Yes, with the Pyro's Revenge, which is even smaller, I''ll use spruce extensively.
The problem here is that it takes a lot of time to tension them again.
Edited by GeorgeKapas
Sorry for the lack of updates, I was a bit busy, plus a small injury to the hand. Hopefully more photos later today, the final building phase is now, and then back to the Sovereign!
Thank you. Hurting the hand meant I couldn't work on the models properly... we shouldn't take anything for granted! But Its better now.
The scale is really a problem, I couldn't use the tweezers which was vital. Also a lot of my choices especially with the shroud planks were not optimal and required fixes...
The choice to make proper deadeyes proved very frustrating. Barely 1.5mm across and they take a lot of time. On the sovereign a lot of things will move much faster even though it a lot bigger. Perhaps not the best looking from point blank distance, just a few centimetres away they do the trick, so that will do.
The shroud planks were generally a mistake that I tried to fix now, these plastic additions will be painted in the end...
SMALL INJURY????? Your hand looks more wrapped up than my shattered ankle after the doctor did a 2 and a half hour surgery on it! Just what did you do?
I am beginning to think we are going into some kind of injury season or something. Like Flu season except without the constant reminders to get your shot!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Once again, thank you. Cant wait to finish it so I can start a bigger one, so many kits lying around. This build has been  a good school for me.
It was a long hiatus, but last weekend was very productive and the model is ready! I thank everyone who followed it! I learned a lot from it, on to the next!
Impressive build of a challenging model. She turned out just incredible!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thank you all! Now I'll be doing a conversion of Heller's Golden Hind into the galleon Tyger, for a historian friend of mine, and at the same time I'll return back to the Sovereign as well!
  • 3 months later...
Hello again! I returned back to the bomb ketch after a lot of consideration, to try and add sails. It was a difficult process, but I settled in a method. If it is done in a bigger ship, it will look better and will be easier, but tried it with it regardless. The sails are made out of silk, I tried to strengthened the edges with thread, and generally tried to make them attached to the clue lines, at least the mainsail.
All the sails are furled since the yards are lowered in the first place. Even with silk, they cloth is very oversized in this tiny scale, so the sails dont have their actual original outline and size, but are actually reduced in surface area and cut down before folded, so their volume won't look off-scale.
In any case, the return to the Bomb Ketch was worth it, I think. I'll try to update and add other threads with my current builds as well.
I still call this one of the most amazing model builds I have ever had the privilege to follow. Now it is somehow even more impressive with the addition of the sails. Truly a masterpiece to be proud of.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thank you, thank you ! As I said before, many methods were tested on it, and so I insisted to give this rare kit done some justice. But it was a great lesson, hopefully Sovereign of the Seas will turn out the same, although now another kit, Royal Louis from Heller has gotten my attention.
Just outstanding plus all the other nice things folks have said. Truly inspirational.
Congratulations on a job well done.
Cheers, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
George
If I remember correctly the Heller Royal Louis is a relatively nice kit to begin with, so in your hands it should become awesome!
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
  • 1 year later...
I know this is getting tiresome, resurecting this thread already twice... This time I starting tinkering into a diorama - base. I am not sure about the background at the dock, I havent gone that far yet..
