Good trick on the Hanging Knee template Toni :) .
Of course, now that I have the hang of things, I am finished with the hanging knees on the lower deck.
Ah, but the trick will come in very handy for the Upper Deck, Quarterdeck and Forecastle knees :) .
:cheers:  Danny
Cheers, Danny
Since I am not taking any modeling projects with me, if the weather is bad I'll finally have time to catch up on everybody's builds. :D
Toni
Member IPMS
                           Utrecht-1742
Enjoy your time off, Toni. I like your hanging knee pattern-making dodge!
Toni, She looks great!  Good tip on the knees as well.
Maury
Toni, Your joinery is flawless as usual.  I will miss looking at your log.  Have a good time and have fun.
David B
Toni
Just looked at your build of the Atlanta. Beautiful work.
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
I have finally had a little time to work on Atalanta.  Beam 15 assembly has been installed.  The hardest part of this assembly was keeping the line of ledges straight across the ship.  Slight differences are a lot harder to notice if there is a hatch, mast partner or beam arm visually breaking up the run of ledges.
Toni
Member IPMS
                           Utrecht-1742
The longboat has been completed so I can concentrate on Atalanta.  Beam 16 set has an opening for a ladder to provide access to the aft platform.  While looking at this I discovered that the bulkhead for access to the magazine was too far forward.  The ladder would either have to be 18" wide or I would have to rebuild part of the aft platform bulkheads.  It was just too big a problem to ignore so I removed everything forward of the pillar for beam 16 and rebuilt them.  Some of the walls could be reused so it was not a total disaster.  I took pictures of all of this but discovered too late that I forgot to put the card back into the camera.
The result is not perfect but there is now room for a 24" ladder.
Toni
Member IPMS
                           Utrecht-1742
Life and  modelmaking is often like that: one step forward, two back.... Good for you to have the courage to do a re-make.
Thanks, Druxey.  I guarantee those lower deck bulkheads will be measured three times instead of twice!
Toni
Member IPMS
                           Utrecht-1742
I posted this picture of the longboat and Atalanta under the longboat build log.  I am reposting it here for future reference.
Toni
Member IPMS
                           Utrecht-1742
Ah, yes. measurements. I have a favorite cartoon that goes like this:
Manager: "My philosophy is, measure twice, then cut twice, then, uh...."
Underling1: "...give the tape measure a bad performance review?"
Underling 2: "Hee, hee! (Pause) Ooh."
Nice to see more progress on your lovely Atlanta Toni, even if it did involve some re-work (which, I might add, is actually re-assuring for we lesser mortals ;) ). The side-by-side photo is a terrific one for giving a feel for the sizes.
Toni,
Good catch and excellent fix.  If you hadn't told us, we wouldn't have known.
Thanks everyone for your kind comments.  Like so much of what we do, if I had left it alone I would have known it was wrong.  It really makes you sit up and pay attention when you realize that a 6" error on another deck (1/8" in reality) can have such a profound impact on the next deck.
Toni
Member IPMS
                           Utrecht-1742
Hi Toni,
I had exactly the same problem with that Companion, but I didn't go back for the "fix" :blush:  . I just made the ladder narrower.
Speaking of which - there is a similar problem with the alignment between beams on the Upper Deck and Quarterdeck. The TFFM deck framing plan doesn't match up with the NMM plan - the forward bulkhead for the Captain's Cabin doesn't fall on the Upper Deck beam on mine :huh:  . It's worth checking before you go much further, although it doesn't significantly impact on anything (no hatches here).
:cheers:  Danny
Cheers, Danny
Danny, thanks for the head's up.
Not much has been accomplished the last week.  The spring here has been particularly cold and cloudy so now that it is a little warmer (50 degrees with a 30 mph wind!) I have been occupied in the gardens.  We finally saw the sun yesterday so I took Atalanta sailing in the lawn.
Toni
Member IPMS
                           Utrecht-1742
Lovely shots of the work so far, we are not so green here yet.
Michael
Wonderful pictures
Regards Christian
A milestone has been achieved.  The lower deck structure has been finished.  I have been applying finish to the underside of the beam sets before installing them.  The gap in front of lodging knee 17 in the fourth photo occurred because the assembly is not glued in yet and it shifted.  The last photo shows it better positioned.  I will not put on any upper surface finish until after the decking is installed.  Now on to the mizzen partner.
post-262-0-22599800-1368905163_thumb.jpg     post-262-0-89496300-1368905163_thumb.jpg
Toni
Member IPMS
                           Utrecht-1742
Congratulations on achieving that milestone Toni - she's looking fantastic.
Greg and Grant, thank you.  I am pleased with her.  Let's see...22 month so far and how many more to go. B)
Toni
Member IPMS
                           Utrecht-1742
