I’m still chugging along with assembling the frames. Slow but steady she goes.
Here are a few more done and test fitted to the keel and framing jig.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
What a massive frames!
You might need a crane to rise them and put´em in place...
At that scale the amount of detail you are going to put on her is going to be amazing! I cannot imagine myself working at that scale. There´s something magic when you see a model of that dimensions in a museum.
Best wishes.
Daniel.
Thanks Daniel.
A crane might not be a bad idea. I think I may get a hernia when it come to taking it
out of the framing jig. :huh: Still plugging along here finishing and fitting frames.
Rusty
Thanks druxey.
When making the double frames the plans show a single treenail on each side of the
joint at the chocks. The size came very close to 3/32”. I used a standard dowel that I
had at that size for the treenail. And no I don’t have a drawplate that size. :P
Almost done making frames! :36:
Rusty
Those frames are massive....  wonderful work Rusty.
Hey thanks to all of you for your interest and support. :)
Yeah Ben, Gregs methods were a big help.
Big Frames, Big treenails, Big piles of saw dust!
Oh yeah and a big pile of frames too!
Rusty
Rusty, beautiful work as usual, what is that plan behind that big stack o frames?
Yes, inquiring minds want to know.
Bob
Current build:  SS_ Mariefred
Thanks all,
Very observant. Those plans have shown up in many a picture over the years. The plans are
for the OcCre Cazador Xebec which I have been tinkering with on and off over the last three years.
The hull and deck are planked. I figure at the rate I’m going it will be done sometime in 2016! ;)
Hi Chris, Well it’s too early to tell. One thing I know is you don’t have to worry as much about snapping
a frame when they are ½” thick and I swear you could stand on them. Cutting joints and chocks were a
lot easier too but the scroll saw work to cut them out took three times as long and I went through a whole
lot more blades. Another thing is if you make a mistake in a joint it is compounded by the size. What would
be a paper thin gap on the Echo could be very wide on this build.
I can see why people would like the larger scale though. We shall see.
Rusty
Great work on the frames Rusty - she sure is big at this scale!
Hi Greg and Grant, thanks for stopping by. Starting to put frames in place! B)
Rusty
Nice work
Rob
Current build:
Finished build:
Current build(On hold):
Thank you Rob.
Well I’ve installed all of the frames. After fine tuning them so they sat correctly it
was just a matter of gluing one in place, waiting for the glue to set then repeat.
To strengthen the frames for when I remove the cross section from the framing jig I
glued blocks between the frames at the area of the wales and then at the tops of
the frames.
I also thought about installing blocks between the frames at the keel but instead I
drilled through the frames into the keel and glued in a dowel. Now those frames
aren’t going anywhere.
Next up will be a lot of sanding the frames to fair it up. I’ll start with the inboard while
it’s still in the framing jig and install some of the interior framing and clamps to strengthen
it even more.
Well I’m off on a short vacation so I’ll be away from a computer. Hopefully the withdrawal
pains won’t be too severe! :o
Rusty
Have a nice break, come back soon to continue the lovely work
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Like your work Rusty, Cherry is a beautiful wood to work with.
mij
xebec 1:60 scale, scratch build
Hi Rusty.
Very nice build. Loads of frames completed and looking very clean.
Will be following this build with interest.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Well I made it back last night and I popped on for a quick look see and man has
everyone been prolific while I was gone. I'll have to take a couple of days off from
work just to catch up on all the posts.
I want to thank you all for stopping by and for you kind words and interest in this build.
Work, yeah like it’s work ;) , will resume tonight. :)
Rusty
