HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Thank you Michael and Patrick :) .
With the stanchions, are you just gluing these down? If the sheaves were going to be in use with rigging would you secure them any differently?
The stanchions are pinned (with bamboo) and glued with PVA - you could hang the entire ship from them quite confidently, they are attached that strongly :D . And they WILL be used for rigging.
:cheers:  Danny
Cheers, Danny
Danny, thanks for such a detailed log! It's an endless source of inspiration and hints for less experienced builders, like me :)
P.S.: the color scheme is interesting, I'm thinking about POF model with similar wood combination - swiss pear frames and beams, boxwood hull and deck planking, mixed wood for fittings. Your log gives a very good overview of that color combination!
Dan, fantastic progress in the last month. Really wonderful
Regards Christian
Thank you John, E&T, Mike, Christian and Allan.
It looks even better in "real life" Mike :D .
are you going to rig her?
Yes Allan.
:cheers:  Danny
Cheers, Danny
Taffarel
The stern structures begin with the Taffarel Base.
I started by making a "building board" which has the same curvature as the stern. I used a couple of pieces of pine - the lower convex one is the actual board, and the concave one is used to clamp the pieces of the taffarel whilst they are drying :
Continued next post .....
:cheers:  Danny
Cheers, Danny
...... continued.
I made the taffarel base from three pieces. This will save a lot of carving, and won't be at all noticeable.
I drilled out the bulk of the inner parts of the top section, glued it to the middle section and clamped it into the baseboard to dry :
Then I finished the outer edges and glued the pieces to the main lower piece and clamped it again. I spot-glued the main piece to the baseboard - this will ensure it doesn't straighten out and also gives a good steady rest for the carving etc :
Once the three pieces had dried I started carefully carving and cutting the waste out of the middle holes. This was relatively easy, thanks to the earlier removal of most of the waste :
:cheers:  Danny
Cheers, Danny
Nicely done, Danny.  Can I ask why you glued the three pieces together before finishing the carving - was it for strength?
John
Thanks John.
Yes. The upper piece is only about 1.5mm wide and of course has a lot of sections where the grain runs directly cross-wise. I was worried that it would have snapped in numerous places if I'd tried to cut out all the middles before gluing it to something more substantial. This method worked very well :) .
:cheers:  Danny
Cheers, Danny
Thanks David - the wood for the taffarel is Castello Boxwood. I'm using dark Swiss Pear for the Capping Rail.
Thank you Greg - I imagine it would have taken quite a while to hollow out all the Coving from one piece :huh:  . I notice you didn't fit the Capping Rail or Quarter Pieces to your Pegasus - any reason for that? It would have been nice to see it all fitted to your ship - it was a little difficult trying to imagine the whole assembly from the plans.
Thank you too Al.
Capping Rail
The Capping Rail is very tricky to make. I traced around the taffarel to get the inner shape for the five pieces which I cut on the scroll saw from dark Swiss Pear to match the rest of the railings. Much finessing was need to get a good fit :huh:  . I found it best to work from the centre toward the ends :
:cheers:  Danny
Cheers, Danny
Thanks for looking in again, and the nice comments Geoff, Brian, Ben, John and Spyglass.
did you HAVE to start on your stern just as I started on mine. Not that I feel inferior or anything !! just differently skilled !
Sorry about that Spyglass, I didn't realize that you were up to the same stage :D . Besides, the construction of your Pegasus is quite a bit different to mine :D . You're doing a fine job.
Ensign Staff Block and Clamp
There are a few more things on the taffarel that need doing prior to fitting the assembly to the ship. One of these is the Block and Clamp that hold the Ensign Staff, enabling it to be easily removed.
The block is stepped into the fore edge of the taffarel and has two small molded sections at it's ends,
The clamp is very similar to a Gun Trunion Cap, so I simply used a slightly modified spare that I had (I only had to enlarge the diameter of the half-hole slightly) :
:cheers:  Danny
Cheers, Danny
I agree with Druxey, this would make an interesting article for the Journal. Hint Hint.
David B
Thanks again Druxey, David and John.
Quarter Pieces
The Quarter Pieces on most Swan Class Sloops are elaborately carved, but the sheer plan of Vulture shows very plain ones. Whether this is correct or not I don't know - perhaps the draughtsman was just lazy :D . I've treated them in similar fashion to the Pilasters of the Quarter Badges and Stern Lights.
To overlap the joints between the hull planking and counter planking I hollowed out the pieces :
Some progress pics through the stages of fitting them up :
:cheers:  Danny
Cheers, Danny
The finished stern for now - I'll fit the three remaining Lights much later in the build, as they will be in the open position and may get damaged during further construction :
The Pilasters are of similar design to the Quarter Badge ones :
:cheers:  Danny
Cheers, Danny
Very very nice Danny the flagstaff clamp is really sharp, the rest is super as well. You mention it was a spare trunnion clamp is there a picture in your build as to how you made them? with out me having to go looking to far.
Michael
Michael
They are one of the few things I didn't make from scratch - they came with the Gun Barrels which I bought from Ukraine.
Thank you David :) .
When does the carving start?
Probably never John - carving isn't one of my strong suits :( . But ..... we'll see. I might get better at it, I can always add carvings later on :D .
:cheers:  Danny
Cheers, Danny
Danny this is one amazing build, haven't looked in for awhile ......the progress you have made is just outstanding!!!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Once again a neat blend of craftsmanship and ingenuity Danny. She continues to look better every day.
