Thank you Nipper and Allan.
@ Nipper - Nice of you to say so, but I don't think I deserve mention in the same company as Chuck, I might qualify to sweep up in his workshop, and I'd be happy to do that just to watch him. (Can you tell I'm a fan 😄)
@ Allan -  I'm using 0.6mm stuff which equates to 1½"  about right I think. The side stops are fitted on the bottom stop, which I find easier to do.
Cheers,
B.E.
Post Thirty-five
Port Lining continues.
I am using 0.6mm Boxwood (10mm wide) to line the remaining gun-deck ports.
If nothing else it will provide a smoother finish than sanding the mdf /lime/pear/ sandwich which make up the bulwark.
1025
The bottom layer goes in quickly using the kit part as a template, and simply requires trimming on the inboard side.
1021
The kit part 549 was used as template for the more complex side pieces. This was simply transferred to the Boxwood strip and cut to suit.
1023
The ports were re-taped for painting.
I think I should buy shares in Tamiya tape, I use so much.
1037
1035
1043
1027
1032
The whole process went more quickly than I had initially thought, four days to line the ports and apply a couple of coats of paint.
A few ports will require a little more attention, but that is something I will return to, as is attending to the inner bulwarks.
Onwards to sorting out the wales.
B.E.
06/06/2023
looks very good B.E.
Nils
Current builds
-Lightship Elbe 1
Completed
very nice indeed
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you, Nils, and Kevin, and for the ‘likes’.
Post Thirty- six
The Black Strake
My plan is to fit the wales, followed by a drop plank, followed by the Garboard plank, followed by lining off and planking the remainder of the hull.
If only it was as simple as those few words.
The first task is to fit the Black strake which will fix the line of the wales.
For this I am using 0.8mm x 4mm Pear.
1061
The kit indicates use of 1mm pear, but I used 0.8mm as I think it better reflects the subtle difference in thickness between the wales and topside planking.
1059
I used Vallejo black to colour the strake before fitting but may tone it down using Black/grey, depending on the overall effect.
1056
Masking tape was used to mark the upper line, and Ca was used to apply the strakes.
1048
Onto the wales and a somewhat trickier operation.
B.E.
07/06/2023
Post Thirty-seven
Onto the Wales - The approach.
1062
A master plank was cut from some 6mm x 3mm Boxwood sheet. This will be used as a template to cut the planks.
1064
The planks are of a scale 120mm in length.
The touch 30mm in from the end. (¼ of plank length)
The touch depth is 2/3 the depth of the strake (8mm) = 5.33mm.
The butts are ½ the depth of the touch =2.66mm.
To make the measurements easier I used a touch of 5.5mm and a butt of 2.5mm, easier to see.
1068
A simple jig was made to hold the planks for marking and cutting.
1066
1070
I used 6mm x 1mm strip to form the planks.
1071
The trick is to ensure that all the joints will meet cleanly.
1073
Once the top wale strake is in place things will be easier, but the fit will be tested before gluing into place.
I now need to cut around sixty planks – what joy!
B.E.
08/06/2023
Nice work on the wales. I’m personally left wondering though, what a Hoggs of Fife country shoe must look like😊
Regards,
Glenn
Current Build: HM Flirt
Post Thirty-eight
Main Wales
With a supply of planks cut, application can begin.
1077
I start at the bow with a full-length plank, touch end to the stem. The planks will continue in this sequence to the stern.
1078
Below this a shorter plank starts at the touch and runs to the stem.
The total depth of these two planks must be 8mm.
1079
I work both strakes sequentially as I go along, making minor tweaks as necessary.
1082
For the lower set of strakes I begin with the touch end starting midway along the foremost plank above it, to create a shift in the butts.
1085
This second set also starts with the straight edge upwards and continues in the same manner.
1093
The final plank of the lower strake is shaped to follow the curve of the hull and will be finally fettled as the wale is shaped to follow the transom line.
1090
Two days work and the Starboard side wale is completed. A lot less fiddly than Hook and Butt but still gives a more authentic look than straight plank Wales.
1099
The overall depth of the wale is 16mm around 3’ 4”.
This is deeper that the kit wale by 1mm but is still slightly less that the depth given by Goodwin for a thirty-eight-gun frigate of 3’ 6.”
1098
1100
The wales will be cleaned up after the Port side have been fitted.
B.E.
10/06/2023
Very nice work Maurice.
I used this technique on the wales for Fly but I cleaned it up so well that after painting them black the jointing was invisible! Be careful of that.
Cheers
Alistair
Current Build -
that looks fantastic
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi B.E. I just spent a very pleasant time catching up on your build log. Very well done!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Cheers Guys, thank you for your comments, and ‘likes’.
@ Alistair, - it’s a fine line (no pun intended) between showing the plank lines, and what looks like a poor fit. Worth doing regardless, as I know it’s there, and hopefully there will be sufficient lines showing thro’ to indicate the planks.
022
If I can achieve the result I got on Pegasus I will be satisfied.
Looking out this photo I am reminded it has been twelve years since I last did a Top and Butt wale, where have all those years gone!
B.E.
Post Thirty-Nine
Completion of the Wales.
The Port side planks were fitted without issue; the plank jig allowed for quick reproduction, and using ca, fitting was instant.
I dampen the planks before applying the ca - it aids rapid grab.
With both sides completed the hull is again inverted for finishing.
1107
The tricky part is the stern counter where the aft end of the wale is shaped for the round of the hull, and to follow the curve of the counter.
1112
It is important that there is a smooth transition between the lower edge of the wale and the plank below the wale that runs into the lower counter. All following planks of the second layer will follow this line.
1124
1125
1122
1121
1115
1120
I think there will be sufficient plank line definition to give a subtle impression of the Top and Butt once the wale is painted.
1118
I have moved quite a way from the oob sequence.
For me the result is worth it, and by fitting the wale before the lower second planking I have the opportunity to work a Drop plank below the wale.
Onwards....
B.E.
12/06/2023
Post Forty
 Drop planks at the Bow.
These are a feature of ships of the period and generally appear immediately below the wale.
They are a nice feature on a model, and installing a drop plank should help prevent overcrowding of the strakes at the bow as planking proceeds.
1131
Where it meets the stem I have tapered to 4mm, which is 1mm less than the full single plank width.
The taper was determined in the usual way using a single  5mm plank which was then use as a template on a 10mm plank.
1127
The body of the plank must be broad enough at the aft end to take account of a tapered plank that butts against it and runs beneath the wale.
The tail of the Drop plank also must run to meet a full width plank of 5mm, following on and running towards the stern.
Together they form the first two strakes beneath the wale.
I couldn’t find any specifics about the proportions of drop planks between the body and the tail, so this is my best guestimate.
1128A
These are the dimensions I used.
The drop plank width is 4mm at the stem, 8.5mm at the aft end of the body, which is 55mm long, and with an overall length of 120mm.
1132
1133
1140
1148
1142
B.E.
14/06/2023
Thanks B.E. for your detailed explanation.  I've marked this ready for my next planking job - it will make my next model better, more realistic and more satisfying.  As ever, your meticulous thinking, planning and execution provides a guide for the rest of us.
Nipper
Current build:  HMS Sphinx 1775 - 1/64 - Vanguard Models
On the drawing board:  Dutch brig "Irene" 1815 - 1/64 - based on HMS Cruiser - Caldercraft
Completed build:  HM Cutter Alert 1777 - 1/64 - Vanguard Models
Post Forty-one
Garboard Planks
The two strakes below the wale are completed before I move onto the Garboard.
1152
These were fitted as individual planks, and attached using ca.
According to the Construction and Fitting of the English Man of War (Peter Goodwin) the width of the Garboard Strake is 2/3 the moulded depth of the keel which would be 6.5mm at scale.
At midships the depth from drop plank strake to keel is 141mm
On paper this represents 28.2 number of 5mm planks.
1168
I have opted to round up to 7mm wide strips for the Garboard planks which I think better shows the difference to the usual hull planking.
1166
I next added the strake above the Garboard.
1161
1157
1165
At last, I can now move onto prepare for the remainder of the hull planking.
B.E.
15/06/2023
Post Forty-two
A bit of a set back
What I feared may happen with a hull this size has happened.
Manoeuvring to check the lining off resulted in the hull toppling off its support with the stern crashing against the wall.
1185
The stern frame bracing has buckled, and one of the mdf stern frames split.
1186
The Upper stern pattern above the gallery has been split.
1187
1188
I’m bloody annoyed with myself letting this happen, but pva and clamps should sort the issue.
Not a good start to the day.☹️
B.E.
16/06/2023
OMG, I can feel with you B.E. after that crash, but now your putting in all your experience and skill to mend it well,head up....
Nils
Current builds
-Lightship Elbe 1
Completed
Ouch. Tough way to start the day but I know you'll get it all sorted out!
Rusty
Apart from the buckled MDF part, I also banged the back side bulwarks and split one as you did.
Annoying (especially in this heat!) but nothing major.
Ongoing:
Sorry to hear of the accident.   I find that it seems to be rite that there's at least one "oops" moment for every build.  Luckily, as in your case, the damage was fixable.
2 hours ago, Blue Ensign said:
Cheers Guys,
The repair seems to have held, but work is now suspended for a week whilst I enjoy a week  in Dorset. An opportune time for a break,  in the better sense of the word, I think.
B.E.
enjoy the break, and glad the repair has held
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Sorry that happened, just another opportunity for creative problem solving. It seems you already have it well in hand. Enjoy your week off.
Regards,
Glenn
Post Forty-three
The Preparation
I have (26) 5mm planks at midships which are marked off on the hull using a tick strip.
I intend to work a first band of six strakes below the existing planking, and I’m looking to have the plank ends at the stem not less than 3mm in width.
With this in mind, I apply the lining tape.
1173
1179
The first application of the tape, now the tweaking begins.
In these shots the upper tape marks the line of the first section.
I am aiming to get a smooth sweep up to the stem using edge bent and tapered strips only. I hope to avoid the need for spiling except perhaps when I reach the under belly of the hull.
The trouble with lining off is deciding when it is at its optimum line.
This process is more art than arithmetic and I find myself in an agony of indecision wondering whether I have reached that point.
Using strip wood there is inevitably error creep strake upon strake, so I will fit the first section and then recalculate.
The following photos show the point where I think I am getting close to an acceptable run.
1191
1193
1195
1199
1212
1205
1207
1203a
I think it needs a slight tweak as indicated.
1216
This looks better to my eye.
I can now proceed to mark off the strake widths at each bulkhead point and begin planking.
B.E.
27/06/2023.
