Hawker Hurricane Mk. I by ccoyle - Halinski - 1/33 - CARD
Gonna have to sideline this build for the weekend, but here's a quick update. The patch has been made (it's ugly), the aft fuselage completed, and the vertical stabilizer added.
I'm getting a little itchy to get back to Phoenix. 😬
When you have to shoot, shoot. Don't talk.
- Tuco
Current builds: Brigantine Phoenix, Hawker Hurricane
Link to comment
Share on other sites
Now  that  is  taking shape   -  lovely job  Chris.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
It is anyway a good save! No kit left behind.
Dan
Current build : Mayflower - AL 1:64
Completed non-ship builds : Spitfire MK I - 1:48Arado 196B - 1:32, Sea Fury - 1:48F-15C Eagle - 1:48Hawker Tempest Mk.V - 1:48F104S Starfighter - 1:48
Link to comment
2 hours ago, ccoyle said:
 The one-piece stabilizer fillets were a real booger!
But for you, obviously, it “snot” a problem! 😁
Looks great! The fairing on the underside was to help with spin recovery.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Link to comment
And now we commence with the wing, starting with the skeleton of the center section.
Next we start on the landing gear bays, which are NOT simple -- gotta pump myself up for that sequence! 😯
- Tuco
Link to comment
The directions next call for the skinning of the central wing section, but I decided to slightly deviate from the suggested sequence. By assembling the entire wing skeleton first, I hope to produce some better seams between the center skins and outer wing skins.
- Tuco
Link to comment
So, I started skinning the center section.
Of course, in my haste I forgot that I hadn't yet installed all of the gear bay parts, but hey -- who doesn't like a little more challenge, right? 😑
- Tuco
Link to comment
I got the missing gear bay pieces in. It was exactly as much fun as I thought it would be, i.e., none. 😑
I also got the wing skins cut out, edge colored, and shaped. Here they are for a preliminary fit.
They will need landing lights installed before being glued on. Strangely, the diagrams also show inner sheaths labeled as part S -- the main spar is even recessed to accommodate the extra layer of paper. But there are no parts S in either the kit or mentioned in the instructions. I will probably go ahead and add something like them anyway to increase the gluing area.
- Tuco
Link to comment
The right wing is now skinned. I will not be showing any close-ups of the finished wing tip -- if there is a pro technique for doing those neatly, I have yet to discover what it is!
- Tuco
Link to comment
Okay, wheels weren't actually next!  The instructions called for mating the wing and fuselage, followed by adding the wing fillets. Here's the left side done, with the parts for the right side for comparison.
- Tuco
Link to comment
Small update . . . I finally had some time (and mojo) to work on the landing gear. Here's the parts for the main struts, their wire innards, and the resin wheels (with some preliminary painting done).
And here's the main struts rolled and the inboard sides of the wheels done. There are some residual pock-marks on the wheels, which I do not intend to fuss about, as they are not ginormous. Well, maybe I'll fix them -- one never knows. I've applied a couple of washes to the hubs to try and grunge them up a bit -- they effect is more noticeable in real life.
Still lots more to do.
- Tuco
Link to comment
 This paper modeling biz amazes the heck out of me. Nicely done, Chris.
Link to comment
Not much time for modeling the last couple of days, but I did take a moment to dry fit the gear struts to make sure they fit properly and are the correct length. Everything looks pretty square from this angle.
- Tuco
Link to comment
The struts are on now -- no doors yet. Each strut and wheel consists of fifteen parts. The end of this build is coming slowly into view!
- Tuco
Link to comment
The gear doors are on. They have some fit issues that are nicely hidden in the photo -- they look fine, but some of the dimensions and angles are off.
- Tuco
Link to comment
Here's a question for all of you true Hurricane know-it-alls out there. On the underside of the port wing fillet is a very small, oval structure, as seen in the image below:
The kit provides parts for it, but I have no idea what it is. Possibly a step rung? Photos differ on its shape, and some aircraft appear not to have the thing at all. Whatever it is, it appears to be overlooked on many models.
Anyone able to shed some light?
- Tuco
Link to comment
Not sure  what  its  for  Chris  -  but  checking my  airshow  pics  I can see  its  just on the  one side.
OC.
Current builds
Completed works.
Link to comment
I’m fairly certain that’s a retractable step. You can see it here in the deployed position.
Andy
USF Confederacy
Link to comment
You gots a PN brother...
According to my references yes, it is the retracted version of the access step, the reason it is not covered by most model kits is it is flush and practically invisible in it's in flight retracted position...
Also when on the ground, it is usually in its deployed position as seen on the USAFM's Hurricane, (thanks Andy) although you will see pics of it released but not fully extended... Looks like a little oval bump... with two edges/ridges across the top lengthwise...
Quote:
Link to comment
Hi Chris,
it is a rectractable step that was unblocked by operating the lid of the hand handle. Closing the lid, the step would retract by the action of springs. So, step down with hand lid open and vice versa.
Dan
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
