53 minutes ago, Canute said:
Of course, plan B is the wings folded option
I was thinking of wings folded, for space saving on the shelf 😉.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
a sliver of plastic will fill the gap in,  but if your going that route,  cut off the antenna put it back after the repair.  good to see her closed up......gull wings are so cool! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you Denis 20211028_215123.thumb.jpg.e20f019d1e61a9cedc7b0f2291cdb2be.jpg
antenna duly cut off while filler applied, dried and sanded, some minor rivet detail lost, I will try to replicate them with tiny dots of CA.
The antenna was glued back.
As I was sanding the filler, the wing hinges snapped, (the kit plastic is quite soft) and the outer wing sections fell off.🤨🥺
the uppermost part was carefully removed and the hinge stub drilled and a brass pin inserted and glued, a corresponding hole was done in the other part the pin pushed through and bent over and again glued.20211028_215150.thumb.jpg.152a40f362d530b6827db773e7522e9d.jpg
Hopefully this will give it a bit of sturdiness.
Thanks all for looking in etc...
Cheers
Current builds;
Completed:
Very nice progress Edward. You've come a long, long way to get this far.
This is a kit I have seen on the hobby shop shelf many times in the past but have never owned or tried to build one. As a consequence I cannot offer any specific comment on the quirks of the build but it looks as though you are figuring it out quite well. Most of my best work came on my 2nd attempt on kits I really liked. The first one provided a basic training of sorts and the second kit allowed the improved techniques learned from the first.
A small update, not a lot of progress. Painted the engine,  the instructions say to use steel colour, I've not got steel so l  used flat aluminium, with a citadel armour wash20211031_154157.thumb.jpg.902c49c3066578cc16b091c8e2a2aca8.jpg
the other parts are dark iron.20211031_154136.thumb.jpg.08849f547ea2ce9eaabad586d8f60424.jpg
also made a mask for the canopy and painted the framework20211031_154040.thumb.jpg.fa14c526398fbc3640d304c358b560d2.jpg
cockpit green first followed by sea blue20211031_154839.thumb.jpg.1cb0c9342506028b869362209ca8474d.jpg
I'm happy how it's turned out 😉20211031_160053.thumb.jpg.ffd66acad0de610dbdd17f515e00210d.jpg
thanks for watching and the likes.
Cheers
Current builds;
Completed:
Well, according to my Aunt, the cylinders were made of cast aluminum in the first place.... Dark cast aluminum would be appropriate, the fins were cut into the casting on a special lathe.... But making that distinction would be difficult....
Quote:
Hi, if you want to bring up the details of the cylinders, you might try to touch the fins with a fine brush loaded with Tamiya black liner. Capillarity should pull the ink into the slots between the fins. If you do not have that product at hand, you might try black aquarelle out of the tube diluted with water. Adding a drop of dish soap to the water, will break the surface tension of the water and the color will run better into the slots.
Good progress with your big Corsair.
Best regards,
Dan.
yea....folding wings and such makes the model all the more delicate.  for myself,  I've only been able to adequately repair a couple......the others I simply abandoned the idea and fixed the wing,  attempting it again on another model.   in my younger days,  I had a lot of models on the shelf ;)
looking good......love the repair job with the gap  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 11 months later...
Well, it's been a while since I worked on this one.
I'm hoping to get a bit of colour on her and get the wings fixed on20221008_220443.thumb.jpg.9765fb070c9953ad911bb499e57dcfc7.jpg
I'm thinking something similar to this one1480238550_04_fs(2).jpg.d740ef8c4cffcd68a52fc0ecec693f8b.jpg
But any suggestions are welcome. 20221008_220559.thumb.jpg.93d80c6cc81fa2672af94a3c91a6606d.jpg
thanks for your patience.
Cheers
Current builds;
Completed:
You going to spray her or brush paint her?
Quote:
I'm going to have a go with my airbrush and try to give the transition of the Colours a softer edge than the ones on my SBD
Current builds;
Completed:
A bit of colour on her20221013_212642.thumb.jpg.744483ea10459e4667e5fcc132782975.jpg
first coat of sea blue.
I'm waiting for some acrylic putty to be delivered and the wings will be attached and then get another coat on.20221013_212630.thumb.jpg.729ec2cb575f2f4e0304bcc31144a1cd.jpg
this is Mig/ammo sea blue, it's not as flat as the same colour by tamiya.
Thanks for the likes and looking in.
Cheers
Current builds;
Completed:
14 hours ago, king derelict said:
I've been finding that the Mig acrylics have a sheen rather than dead flat like Tamiaya. I thought it was just me
Alan
No, it's not just you😊😉I assumed they were a flat/matt finish20221014_143413.thumb.jpg.52d9a781a28bbeff5ab5b93a07d38ab2.jpg
but it doesn't mention on the bottle, anywhere that I can see.
personally I quite like the finish of the Mig colours.
Current builds;
Completed:
Just a little update, I've had a bit of a practice run on the transition of the colours. 20221016_123238.thumb.jpg.d039d1d4882e476a56e95419c3aab4dc.jpg the engine cowl was the perfect practice piece. 20221016_123247.thumb.jpg.d78ce0163343d7283d3ec6543c50b967.jpg
this was a freehand experiment, with no masking. Between the two blues I have touched it up with a brush. From the white to intermediate blue it's left as was sprayed.
I'll be interested in your opinions, for or against, any suggestions as to wether there are better methods to achieve a softer line between colours will be gratefully received.
Thanks for the likes and interest.
Cheers
Current builds;
Completed:
Cheers
Hi Edward,
For a fuzzy edge, as I don’t have the requisite airbrush skills, I would still mask, but lift the paper mask off the surface by use of small blobs of blu-tac to allow some under spray. You’d have to experiment a little to find the height of mask you need for a given “fuzz”.
Is this kit the the old Matchbox one, rebranded?
nice work!
Andrew
Completed (Kits):-
Nope it's the venerable Revell corsair, builds into a great model, but it's still the old Revell corsair.... (just reboxed to Revell of Germany)
Quote:
Thanks for the suggestions, I'll have a try on the fuselage as I don't like the freehand attempt I've tried on it20221020_133854.thumb.jpg.b287d4f756e9a027eaffd42246cfc8d2.jpg
it is a bit too fuzzy
the wings are glue on and the gaps are filled20221019_211521.thumb.jpg.694ffbbb552d5f187af2defdfec051ad.jpg
Also I've put a coat of intermediate blue on the underside of one wing20221019_211646.thumb.jpg.94ee6921fb99412b897a16b9eaa0249b.jpg
Thankyou for all the likes, comments and looking in.
Cheers
Current builds;
Completed:
Done a little bit more, intermediate blue on the other wing and a coating of white
had to stop as I'm having trouble with the airbrush clogging up. So it's having a full clean with the parts soaking in cleaner fluid.
Thanks for dropping by and the 👍.
Cheers
Current builds;
Completed:
Airbrush clogs most usually come down to the ratio/mix of paint to thinner. With acrylic paints, a flow improver additive is sometimes needed to stop needle tip drying. Play with your mix ratios on scrap until you find the correct mix. It's a problem that happens to all of us, particularly when you go from one brand of paint to another because each have their own peculiar quirks it seems to me.
That soft line between colors came out really well.  Nice job on this one!
As much as I like using Vallejo, I have issues at times with the nozzle getting clogged.  Flow improver and thinner help a lot.  Also, make sure you really clean your airbrush.  Vallejo I think leaves a trace amount of clear residue that you might not see.  So, you think you have your airbrush cleaned out (needle, nozzle, etc.), but it's still a bit clogged.  I try to remember to spray water to test if the nozzle is clogged before filling the paint cup, but I forget sometimes and it's a pain to then have to dump the cup, and really clean things out if it's clogged.  Using something like a bit of lacquer thinner will really clear things out.  It could also be older paint that has just clumped a bit.
I thought I was having the same problem this morning. I would get a short puff of paint from the sir brush and then hardly anything. I cleaned the nozzle a number of times and then gave up and stripped the airbrush and cleaned it. After three cleanings it still wasn't getting any better. It was then that I noticed that I had somehow accidently screwed the shut off valve in the quick disconnect almost fully closed. 😁
Alan
It happens to the best of us brother...
Quote:
Small update, after rereading EG s post on the interior colour and the discussion over on Doc Robs tamiya corsair log, 20221030_204444.thumb.jpg.871716100af01cc240b3801a942cb1a5.jpg
I did a repaint on the wheel wells.
This my version of salmon pink, one part tamiya flat red to 3 parts tamiya flat flesh.20221030_213351.thumb.jpg.5ee57e3f710f16b74c5af32cbf781667.jpg
Whilst painting the wells, the repair to the hinge I'd done decided to fail😶😬😔 so now the wings will be glued in the down position 🤦‍♂️🤷‍♂️
Thanks for the likes and comments.
Cheers
Current builds;
Completed:
That's actually a very very good match.... And the only place you will see it without panels removed.... And, after mid '43, they went to hard shell gloss white for all landing gear bays... It was easier to spot and clean up the hydraulic leaks...
Quote:
I've been plugging away on the little bits, like the wheel well doors and touching up the paint.20221112_122417.thumb.jpg.53a07337672607a719bdd94b11b83a69.jpg
the engine is fitted. 20221112_122430.thumb.jpg.a7a77c26bfe1b00ae011a67b3c88a6f5.jpg
Prop on a dry run20221112_122511.thumb.jpg.77f919c6c111108ec48839b84ab98b09.jpg
just a few little bits to do and soon the canopy will go on!20221112_122354.thumb.jpg.7f6f5051f130a79a5bf0726677a7d0f1.jpg
a reminder of the cockpit before it is never to be seen again!!!!
Thanks for looking in, the likes and comments.
Cheers
Current builds;
Completed:
Still doing the tidying up, paint touch ups etc..
Started to put the decals on20221115_170310.thumb.jpg.e51bb99f895b6b2fa5a09fa603fbd242.jpg
Cheers
Current builds;
Completed:
