3 minutes ago, CDW said:
I'll bet you will like the new lift blocks you make more than the old ones.
Hang in there, you are doing great with this build.
Dont worry mate  I  will get my mojo back,  in hindsight I shouldn't have put the foremast yard on yet  as it was just in the way while I was doing the upper foremast ratlines - and kept getting bumped, I was in a hurry becuase the lift ropes were getting my way a bit with the ratlines.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Don't be hard on yourself, OC.  We all have our days that at the end of it, we probably shouldn't have gone near the model.  I do sympathize but as others have said.. "the next ones will be better ".
Thank you mark  sincerley -   its encouragement like this that inspires and enpowers not just me but others to carry on.:dancetl6:
OC.
Current builds
Completed works.
Gidday O.C.
We all have days that seem to be nothing but one thing after another going wrong.
The trick is to find a way to overcome the doubt that creeps into every decision we make.
I am confident you will overcome your temporary malaise and do yourself proud when she is complete.
Wishing you and your family all the best.
Mark.
7 minutes ago, pontiachedmark said:
Gidday O.C.
I you am confident you will overcome your temporary malaise and do yourself proud when she is complete.
Mark.
Thank you mark   - you beauty,      sorry  only got   crock dundee  to go by.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Getting caught up on your build after being away for a while. She sure is looking good! Sorry to hear about your whoops and the frustrations from it. We all get those at some point during a build. Often times more than once. Take a breather and let your mind clear. You have done fantastic work so far and I know you will rebound from this as well. You are nearing the end and will soon have a beautiful model to display proudly! :)
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thank you for your kind supportive words EJ.
OC.
Current builds
Completed works.
Good day all,    so I had a short break  - already new what I had to do (the temptation to work on her last night was incredible)   so  I painted two fresh blocks then when dry I made two sections of rope and de-fuzed them by rubbing watery pva on the the rope between my fingers,  then I tied the block around the upper post above the tops,   I then started routing the rope one side at a time  - the first pic shows spaghetti junction, then I ran the rope down and did a few loops around the bits and glued and trimmed, I did the same for the other side and it does look better and runs far more naturaly.
Heres the pics  -
OC.
Current builds
Completed works.
Rigging looks spot on. Good works
Regards, Scott
Completed builds:
Awaiting construction:
Thank you Scott.
OC.
Current builds
Completed works.
Nice progress and workmanship OC.
I step out for a few and you just keep moving on down the line on things that need doing.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thank you lou   shes getting there,    the admiral is chuffed also.
OC.
Current builds
Completed works.
there you go....that looks really good  :)    you gonna break a few eggs,  but you'll get there........just gotta get used to working under low hanging objects ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
a quote from the Moody Blues:
there ya go man,
keep as cool as you can.
replace piles of trials with smiles.
it riles them to believe,
that you perceive the web they weave
and keep on thinking...free :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you denis,  it can get a bit disoriented working under a low slung light and looking through the mag - glass - a bit tunnel visioned.
OC.
Current builds
Completed works.
12 minutes ago, Wallace said:
She has a right to be OC, it all looks fine sir.
Thank you wallace.
OC.
Current builds
Completed works.
Evening all,     so with the foremast shrouds done - today I started on the mainmast,  I constructed the first two lengths of  rope then lashed them around the mast above the crosstrees,  I tied the lashed part quite tightly  making a neater job than I did on the foremast, I then ran the rope down and attached the shroud deaedeye - I did somehow manage to get the first one alot lower (just one deadeye distance between them)  so I thought I better do the same on the other side,   when I came to do the second rope I intended to make the gap between the two deadeyes wider, but for some reason and sloppyness on my side  - I did the same again, oh well the first two rows will have to remain as they are  (captain jack  ordered them that way after a battle with the defiant - as a way to give more strength to the main mast)   I will attempt to make the remaining four the correct gap.
OC.
Current builds
Completed works.
Quite a positive saturday at the bench  - I continued with the mainmast shrouds, this time with a little more control I managed to get the next two spaced a little better.
OC.
Current builds
Completed works.
12 minutes ago, BLACK VIKING said:
Lovely work OC . Rigging really brings the ship alive.
Martyn
Thank you Martyn,    I  was concerned about the different deadeye hights - but it is what it is, so I have made it intentional  from the captain.:dancetl6:
OC.
Current builds
Completed works.
OC.
I wouldn't worry about the different hight of the dead eyes as I have been on real ships where the dead eyes have been different heights it all depends on how tight the shrouds are .
Martyn
I have been working on some diagrams of the rigging  - whats done and what still to be done  -
OC.
Current builds
Completed works.
Good day all,   another good day on the pearl,   I have managed to get the mainmast shrouds fitted to the deadeyes,   went quite well  and is niclely tentioned  - need to do the ratlines.
A  few pics including a close up of the lashing around the mast.
OC.
Current builds
Completed works.
4 minutes ago, CDW said:
Looks great OC. How are those masts holding up to the tensioning created by all the rigging? They look nice and straight.
 Not too bad mate,   the wood inserts  certainly help keeping them rigid,  I am still being careful though  and keep checking all the masts are ligned up.
OC.
Current builds
Completed works.
just catching up on your log my friend, yesterday i also had one of those 1 step forward and 3 back, and few choice swear words, walk away take the dog out and get back on with it
lovely work
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
lovely work
Thank you sincerely Kevin.
OC.
Current builds
Completed works.
The bench was calling me so I decided to make the mainmast tops, painted and weathered  including fitting a couple of blocks for the foremast yard  movement ropes.
OC.
Current builds
Completed works.
So the ratlines begin  -
OC.
Current builds
Completed works.
