marsalv
Posts posted by marsalv
To dowmer - this time I used brass, which is then tinned, and tin foil, which is glued to the deck with double-sided adhesive tape.
To glbarlow - the maximum length I can do on a milling maschine is 28 cm, for longer plank I use "special jig" - see picture. I insert the plank into the groove in the jig, perform the milling of the first part, remove the plank and move it forward and continue milling.
I continue with breast hook, collar beam and bowsprit partner.
Hi Michael,
moldings are made on CNC milling maschine. I am using VCarve software for this purpose. You have to create only curve (cross section) of molding and maschine does the work itself🙂. You can see in this example that my workmanship is not so superb as you noted🙂.
Preparation of deck beams for forecastle and quarter deck.
- Oliver1973, JpR62, JOUFF and 19 others
- 22
To Druxey - thanks for informations, I discussed this situation with my friend who had the same problem. I cover these lead items with clear varnish and the whole hull is then preserved with the wax. I hope that it will be OK.
To Alexandru - I am using the french Sajou thread for the ropes (https://sajou.fr/en/339-fil-au-chinois-gloving-thread-1000m-cones). Unfortunately this thread is only in one thicknesess.
Completed ceiling.
- Captain Poison, Bluto 1790, davec and 21 others
- 24
To No Idea - I mostly use the two flute router bits (https://cnc-plus.de/en/End-Mills-266/2-Flute-281/Carbide-Two-Flute-Router-bits--2-Flute-End-Mills--CNC-Cutter-Bits-2983.html).
Waterway.
- ChrisLBren, Oliver1973, Mike Y and 22 others
- 25
Thank you guys for all comments and likes.
To No Idea: tilting base is specially designed and "home made" for existing Proxxon vice.
To dvm27: I have visited Sherline web - this maschine is fantastic, I´ve never seen anything like it before.
After about one week all ropes are finished, cca 190 ropes in 14 thickness. Lenght of one ropes is approximately 180 cm.
- John Cheevers, KentM, JpR62 and 21 others
- 24
- Ron Burns, Jorge Diaz O, KentM and 27 others
- 30
Hi Derek, thanks for reply. Information at the beginning of the log I meant that there is no fixed orlop deck. At first I thought I wouldn't install this removable orlop deck at all, but later I changed my decision.
I added the barrels to the water hold and covered the whole with the remaining deck beams.
- mugje, KARAVOKIRIS, Jorge Diaz O and 26 others
- 29
- JpR62, archjofo, Edwardkenway and 32 others
- 35
- DelF, DmitriyMarkov, davec and 30 others
- 33
Le Gros Ventre by marsalv - FINISHED - 1:48 - POF
Thank you guys. Answer to Glenn: The groove is made so that you only have to push the plank into the groove. For sure, however, it is still glued with double-sided tape.
I started work on stern - moulding rails.
