Absolutely gorgeous work. If I had one tenth or your skill I would be a very happy individual.
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Wonderful detail. How did you make the hinges?
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
To druxey: I'm almost ashamed to say this, but the elliptical  frame is made with a CNC milling machine.
To Dowmer: Hinges are made of a brass tube 1.0 / 0.2 (ie. the inner diameter is 0.6 mm). A groove with a length of approx. 0.6 mm is milled into this tube with a 0.5 mm milling cutter, the tube is then cut to a length of approx. 1.2 mm. The 0.5 mm brass nail (0.5 mm brass wire can also be used) is bent at a right angle and the nail is inserted into the tube so that it fits into the notch. This assembly is soldered with silver solder.
