I didn't hear anyone offer to pay for wood, and If you're not getting paid, is it really work?
Bob
True...no mention of money. But, let's not get philosophical...   :P
Edited by mtaylor
let's see.........you make the wood for yourself..........some one likes it and you make some for him......but you don't get paid....hmmmmm sounds like a sub-phylum from the original hobby ***********************************wait for it**************************that would make you a pl-anthropist!  :D  :D
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
LOL!!!   :D  :D  :D
GEORGE
Update.. we ain't dead in the water yet..!!!
After milling my wood, I spent a fair amount of time sorting out how to put this together.. the wales.  There's 12 strakes that start off a 3/32" thick and as they go down to the main hull planking, they thin to 1/16" which is the "normal" planking thickness.  Above the main wales, the upper works planking is 1/32" thick.
After much experimentation and sorting things out, my approach is below.
First two pics are how I clamp things down...
This one shows the actual planking...  hang with me, there's issues that I know have to be resolved due to some gaps.
1) is the second strake of wales. Solid swiss pear.
2) is the underlayment of 1/32" thick Swiss Pear. This is for the top strake of wales.
3) is the first of the planking for the upper works.  Forward of the first port will be heavier planking going from the wales upward
(last photo which is from Karl's build of Bohomme Richard.)
4) Ebony for the top wale.  It's 1/16" thick to make it easier to bend than the full thickness of the strake.
The issues are the end of the ebony needs adjusting. For some reason it drooped while getting it into place.  And there's piece near the stem on the second wale where pear split.   I'm not overly concerned about it as the bolster for the hawse pipes goes over that.  The whole thing will need sanding and smoothing but for now, I'm going to continue on and finish running these to the stern and then get the other side done.  I'm also still sorting out clamps. Seems I broke two frames in the process of getting things glue up.  I have to not put so much force on those clamps. ;)
As always, feel free to click on the pics to enlarge and criticism, different ideas, etc. are always welcome.  I'm still learning this stuff.
Edited by mtaylor
The attention and detail you are lavishing on her should result in a very nice planking Mark.  Still hangin' there :)
cheers
Pat
The varying of the thicknesses is an interesting challenge.  I don't envy you working with the ebony but, in the final analysis it's going to look great.
Rooting for you!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
I'm going to echo what the other guys have said, and also add that maybe that ebony plank could be flipped end for end to correct those drops. In the pic, it almost looks like it's curved downward at the ends. Probably just me!  :rolleyes:
Cheers
GEORGE
Thanks for the "likes".
cheers
Pat
Thanks Pat.  I've still got my fingers crossed...  Next ship won't be French so hopefully the planking will be easier.  :)
Rooting for you!
Thanks Augie.  It is a challenge.. :rolleyes:  But, I wanted the wale's line to highlight their curve.
Cheers
Thanks George.  It's the way the plank runs and twists.  I am going to run a file over it and get it looking more even as well as sand everything since there's some unevenness in thickness due to the bends and twists.  Since this is the first side, I may use it for the "wall side" as I'll do my experimentation here.  :D  :D :D
The ebony ... couldn't you use a longer plank. Like this you miss leverage to follow the strake. Furthermore, you cannot file/sand/cut it into line for the other side won't line-up.
Nice chalenges again
Carl
it's still early Mark.........still time for that idea you haven't thought of yet,  to come to the surface  ;)    your planking now......you've come further than  you did in V1..........that counts for a lot!   very nice start  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Mark
You may well say "As always, feel free to click on the pics to enlarge and criticism, different ideas, etc. are always welcome. I'm still learning this stuff.", but believe me, I think we're learning just as much from you as you are from us. I'm really enjoying seeing your ship grow before our eyes, photo by photo and, with it, I'm gaining as much knowledge and insight as possible in terms of perserverance and effort.
As far as the issues that you're having now, I'm sure that they'll be ironed out in no time at all.
All the best!
Patrick
Mark,
Just getting caught up. Your Licorne looks fantastic!
- Tim
Thanks Tim for the comment and to everyone for the "likes".
I do start with a longer plank and then bend it to shape.  The ends that don't get bent get removed and the planked is checked for length, Carl.  I think if they don't line up, one of two things will happen... I'll either shape the other side to match, or rip it off and have another go.  :)
I think you're right Denis.  I'm beyond V1.  Well into the Twilight Zone.
Hi Mark
All the best!
Patrick
Thanks Patrick.  They're being ironed out as I go.  I do find that I tend to post the "not good" stuff as well as the "good" stuff.   I think it's part of the learning curve and finding pitfalls.  The really nice thing... perhaps the biggest thing about MSW is that we all learn from each other.
Back to planking...
Ahoy Mark :D
It is truly an amazing project you have here. An absolute pleasure to follow.
Sorry to see the crack but we all know these things happen and generally only make us better in the end. I am sure you will weather this small squall
As for your Ebony I am not sure if its correct to use spile and ebony in the same sentence but I am wondering if this might be that exception to the rule.
Good luck and happy sailing
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Looks like you are making some good progress Mark, we all do the dance one way or another.
Michael
For someone just learning this stuff, you seem to be doing exceptionally well. I don't know  enough about what you're doing so I can't really offer you any constructive criticism, so I'll just sit back and enjoy your work. ( maybe I'll learn something :P )
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks for the feedback and the "likes".
JPett, spiling is an option but at this point, I just use a file sometimes in place, other times, remove the plank, shape and re-fit.   After I get these first two wales done, I'll mark off the hull and then have to do tapering, spiling, etc.
As Michael says, we all do the dance...  :)
Between translating the Belle-Poule monograph and planking, I'm keeping fairly busy and somedays, its seems like I don't get much done.
Interesting material in the Belle-Poule monograph.  The rigging plan is radically different then Le Venus that Hahn used.   I see I'll need some feed-through sheaves amongst other things.
"... I don't know enough about what you're doing ... so I'll just sit back and enjoy your work. ( maybe I'll learn something :P )
Frank
I echo that loud!!!!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Frank
You see Mark,
I'm not the only one  :D  :D  :D  :D  :D
Go back in the relax mode......
Sjors
Mark your right about learning from each other, I find I learn more foremothers (from others, stupid keyboard...) mistakes and how they fixed them than I do anything else short of actuall hands on.
Now if only I could make some time for hands on myself..... ;)
Sam
Edited by src
Current Build Constructo Enterprise
Thanks for looking in, everyone.
Port side, first three strakes.  Not too bad to my eye and I'm happy.  The pics, though tell me that I'll have to do some sanding and shaping still around the joints and also to fair and smooth things out a bit.  The big challenge here is the where the plank thickness changed and also where the hull shape changed due to the tumblehome.  I'll fix things with some sanding and then finally scraping to get the ebony dust out of the Swiss pear grain.
Onto the starboard side....
The run of the planks looks great !!  Ebony dust into the pear ---- I wouldn't have expected that.  Duly noted.
Augie
Previous Builds :
Hey Marc:   What they all said!   ;)
Cheers
GEORGE
