Ben,
really nice progress.
Regards Christian
Stop counting.!!!   She looks TERRIFIC!
If he didn't count, we'd  think it odd that there was a large hole in the middle.
Ok. seriously nice work, Ben.   Looking superb.
Looking great Ben. I remember how tedious the framing was on my KF and I allowed myself the occasional break to make a sub assembly of some kind for use further down the road. Hang in there you are nearly there.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Looks fantastic.  Make sure you get in there are fair the hull while there is still an opening to get your arm into.
Toni
Member IPMS
                           Utrecht-1742
In addition to Toni's kunckle-saving advice please check those frame/station lines as you close her in. I found that I had to rejig a few frames around the dead flat due to cumulative error. You can modifly the fillers a bit to compensate if necessary.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks all,
Toni - you hit it! I intend to do just that before any more frames go in - thanks for the reminder.
Greg - my Mentor gave me the same advice so I have already been compensating for creep with every square frame I put in, measuring from dead flat marks on keel to the face of every frame, changing thickness of fillers to achieve it.
I've found as much as a scale inch that I've had to compensate for, room and space says they should be 4" but Ive had between 3" to 5"
Ben
Edited by Trussben
The framinglooks really well aligned. Superb work, Ben
Regards Christian
Thanks everyone and the likes.
The 7 frames to go are only the square frames remaining, there is still a lot of work around the stern framing to be done and then all of the fairing and clean up work before the milestone is passed.
Greg - I still don't have a finalized idea of how much planking will be done on exterior, I can say for certain that I won't be covering up much of the framing that I have worked so long to make, but still undecided.
Ben
