HMS Winchelsea 1764 by glbarlow - 1:48
1 hour ago, Blue Ensign said:
I'm feeling inadequate.
Thank you BE, I feel that way a lot when I see the work of some others, including yours.
Side note, when my mini-chisels are too big I turn to the Swann Morton surgical chisel blades I picked up after seeing your use of them. They do come in handy.
Edited by glbarlow
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
Wow. Just wow!
(That's me being speechless too)
Edited by DelF
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Link to comment
4 minutes ago, DelF said:
Just wow!
Thank you Derek, I say that a lot with your work.
A side note, I use (and keep sharp) my Veritas chisels so much now, so thanks for both the lead on tools and the Kell sharpening wheel. I’d be lost without them.
Regards,
Glenn
Link to comment
Some of the best planking I've seen 🙂
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Link to comment
The stern post transition is absolutely superb, I totally struggled with that part.
As has been mentioned several times, very clean, precise planking! Always a pleasure to read your updates Glenn
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you for saying so, I appreciate it.
1 hour ago, Seventynet said:
Lovely clean work
Thank you, if only my work shop was remotely clean now 😄
Thanks. I definitely struggled, now if I can only remotely match it on the port side.
Regards,
Glenn
Link to comment
1 hour ago, FrankWouts said:
Beautiful progress
Thanks Frank.
On 4/27/2022 at 10:38 AM, Trussben said:
very nice work
Thank you!
Regards,
Glenn
Link to comment
I'm just getting caught up and echo all the previous comments.  Unbelievable work!!
It helps to see how the bow and especially the stern counter should be planked.  I'll never get anywhere close to this good, but it gives me something to shoot for.   I absolutely love the look of Alaskan Cedar.
David Salguero
Wichita, Kansas
Current Build:  Royal Yacht, Duchess of Kingston - Vanguard Models
Completed:  US Syren - Model Shipways
On Deck:  HM Cheerful - Syren Ship Models
Link to comment
Thank you.  What I know I learned from others and improved by doing. I too have a lot to improve, especially with the stern.
Regards,
Glenn
Link to comment
The slow work of planking continues, now with the first port side belt completed to go with 16 starboard rows.
Just a couple of progress photos. No WOP at this point and only preliminary sanding.
I’ll do the next port side belt then work from the keel up after that.  Here a plank here, there a plank there, everywhere a plank plank.
Thanks as always for your comments and likes
Regards,
Glenn
Link to comment
Hi Glenn, your planking is incredible. In a couple of posts (171 & 194) you have more than one strake going at a time. Are there advantages to this  or is it just because she is just so big?
Regards……..Paul
Completed Builds   Glad Tidings Model Shipways. -   Nordland Boat. Billings Boats . -  HM Cutter Cheerful-1806  Syren Model Ship Company.
Link to comment
Although it may be more of a mental advantage it helps me make sure I’m keeping tight rows and that I’m keeping the plank shift pattern as I go up (or down).  Mostly though it’s so I can focus on the bow and the stern for a while to keep them consistent since both are different challenges.
And it’s a really big model😳
Edited by glbarlow
Regards,
Glenn
Link to comment
1 hour ago, westwood said:
Nice progress
Thank you, I enjoy following yours as well.
26 minutes ago, BobG said:
Perfection
I wish.. but thanks Bob.
Regards,
Glenn
Link to comment
AND Planking Continues …
I started planking in early March, and I’m still and it and I’m still not done and I still have more planking to do and I’m having so much fun... I’ve now completed 16 strakes both starboard and port - with 8 more to go on each side.
It seems like these, plus my travel iron and craft hot air gun are the only tools I’ve touched in months, probably because they are. I do spend a lot of time with my Byrnes collection of saw, disc sander, and thickness sander so there’s that.
I’ve always been comfortable tapering planks with a metal ruler and a sharp object, with the longer planks required for Winchelsea I added a separate cutting mat along with double sided tape. I put a strip of the tape on the mat and stick the plank to the tape - it doesn’t move while I’m sliding the blade along the tick marks I’ve transferred from the ship.
I have the problem of being somewhat of a perfectionist and not being very good at my job - the result is a lot of wasted wood from rejected planks and excess. I was feeling bad about this until my wife walked in the shop, looked at the pile and said “We’ll have some great summer projects for the grandkids using these.” I looked up and said “Of course, that was my plan all along.” We’re going to Alaska on a cruise this fall, I plan to find an Alaskan Yellow Cedar tree and apologize for how much of his brethren I’ve wasted.
The port side bow has turned out ok so far, it’s nice because it’s more or less measure, cut, fit. It’s still 'every plank’s a project' with the bending, fitting, edge softening, and gluing - each plank can take up to an hour or so to make. Then of course there are the repeats when that doesn’t work … grandkid projects I now call them.
Remarkably both sides look more or less the same in this view I’ll likely never see or notice once the ship gets turned right side up, but still.
There was so much excitement at reaching this stage a guy with a mandolin came by to play a few tunes.
I’m not as concerned with the variances in the wood color, for one thing there are different number of coats of WOP, the port side has only one. The AYC soaks up the first coat like a towel.  There will be more light sanding and more coats of WOP before I call it done. Plus, as I see my Cheerful on its shelf everyday I know somehow this nice wood just evens itself out over time. I probably should have milled all the planks at once, thrown them in a pile and used whatever came out first, rather than try matching as I’ve done, and not done well. In fairness it changes a lot with that first coat of WOP.
Then there’s the stern - Planks at the bow make take an hour or two, midship less, but these stern planks starting at the turn to the stern post wore me out. I really struggled with the stern on multiple levels.  One plank might take me a day to get right. I’m fortunate these aren’t very heavy, so they didn’t do much damage when I flung the rejects against the wall.
In another macro view I won’t often see it’s somewhat a miracle both sides are near equal.  At least unlike the starboard side and the multiple rip and replace I didn’t have to repeat that for thr port side, so I must have learned something along the way. It is nice to know the counter will be covered by a frieze and a moulding strip eventually covers the seam.
I’m still not that happy with the stern, but I got there - it is in fact a stern. Even with wider planks and knowing I’m on the tick marks it looks like a lot of ground to cover at the stern post with just eight more strakes to go. I’ll make it work, that’s what wider planks are for.
More and more it looks like an actual ship.
With that it’s time to reverse course and start down from the keel, so next up are garboard strakes.  By my estimation (and no I’m not going to count them) with 32 strakes done below the wales and about 3.25 planks to a strake (depending on the butt pattern) I’ve added over a hundred planks and have about half that still to go…but who’s counting. Of course that’s not counting rejects, I mean grandkid summer project material. I’m just taking it slow, admiring build logs of those who have a deck, and working it a day at a time.
Thank you for the follows, likes and comments - it really helps keep me going - one plank at a time, then another plank, then another plank……
Edited by glbarlow
Regards,
Glenn
Link to comment
That looks great.  Dont worry about the color of the cedar varying.  It will deepen and even out.  My winnie hull is a completely different color now vs when I finished planking.  It really mellows.
Link to comment
Thanks Chuck,
Yep, my Cheerful looks completely different, and better, than when I finished it.
Regards,
Glenn
Link to comment
Truly a thing of beauty - even a perfectionist like you must be delighted at your achievements. The sweeping lines of those planks really enhance the beautiful shape of the hull.
We're also cruising there in late July, early August. I'm taking a saw to bag me some of that cedar😁
Cheers, Derek
Link to comment
13 hours ago, Oldsalt1950 said:
Outstanding
Thank you for saying so.
13 hours ago, Seventynet said:
That AYC sure is beautiful.
Thank you, it really is a great wood for modeling.
Regards,
Glenn
Link to comment
Thank you. I am happy with how it’s going, but can’t help seeing every flaw, no matter how small. Into my third month planking I’m kinda ready to be done though.
So you check one of those hard shell golf club carriers empty and bring it back full, no one will notice a thing🤣
Regards,
Glenn
Link to comment
Your planking is coming along absolutely gorgeously.
You'll soon be starting chapter 3 and then I can follow your example.
Current builds;
Completed:
Link to comment
10 hours ago, Edwardkenway said:
starting chapter 3
Thank you, I’m looking forward to moving beyond planking.
Regards,
Glenn
Link to comment
Once you complete planking things really start moving quick, especially if you are still working on planking mode!
Current Builds: HMS Winchelsea 1764 1:48 - 5th rate 32 gun frigate (on hold for now)
Link to comment
