Fantastic clean work....just wonderful.
Rob
Current build:
Finished build:
Current build(On hold):
Thank you Rob!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hi All,
Well all of the carronades and long guns have been rigged and rope coils placed.
I also put the pumps in place.
Next up I’ll be doing the rudder and tiller. Thanks for stopping by and all the likes.
Rusty
Hi Chuck, Pat Bob and Grant. Thanks so much for the kind words.
And thanks everyone for all the likes too!
Rusty
It’s time for a long overdue up date. Next up was the rudder.
Like other parts I used Chucks Syren laser cut rudder.
The rudder is tapered as it works its way aft.
Also the forward edge is chamfered on both sides.
The pintels and grudeons were made made from another Syren kit. The bolts are simulated with 24 gauge wire.
Time to make some masts and yards!
Rusty
Thanks Pat but it's really a lot easier when using Chucks laser cut parts! ;)
Also thanks for all the likes!
Rusty
  • 3 months later...
Hi all,
Been real busy this summer with vacation, family commitments and working the last 4 weeks
straight hasn't left a lot of time for modeling. I did pop in and out of the shop from time to time
a few minutes at a time.
To make the various masts, yards etc I took some boxwood cut into square stock and shaped them.
The mast dry fitted.
Next I'll be painting and attaching blocks and foot ropes.
It's great to be back in the shop and doing what I'm supposed to be doing! :)
Rusty
Great to see you back at it Rusty; you haven't lost any of your skills during the interval - very nice work.
cheers
Pat
Thanks Dirk, Joe, Grant, Pat, and Elia for stopping by and the kind words.  Also thanks everyone for the likes.
The mast has been painted and assembled and dry fit back in place.
I'll continue fitting out the yards next. Then it's time to learn to make thimbles and seize line!
Rusty
Looks great from here, Rusty.  Have fun with the thimbles.
Thanks Bob,, Glad you're safe and sound in Chicago!
Hi Mike, Not sure if the thimbles or seizing will be the most fun!
Thank you alde.
Plus all the likes too.
Here the boom and gaff have been completed.
More to come by the weekend!
Rusty
Ok I said I'd more for the weekend! I just didn't say which one.
The two yards have been completed. Blocks, foot ropes etc have also been attached.
Next up I have to breakout the original Syren Serv-O-Matic and try serving line for the first time.
Rusty
Hi Druxey and Pat. Thanks for stopping by and thanks for all the "likes".
Rusty
Hi Rusty,
Great work as always. Your ladders look great. How did you cut the grooves (file? razor saw?, table saw). My first attempts at the confederacy method were OK but not as nice as yours.
Best
Jaxboat
Edited by Jaxboat
Thanks Chuck, Your plans and directions make it a whole lot easier.
Thank you Eric. I see your doing some good work on the Syren. Nice job on the coppering the hull.
I love that Model. It was my first scratch build.
Thanks Jaxboat. I used the table saw to cut the grooves. Trust me there have been many
rejects before the final ones made it to the model..
OK I put the Syren Ship Modeling traveler ring on the bowsprit. I then served some .025 rope for the
bobstay with a 3/16" single block seized to one end. The opposite end was fed through the stem and
seized. Some .012 line was attached to the bobstay block and fed through  the lower double block on
the bowsprit. At this point I discovered I had no belaying pin to secure the line to! Head slap.
Ok now it's time to make some belaying pins!
Rusty
Ok I didn't think I needed to break out the lathe to do these small belaying pins so I did as Chuck did.
Can't go wrong doing that. I cut some 3/64ths square boxwood, chucked it in my dremel and using
files made some belaying pins. The success rate was about 50%.
Hmmmm.......Looks like I need to do some dusting!
Rusty
