in the surface.
So marked the position on the circle ...
... and used a dummy for testing. First drilled a basic hole ...
... ground a old scalpel into shape ...
... and formed the drilled hole.
And the trials shows that it fits :-)
So assembled the carriage and barrel, splashed some paint onto it, fitted the appropriate eyebolts and it looks ok ;-)
Old and new side by side ...
... old - once state of the art -  ...
... and a bit pimped ...
... and it seems quite ok :-)
XXXDAn
Uh-oh... a new reality TV show... Pimp my Carronades!!!   They do look super nice, Daniel.  Congratulations.
Ok trial number 4:
... and bingo :-)
XXXDAn
Just a quick query about the monogram. Would not nori glue have held it in place while fileing then just release the thinned monogram quick wash and stick it on the coronade, or would that not be strong enough? Only as of yet I've no materials to embed the monograms into. Also if nori is too weak what about CA with the usual acetone to un glue it. Would that work do you think?
Ongoing builds,
SCutty Sark Revell 1/350 (Mini Nannie)
Cutty Sark Airfix 1/130 (Big Sis)
Will (Everard) Billings 1/65 but with wooden bottom, because I can
They look awesome Daniel.
Current Build: Merit 1/48 Early Eco 80' PT Boat and Imai 1/50 Catalan Ship
Revell 1/196 USS Constitution (My oldest son's school project)
Revell 1/72 Hanse Kogge
Revell 1/50 Viking Ship
Revell 1/72 U-Boat
Zvezda 1/72 English Medieval Ship Thomas
Revell 1/90 The Nina
Thank you all for comments and likes!
Izzy, I do not know about nori glue, but to file the material, I think most glues are not strong enough.
The material I embedded the monogrum upside down is a normal plastic card/sheet, standard material.
To make sure, I only sink in one monogram, which will be destroied by taking it out again. But it leaves a wonderful form for the other ones to be held in - just place the monogram upside down in the form, no glue required, just filing slowly and carefully :-)
Cheers, DAniel
Cheers, DAniel
Hi,
Nori is a glue used by samurai sword sheath makers. It's used because it set solid like epoxy but dissolves in water as its starch based. I've used it when making watch glass replacement and needed to be able to file from any angle. I usually used Perspex for the glass so I would imagine of similar hardness but I never had anything move until soaked to remove it. And it's very readily available as its made from over boiled rice..
And if you always filed towards the edge as apposed to away then the CA should hold it if your substrate is rough enough. And loctite thread lock would grip brilliantly and a bottle would last years. And even more so if it's none ferrous metal as there is a chemical reaction between the glue and metal. That a lot of engineers haven't realised as they always seem to use the thread locks etc which are CA based on metal so don't experience the difference especially in curing times.
Slight side issue I've had loctite thread lock and other liquids by them that in them selves won't set even after several days, add a few grains of none ferrous metal and instantly a disc 5mm x 40mm sets solid.
Ongoing builds,
awesome Daniel..........never a dull moment at your table!  such wonderful detail.........really....really nice!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Sirs.
Slow tinkering ahead ...
... creating more questions  ...
... in the front the movement is limited by the eye bolts ...
... but in the back is the question how much overhang there was.
Where was the limitation by the breeching rope?
Sideways there were the wheels ...
... but interestingly all the contemporary drawing show a round bolt to hold the sled, possibly allowing a side turn, no second guide to be seen.
Was this actually done.
Ok, lets go for the trials ...
... made some timberheads ...
... the half circle was still moved as the timberheads were too far apart.
Just for the model, I used a second guide ...
... and a breeching rope of 20 feet as this was indicated for 32 pounders.
Fixed it gives a realistic looking overhang ...
... while in the front ...
... the radius is surprisingly limited.
Cheers, Daniel
[quote name="dafi" post="298857"
Cheers, Daniel
Sorry to be going somewhat off subject. But looking at your excellent trials. I'm still troubled by the use of the screw for height adjustment. In one of your earlier pictures I think. You show both the wedge and the screw. Which I can understand. The screw gives the adjustment but the wedge takes the force.
But without the wedge how you have it rigged. Which I'm not doubting for a moment. But basic physics shows that the rope is going to want to end up straight. To do that the back end is going to be dragged down onto the screw as well as back which would give you a one shot deal as the screw would just embed itself in the carrige.
So my wondering is while the use of screw or wedge for aiming was upto the individual captains. Was it a case of at the actual firing that the wedge was always put inas that would then take the full force of the recoil. Leaving the screw safe?
Would not the screw be easier to turn with an eye loop at the top for turning?
Just speculation and not intended as any sort of knock or slur. But just a query of greater knowledge against pure guesswork.
Edited by Izzy Madd
Ongoing builds,
"... hot deal as the screw would just embed itself in the carrige. "
That is why there is a metal plate underneath the screw.
But that was my same question about the help of the wedge to ease the strain on the screw.
See more here:
http://modelshipworld.com/index.php/topic/10035-thinking-things-throu-carronade-carriages/
XXXDAn
Edited by dafi
Still had some more rounds in the NMM, checked all available carronades, found them all different, but found some similarities.
- The bolt of the lower part as near to the wall as possible, gives 2mm
- Shortened the front of the sled gives 1,5 mm
- makes 3,5 mm :-)
- no feed for higher flor plate
Ok let´s go for the infamous Texas carronades massacre ...
... new hole in the floor plate, new bolt on the lower part and shortened sled ...
... pushed back ...
... and now fits in the front ...
... also the radius fits much better :-)
Have to admid the timberheads being quite close to each other.
Now still is the mystery of the turning sled ...
... but I am sure we will find that out ;-)
XXXDAn
And what would be a successful tinkering weekend without decent damage reports ...
Adaptations on the second carriage ...
... together with the almost oob version.
And then reworking carriage 1 ...
XXXDAn
... meanwhile preparing big things ...
... the resin saw found a new duty :-)
Hooked in the pulleys ...
... using some brown yarn to keep things together.
And then the great moment ...
... down the ties ...
... but the big question is still to come ...
XXXDAn
Edited by dafi
... Pandora´s box is slowly opening ...
XXXDan
a very neat diorama kit.........I like how you did this  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanx Dave !
Hello Popeye, quite easy - just draw the box open ;-)
XXXDAn
... and here it comes, the final question of great fascinating weekend quiz:
Can you recite the dialog of these pictures??
...hihihihihihihihi...
XXXDAn
Thank you for the replies ...
... but I am getting desperate ...
... heave ...
... was mixing so long to get the color of that fancy hat right ...
... heave ...
... I tell you he´s got us lost ...
... heave ...
XXXDAn
Edited by dafi
Hyho - one german forum already solved the mystery! Do not stay behind, you have a reputation to defend ;-)
... heave ...
... five years hard labor, the judge said to me, or honorable service in His Majesty´s Navy.
... heave ...
XXXDAn
Edited by dafi
The gentleman with the blue jacket... "here, use a bigger hammer."
... heave ...
... five years hard labor, the judge said to me, or honorable service in His Majesty´s Navy.  What did I pick? ...
... heave ...
... What are we doing in the pacific anyway? I tell you, he´s got us lost.
... heave ...
XXXDAn
Edited by dafi
I'm beginning to wonder if this dialogue has something to do with the man with the black beret (or hair?) and tiger camouflage shirt...?  HIs clothing seems totally out of place.
