Everything posted by BANYAN
Some good progress OC; coming along very nicely. cheers Pat
- 455 replies
- slightly modified
- greyhound
OK that's done it - I need a better (BIGGER) dictionary to find further superlatives - I have run out of ways to compliment your work ED That is craftsmanship at its highest standard. cheers Pat
- 3,618 replies
- young america
- clipper
Great looking model Dan; the details are superb. If you look up "the task lighting" section of the "rules of the road" for maritime navigation you will find the appropriate task light colours. The main task lights will need to have catered for - not under command, restricted in ability to maneuver, and perhaps under tow, which mandate combinations of white, yellow and red lights in specific sequences, arcs of visibility and spacing. That may help determine the lighting colours and placement and add some interest? The attached pics provide a summary of some of the task and nav light Rules, and an example light control panel, that while a modern version covers the same types of light requirements for older vessels under the 'rules'. the insignia/logos on the images show from which companies/organisations the graphics originate. I hope this helps you add some life to the lights cheers Pat
- 287 replies
- michelangelo
- ocean liner
HMCSS Victoria 1855 by BANYAN - 1:72
BANYAN replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Thanks for looking in and kind comments Dave and John - welcome back to the fray to both of you Some further small updates coming very soon. cheers Pat- 1,021 replies
- gun dispatch vessel
- victoria
Looking good Mark; nice to have a laser cutter for accurately fitting parts. cheers Pat
Great progress and looking great Patrick. Is it just the angle of the camera or does the flare of the hull (stbd side) at about the two-thirds back mark seem a little wider than for the port side? cheers Pat
Looks great Dave; welcome back I hope you had stern words with those slackers in the dockyard cheers Pat
Hi Rod, see my response to your PM for some answers, however, a couple of clarifying points for you to ponder. A ship is steered by a helmsman using a compass and is 'conned' on to the course to be steered by the deck officer (Officer of the Watch in RN terms) or the Captain (whomever has the control of the ship). I think it was this way even back then also. The helmsman does not need to see ahead but does need to see the sails (to keep them filled) and have a clear view of the compass - seeing ahead is a bonus So a large binnacle would be okay. The style, design or size of the one used in Endeavour will probably never be known. I went with the larger one (Marquardt) as this being a ship of exploration and, when being refitted, potentially for survey as well, I believe the availability of two compasses a necessity. That does not mean your interpretation is incorrect and may well have been one a possible fit. I only raise my point for consideration. cheers Pat
- 108 replies
- endeavour
- caldercraft
You always achieve such clean crisp joints Chuck; very impressive. Love the wood tones! cheers Pat
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Another warm welcome from downunder Greg; interesting genealogy and one you can be justifiably proud of. cheers Pat
Nice work with the case Mike; especially in your recovery of the break. cheers Pat
- 969 replies
- hahn
- oliver cromwell
Hi Rod, you are making good progress with your build of Endeavour; I'll pull up a seat and follow-along also. As you noted the anchor linings are not well covered in most kits. For mine I dry fitted the anchor to the cathead then traced the arcs the anchor flukes followed as they were catted or lowered in preparation for dropping. that gave me the 'real' arc the lining had to follow. The deck fittings were the most enjoyable for me and you have several good options in the various plans, books and replicas to follow as to how they looked. cheers Pat
- 108 replies
- endeavour
- caldercraft
Many thanks Druxey and Denis; appreciate you both looking in and for the kind words. cheers Pat- 1,021 replies
- victoria
Wonderful looking model John; I really like the detailed carvings and extra bits and pieces which make it look very authentic. Better keep your 'helper" away from it cheers Pat
Coming along very nicely Dave. cheers Pat
- 742 replies
- constitution
- frigate
Thanks for the very kind words and encouragement Russ, Ed, Jason, Carl and Eberhard. Compliments from you guys, noting the exquisite work you do, is very much appreciated. regards Pat- 1,021 replies
- victoria
