mtaylor
Moderators
Everything posted by mtaylor
  1. Tough call on the treenails/planking, Matt. I would say #2 as #3 will probably look a bit busy. Maybe test it on some scrap first and see what you like. I love the wood colors and that deck just pops right out at you.
  2. Glenn, Will it be weathered or "factory fresh"? I think the white would probably have been some version of whitewash and flat.
  3. Just gorgeous. You set the bar really high on these little boats, Johann.
  4. That one's popped recently for some reason.. again. I suspect the writer came across the book and had one of those "I never heard of this before so it mush have been a secret" moments.
  5. Beautiful work at a size I can only dream of. gorgeous...
  6. This excellent customer service and lesson for certain other companies (and not just models or tools) to learn how to get and keep customers.
  7. So both you and Her Majesty have dead eyes? Yes, it's time to quit for the day when your eyes go dead. Looking pretty great, Nenad.
  8. Beautiful work on both, Gregor. I don't know how you can build two at once as one is pretty much my limit. I'm in awe.
  9. Beautiful work on those boats. Please thank your friend for letting us see them.
  10. Yes... they should blacken like any other brass item.
  11. In spite of the problems, it looks super nice, Grant. It's funny that we reach for heat with wood and don't even think about it for plastics.
  12. Brian, I love the pear. It's a great wood to work with, IMO. Got a question for you. Did you fit the decks before planking? I'm asking because of the notches and a couple of models I did, you couldn't plank the deck until it was fitted otherwise you'd have some big gaps where the notches are.
  13. Thanks all. Both drops are finished (except for the acanthus leaves - carvings) and mounted. I've flipped it over back to right side up on my "jig" board and and starting the roofs. This should be interesting for me.... More multi-curves to shape.
  14. I caught myself smiling at those, Jesse. They are looking great.
  15. It's taken longer than I thought to get to this point. I had a minor issue with wood that had defects unseen from the surface, but that goes with the territory and then also quite a bit going on in "life". There will be another pause coming up for Janet's surgeries, but for the most part, that will just entail my keeping an eye on things during the recovery process. The first drop is essentially finished except for some minor touch up (and the carvings...). I've finessed it to fit the hull and the molding and it just needs a bit of touch up on the sweeping curve from top to bottom before gluing into place. The other side is finessed into place and just needs the final shaping to get the curve and then any touch up work. Once these are done, I'll post both sides and a stern shot. I'll need stern shot anyway for my records and to check for uniformity. I won't be applying any finish for now until the wood has a chance to age and regain some of it's patina. Here's the photos...
  16. Beautiful work, Glenn. Sorry that the metalwork is over for now. Everything is very crisp and clean and well fitted. Ah..well worth the wait for the weekly update.
  17. Anthony, I'd go with what Bob said. Danny V. did that on his center section he's building and it's very effective.
  18. No CA here... only PVA or epoxy. PVA for wood and epoxy for metal to wood. CA does bizarre things to my sinuses.
  19. Good looking masts, Sam. So Murphy is hounding you also....? P.S. I loved the campground photos.
  20. Ok.. I think I understand it. I was just thinking if the linkage could be done under the deck, let the rigging above deck just be a dummy. I do hope you can get it sorted. I want to see a video of her sailing.
  21. Sjors, I agree with E.J. Go with a light wood as it will be dark enough on that second deck when you put on the third one.
