gjdale
Everything posted by gjdale
  1. Happy Birthday Andrew! More meticulous work I see - looking fabulous.
  2. Sorry to hear of your back pain issues Nenad, but glad to see you back posting again. Hope your health continues to improve.
  3. Hello Jay and welcome to MSW. You’ll find a strong contingent of us Aussies here. You’ve joined a very friendly and supportive forum too. There are plenty of build logs for your Cutty Sark here, so a wealth of information from those who have trodden your particular path before. Please do start your own build log too - you will find it the most valuable tool in your toolbox.
  4. Very nice work so far Andrew. Thanks for taking the time to provide so much detail in how you have approached the build - I’m sure it will be helpful to many, me included as I have this kit in my stash. I’ll continue to follow your build with interest.
  5. I’ll pull up a chair for this one too Bill. The Chris Craft boats truly are things of beauty and watching your scratch build looks to be a fascinating journey. Have you considered making this a “working” model (ie by adding RC to it)?
  6. Looking good Chris - nice to see her right way up again!
  7. So sorry to hear your sad news Doris. As others have said, you have made a beautiful model that your husband would have been proud to see you complete.
  8. So nice to see you back working on your lovely model Daria. The time lapse video was a good idea too - now we can see that you really are doing all the hard bits and just leaving Dad to do the easy bits!
  9. Hi Dib01, You are in luck! I just happen to have scanned the instructions when I was building the kit as I didn’t want to work from the originals. If you send me a Private Message (PM) with your email address, I’ll send you a PDF copy of them. I do also still have a spare copy of the lithograph (which you will need for constructing the wings). I’d have to post that one via snail mail, but I’m sure we could work that out too.
  10. Great work Sea Hoss. She’s looking more lovely with every update.
  11. Great, simple solution Dave. What’s that old saying about the best solutions are often the simplest?
  12. Congratulations on yet another fine build B.E. Your meticulous attention to detail really raises the bar for the rest of us.
  13. Thanks very much for the kind comments guys. And yes Chuck, I have enjoyed this kit very much - it’s such a pleasure to work with a kit that has been so thoroughly well thought out and with such clear instructions on HOW to go about things while still allowing some room for individual preference. I still think my planking could have been a lot better, but that is on me and I’m sure I’ll take those lessons on to the next build. And Rusty, I’m sure Glenn did a fine job too....😉😎😁...
  14. Nice to see you back at the bench Mike. Love your home made drill too!
  15. Good to see another Medway Longboat on the blocks. Take your time and enjoy the build - this is a really well designed kit but it does offer a few challenges along the way. You’re off to a great start.
  16. Quite a bit of progress over the last 2 weeks, aided by retirement from 18 Dec! First up, while waiting for paint to dry on the cockpit seats, was the windlass. I ended up having several goes at this. I wasn’t happy with the shape of the ends after my first attempt. On my second attempt, I wasn’t happy with the shape of the square holes (I’d managed to elongate them). On my third attempt, I decided to machine the tenons on the ends. When I placed this inside the boat, it seemed to me that there was too much of a gap between the square section of the windlass and the riser bracket. I compared the windlass template to the plan drawing and noticed that the position of the square holes differed markedly – by about 10mm between centres. In other words, the whole of the square sections on the plan drawings were 5mm further towards the riser bracket than those on the template. I checked in with Chuck on this and his advice was to stick with the template dimensions. Just for the heck of it, I decided to have one more go, this time moving the square sections further out (by about half the actual difference in the drawings). I also decided to do as much of the shaping as possible using a combination of mill and lathe. Since I was going to the trouble of setting up the machines, I took the precaution of preparing two blanks (these were made from some spare 1/2” square boxwood that I had in my stash). I first thinned these down to the 3/8” square using the Byrnes thickness sander. It turned out to be just as well that I prepared two blanks. I was just completing the final machining process on the first blank (turning the final diameter for the tenon) when I took too big a cut and broke the part. Fortunately, I had completed all of the machining processes on both blanks as I went, so it was no big deal to simply complete that last process on the second blank, taking lighter cuts. The picture below shows the final result. Going from left to right, my first attempt through to the final version, along with the two windlass bars also finally shaped. The fourth (and final) version show the effect of moving the square sections further outboard. I decided I preferred this position. The square holes were achieved by first drilling with a 3/32” drill bit, and then cleaning up with a 3/32” micro chisel (one of my lovely Russian set made by Mikhail). Next up was the mast ironwork. No issues here – just followed Chuck’s excellent instructions and used JAX Pewter Black for blackening. I did find the belaying pins a bit of a challenge, but again following Chuck’s advice I managed to achieve four reasonably similar results. The Thole pins were next. Here I departed from Chuck’s suggestion of turning these in the Dremel/rotary tool. Instead, I used my Byrnes draw plate to bring the 3/64” square stock down to a diameter of about 1mm. Following Ryland’s excellent idea from his build log, I made a small jig to position the thole pins a consistent distance from each other within each pair, and also from the edge of the cap rail. The picture below also shows the completed cockpit seats, as well as the three sets of knees on the relevant thwarts. The Fixed Block for the Stem was made up according to the instructions and fitted to the starboard side of the Stem. And the Roller for the bow was made up and fitted on the port side. The rudder was next. I first tapered the rudder from forward to aft, per the instructions, and also rounded over the forward edge. The rudder hinges presented no particular problem and were installed per the instructions. Of note here is Chuck’s advice to thin these down once fitted, before adding the wire bolts. Once these were completed, the hinges were painted black, the red section painted at the head of the rudder, and the friezes applied. The tiller was made up from a section of the supplied 3/32” square stock, chucked in the Proxxon rotary handset and shaped with sandpaper and files. A small round tenon was made on the rear of the tiller and a hole drilled in the rudder to accept the tenon. I also decided to take Ryland’s advice and fit the stands to the hull at this stage (actually prior to fitting the thole pins). I’ve also made up the grapnel, although there are no pictures of this yet. Here are a few overview shots showing the completed hull. The rudder has been installed in the photo but has since been removed for safe keeping to avoid damage during the next phase of building. And finally, one with completed hull posed on the display stand. On to the masting and rigging next but will probably have a slight pause while I attend to a 1:1 scale project for a friend….
