You should place a small piece of paper with your name and  ship essentials so some future historian can "discover it" in 100 years. A couple of these have been found in contemporary Navy Board models and are of great historical significance.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
is a good idea, but one must hope that the model survives and is appreciable.......
I could put a "skeleton" in the wardrobe! 😄
Hi Giampie -Fabulous work as always - Looking forward to your next post and seeing my first ever 1/36 skeleton - let me see... an average femure diameter say 2.4cm at 1/36 about 6.6mm "No Pressure" 🙂  Cheers Pete
Edited by PeteB
That was a tough call on whether to hit "Wow" or "Laugh".  The work is a "Wow"....
There are no words.  Your work is amazing, working cabinet drawers and door that are then covered by a deck…..
Really outstanding!
Regards,
Glenn
Current Build: HM Flirt
I have noticed more and more uses of two different species or the same species but from different billets to give a contrast when next to its adjacent piece.  One example of this is in the construction of the partners.  This really shows of your very fine workmanship and I plan to use this on occasion in the future.
Allan
Allan
Thank you! I'm happy that I can be an inspiration for your work. Luckily I found two supplies of pear wood with different shades, so I can play with the contrast between colours, highlighting neighbouring pieces!
Great model progress and very high quality skills as usual.  I am assuming that this room that you showed us today is going to be the pump room. What advise would you suggest for someone like me new to using chisels for modeling?? Thank you so much.
Brian D.
This is the sail locker, not the pump room.
I don't have a lot of experience with chisels, but lately I've been learning to use them and I must say that the feeling is very good, so much so that I prefer to do some work with these hand tools rather than with the milling machine.
The very important thing is to keep the chisels perfectly sharp at all times. and this can be achieved in a variety of ways, some of which are well explained in tutorials on you tube.
In addition, chisels must be of high quality, so it is better to invest a little more money in better tools than to make do with poorer tools that will soon lose their sharpness and ruin our work.
The kit of mini chisels of Russian origin that I bought a few years ago and that you see in the photos is really excellent and helps me a lot in the small joints that you can see in the construction of the decks.
Translated with www.DeepL.com/Translator (free version)
Your joinery is exceptional.  You have mastered the use of chisels.  I am enjoying your build.
Ryland
               - Nautical Research Guild
Brian D.
Actually Brian I believe this is to be the sail room. The ventilation louvers would facilitate air circulation and help dry out stowed sails.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
