Still having trouble adjusting to the much slower pace with the building. With my declining health simple things are not so simple anymore. I have to do the hammock cranes still but have decided to start pre-making and dry-fitting some stuff before I add them. Already made the bowsprit bitts but forgot to post it. Sanding the grove the bowsprit will fit in with sandpaper rolled around a wooden dowel. Began shaping lower bowsprit.
Jesse
Edited by JesseLee
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Working on bees, bowsprit cap, yard sling saddle, jack staff, etc.
Jesse
Nice work, Jesse.   Steady as she goes, I think.
Great progress JesseLee - - steady as she goes mate.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Jesse that is an amazing Long Boat. Can I hire you for my Syren? o)
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
After what seems like forever I finished the Bowsprit. Making the Jibboom: Sanded the eight sides to the heel. Mine turned out to be not as big around as the pictures in the instructions show but close enough to be fine with me. Grooved and shaped the tip. Cut out the sheaves in both ends then realized I cut the sheaves wrong. The tip sheave goes through top/bottom. The heel sheave is supposed to go through sideways and I cut mine both top//bottom. Instead of remaking a whole new Jibboom I sawed off the heel right between where out is rounded and where the eight flat sides are. Drilled both ends out and glued in a 2mm wire pin. Glued it on with the sheave turned the right way. (I had previously left extra length to this end in case of any problems). The seam is almost invisible and this will also be right at a paint line so it wont be noticed. The wire pin made it very strong. Cut this end to length and grooved it out on the end.
Jesse
Nice work Jesse. Good save on the sheave. It is indeed hard to spot if you know it, so it will be invisble to the unknowing eye.
Carl
Nice done JesseLee ad a great save.
Cheers,
                       VOC Ship Surabaya
nice work Jesse :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 5 weeks later...
It has been quite a while since my last update. My illness along with many other things have kept me from the work bench. Seems life keeps dumping more and more on me including another death in the family. I am very thankful though when I see all the devastation happening in so many places. At least I still have a home and a work bench to get back to.
The instruction book has me ready to start permanently adding the bowsprit assembly and rigging it. I am holding off just like I did the Hammock cranes and netting. I like to pre-make all the physical parts from the bowsprit, jibbooms, masts, yards, tops, etc. first. I do this to make sure all parts are made the right size and fit properly ahead of time. I have found in the past that if you don't look ahead sometimes having to alter a later piece might affect how everything fits or spaces with pieces you have already glued in place. This also can apply to how the rigging ends up so I just like to do things this way.
The next series of updates will be me pre-making all these parts, a lot of dry fitting and checking that everything will end up like it is supposed to be. Then I will go back and start gluing things into place in their order so I can get to the rigging stages. Below is the only picture I have ready at the moment of constructing the Dolphin Striker. When there are separate small pieces like tis glued together that will have rigging pulling on them I like to have tiny metal pins between each piece for extra strength. More updates coming soon.
Jesse
Dry fitting of the bowsprit, jibboom & flying jibboom.
Jesse
Started the lower masts. Used poplar dowels I picked up at Lowes. To square the top part I started with a mini plane sent to from Europe. Then finished with emory sticks women use for their nails. Made the cheeks Notched them for bands.
Jesse
The cleats supplied in the kit are cheap metal stuff and I just can't see trying to use them at all. Decided to make my own. Had some scrap pieces of some kin of hard wood cut off the end of something. Cut out into small strips then shaped with mini files. Made all the ones needed on the lower masts and the ones that will be needed in the rigging later. Close ups of both ends of the completed lower masts.
Jesse
I love your self made cleats!! I've got to make them also. The ones with the kit are awful. Nice Job
Great work on the bowsprit and the jibs. Those cleats look real good, and the lower masts definitely look very promising. Looking forward to the next stages of the masts!
Carl
Jesse - I know it is too late for you but for everyone else in the Syren Club Chuck makes some great Cleats out of boxwood.
Mighty fine work JesseLee. Yup, there's nothing like scratch building your own parts.
Cheers,
                       VOC Ship Surabaya
Jesse Lee
I have to add my 2 cents re: The made cleats  over the metal is the difference between an ok model or a class 1 build, these are the small things that hits you between the eyes in the appearance of a finished build. I am really surprised they included those nasty looking cleats in the model that was not cheap and would have added little if any to the cost of the kit.
Very nice job you improved the appearance by 100%
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
