HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
The hull looks very good now. Wouldn't have expected sienna to do that, but I should have known colourwise. Yes, those turrets aren't for pussies;) They stretch the whole breadth of my hand. Did you use a larger nozzle on he airbrush for the primer? Can' wait to set mine up. I'll be having enough to do when I can start priming. The box with parts to prime starts to fill up
Carl
I used the .4mm for the hull overspray but the .15 for the primer as there as so many little bits, and I thinned the AK primer by about 20-% continually cleaning the nozzle. Worked fine.
Greg
Moving on with the mains guns whilst the hull sets, after the primer coat, some pre shading then filling it in and overspraying.post-253-0-70845500-1487115151_thumb.jpg
Then masking to bring up sharp edges with 50/50 mix of light grey and whitepost-253-0-44735200-1487115183_thumb.jpgpost-253-0-82289600-1487115195_thumb.jpgpost-253-0-79763300-1487115205_thumb.jpg
Finally a grey filter added to tone it down.post-253-0-28800300-1487115225_thumb.jpg
next will be the blast bags and gun tubs, then washes and weathering.
Greg
You're getting quite the dab hand at this Greg; those gun turrets look very good indeed.  Nice work.
cheers
Pat
Edited by BANYAN
Greg, that is some impressive detailing there. Watching you layer paint brings the same awe to me as watching our scenic artists give a hunk of gel coat and fiberglass life.
Two questions, there are some very tiny trusses or ladders at the base of the barrels and two "wings" on the rear of the turrets, what are they?
Sam
Current Build Constructo Enterprise
That is stunning Greg, really good work with the airbrush.  Weathering; looks like you have started - there appears to be some nice grime effect in the gun tubs at least. and the looks of some rust on the leading oblique plates of the rangefinder extensions?
cheers
Pat
Edited by BANYAN
This is what I could find:
on a good day the turret recieved information from the director on the foretop. This used radar to get precise range information and had a stereoscopic system as backup.
If the turret stopped receiving information from the fire control computer the turret would switch to local control. This was entirely stereoscopic, and thats why there are "wings" on the back part of the turret, this houses the lenses for the rangefinder within the turret.
Carl
Those tubs were fitted in 1945, on one of the front turrets and the rear turret. They do give something extra, that's what I can't add on the Musashi. Love the detail you added with the paint, Greg. Wonderful work on that.
Carl
Banyan, only used a light wash so far, grime and rust then salt to go. Once that's done I can add the railings then park them. I'm working on the secondary guns at the same time plus a few other bits and pieces. Your advice on the airbrush has been invaluable to me. It's such a big kit, it takes a lot of paint. My trigger application has improved a lot, bit like my normal work tools, gentle application with the centre of the index finger gets the most accurate results without flinching.
Greg
Glad the airbrush has turned out to your liking; can't beat good tools that are handled correctly (work or play) :);)  You have leap frogged me in application though as I have never tried layering shading etc.  After seeing your efforts here I may consider this as an option for Vampire as i have the original resin hull to play with first.
cheers
Pat
look'in good Greg........you've really got a handle on airbrushing techniques  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
As previously stated, whilst waiting on the lower hull to set, I've done up the secondary and main guns. This mean doing up the railings using ezline and adding rust, grime and salt streaks.post-253-0-54627600-1487634779_thumb.jpgpost-253-0-18275400-1487634782_thumb.jpgpost-253-0-33351100-1487634786_thumb.jpgpost-253-0-71331700-1487634791_thumb.jpg
Behind the forward turret are two paravanes, and the reference material is a bit vague here as some say there are paravanes n the aft secondary turret as well, but they don't fit so I have omitted them and may place them on the deck later.post-253-0-49769400-1487634796_thumb.jpgpost-253-0-75927900-1487634800_thumb.jpg
The next pieces are the sides for the main superstructure, the vents that go behind main turret two and a platform that will sit behind the main bridge superstructure. post-253-0-19566400-1487634805_thumb.jpgpost-253-0-85498900-1487634811_thumb.jpgpost-253-0-15914800-1487634817_thumb.jpg
Greg
Next, completing the main guns. It took me 2 days to rig the railings which I lightly painted with grey and rust.post-253-0-20596800-1487635389_thumb.jpg
I have added rust, grime and salt streaks to each gun.post-253-0-30439800-1487635412_thumb.jpgpost-253-0-59288600-1487635415_thumb.jpgpost-253-0-46624900-1487635423_thumb.jpgpost-253-0-35688100-1487635426_thumb.jpgpost-253-0-43385300-1487635430_thumb.jpg
Then a dry fit to the hull, looks a bit stark but I'm happy.post-253-0-88355600-1487635434_thumb.jpgpost-253-0-23691200-1487635440_thumb.jpgpost-253-0-99504200-1487635444_thumb.jpg
Greg
You ought be happy, Greg.  Those guns look fantastic.
SUPERB Work :) :) :)
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Your painting makes it look very realistic. I like the way your railings turned out with the easy line. Might be even easier than the brass ones, considering the hardships those gave and give me. At least the look a lot better! As far I can see your kit has a lot more detail to the plastic to start with, which is a nice plus, a terrific job
Carl
Still up Greg, not passed modeller's bedtime ;)
Carl
So, looking at your avatar ...  it's well passed ;)
Carl
