A few simple sketches to show the details.
A and B.   Bow sprit cap fitting on the tenon
C.    A flat base added on top of the bow sprit.  One can simply plane down the top of the dowel, but the added base makes a more secure attachment for the bees.
D.    The "bees" are added to each side.
E.    Finally, cheek blocks are added to each side, which receive the fore topmast stay and preventer.  Slots cut in the base for access to the cheek blocks.
Completed bow sprit. Top view
Side view
Close up
A few more photos follow to put it in perspective.
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
Completing the bowsprit.  The jib boom passes through the round hole in the cap.  The flying jib boom base is beveled to fit the forward face of the cap.
The flying jib boom is supported by the jib boom.
Much later, netting was added. (Details of the netting are shown on page 3)
The bow sprit cap seen on the real ship.
And on the model.
I hope this makes sense of the original photographs.
Cheers, Gil
Great work you are doing on this ship :)
I am also working on a Victory.
I do have one question: Do you made the ship wheel and binnacle by yourselv
or was it some parts from a set?
I don´t have them on my set, and still looking for some drawing in order to make them.
Will appreciate your help if you can :)
Best regards
Philippe
Michael and Lawrence, Thanks for your visit and kind comments.  My apologies to all our friends whose logs I haven't yet visited.  We're still settling in and time at the table is somewhat limited.
Philippe, The fascia or veneer of the binnacle was part of the JoTika kit as were the wheels. The compasses were added for effect, as were the deck braces and ring door handles.  I'm not sure other photos would be helpful. What kit are you working with?
From the real ship, the wheel with the angle iron deck support and binnacle with compasses, ring door handles, etc.
post-68-0-58996100-1413498518_thumb.jpgpost-68-0-35177000-1413498582_thumb.jpgpost-68-0-52202400-1413498635_thumb.jpg
And from the model, the binnacle and wheel.  The wheels assembled on a dowel, angle support iron added (not in the kit).  Building the binnacle, fascia supplied, compasses added, and a dusty binnacle.
post-68-0-78296700-1413498874_thumb.jpgpost-68-0-46549700-1413499011.jpgpost-68-0-35421800-1413499284_thumb.jpgpost-68-0-90059600-1413499370_thumb.jpg
Hope this helps.  Gil
Davit attached to hull.
Line weighted to create curve in jackstay. (Fast C/A between clamps, Clamps moved and second application of C/A)
Forward hinge at hull
Topping lift
Tackle for cutter
Aft block and hook
Haven't built the boats yet, but I'll have to study Grant's lovely cutters, pinnace, etc.  Cheers, Gil
Topping lift
Lines left to right, guy, topping lift and jackstay
Termination of topping lift from block on mizzen mast through block on deck ring
Beautiful work, Gil.  The first two pictures of the davits installed had me believing they were of the real thing.  Then... the clamps and workarea put it all in perspective.  :)
another mini project finished, another step closer to completion, wonderful
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Wonderful updates !
Love it, Daniel
Kevin and Augie, Many thanks to you both.
Mark and John, if any part of the model begins to look like the real thing, I'll be delighted.
Thanks Daniel. I promise not to mount the anchors until I have thoroughly perused your postings. So many ideas and useful tips.
And when I start on the boats Grant, your log should save me from false starts and problems in construction.  Although I'm rather intimidated by your results, I'll try to come close.  Gil
Hello Gil...
I haven't had a chance to welcome you back since i've had several life (and death) incidents the past few weeks.  All is well and back to normal now.  I am in the middle of constructing the ship's boats also but wanted to reach you to say thank you once more for the amazing photos and help you have offered to all of us.  Good to see you back again.
Jerry
Moving to the port davits.
Making the falls (tackle) for the port davits.
I've chosen to display the port davits in the inboard position, while the starboard davits will be in the launching mode.
Note the slack topping lift.
Topping lift tensioned with weighted clip.
Lift sling, jackstay and guys treated with fast C/A to hold shape.
Weighted clip (Battery cable end filled with solder and tied to the mini clip.) These can be very helpful, placing light tension on lines during rigging.
Cheers, Gil
Attaching the anchors.
From left to right, a double block as supplied, a triple block shaped and a tripple block stained, stropped, with steel becket and anchor hook. I should have added holes in the upper part of the block to look more natural. On the starboard block, (the display side) those holes and carved slots will be added.
Preparing the anchors.  These were previously covered in Section 13, page 3, post #39.  I plan to display the port best bower anchor in the stowed position (after McKay), while the starboard anchor will be suspended by the anchor block from the cathead.  This conveys even to the novice, the function of the cathead.
post-68-0-93611800-1414534872_thumb.jpgpost-68-0-90137300-1414534900_thumb.jpgpost-68-0-27860900-1414534916_thumb.jpg
Creating an eye splice from a line to chain, to support the stowed anchor.
post-68-0-84927300-1414535133_thumb.jpgpost-68-0-67492200-1414535163_thumb.jpgpost-68-0-73894300-1414535184_thumb.jpg
Continued in next post
Anchor tackle at the cathead with the anchor ring in the hook. The line seized to the hook is the messenger to bring the block to the haus hole for retrieving the anchor.
post-68-0-32121400-1414535597_thumb.jpgpost-68-0-27011300-1414535621_thumb.jpgpost-68-0-61210700-1414535641_thumb.jpg
Anchor ring hooked with the messenger line seized to hook.
Stowing the anchor.  Chain supporting the shaft.  Anchor ring still supported by the cathead tackle hook.
Another post follows
Edited by gil middleton
Final steps in stowing the anchor.
An eye splice for lashing the anchor ring to the cat head.
Anchor ring lashed to the cathead.
Cathead tackle shifted to a sling on the anchor shaft.
Anchor in the stowed position.
post-68-0-35726600-1414536345_thumb.jpgpost-68-0-04438600-1414536372_thumb.jpgpost-68-0-09783200-1414536394_thumb.jpg
Next up.  Fastening the cable to the anchor.
Gil
Impeccable work Gil. So much information here for the builder of any ship. Thank you!
Cheers
Alistair
Current Build -
Gil, you're the man even though you're my age.  LOL
Jerry
Edited by Jerry
good morning Gil
lovely work
is the wood pad fitted to the hull or to the anchor where the fluke butts up against the hull
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
such beautiful work Gil...........glad to see you back!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I have to agree with the majority.  Your log is  great read.  If I was a publisher I would put out a book titled HMS Victory a practicum on Jokita's kit of the Victory.  Tips and techniques to successfully build it and have fun.
David B
Are we having fun yet?  Thanks to you all for your comments.  Alister, your "Fly" is a work of art. I enjoyed going through your log. Grant, Many thanks. Glad you still have one foot in the "kit" world.  David and Jerry.  Let's see. If we sold twenty copies at a two dollar royalty, we'd be wealthy??????  Mike, Great progress on your "Unicorn" (AKA "Lyme").  Daniel and Popeye, always a pleasure to see your interest.  And Kevin, the block is glued to the ship.  If it were fixed to the anchor, I'd be afraid it would foul the chain plates when positioning the anchor.  Cheers, Gil
