Looking very good, Ben.  And as for the "messy workarea"... HAH.. that's not what most of us would call "messy".
Gotta agree with Mark on this one Ben. That looks like my work area AFTER I've cleaned it up.
Hi Allan - My plan was to add the ports as I go along ( same way described in TFFM and how Danny did it ), on my Echo I did them afterwards and I had issues getting good joints by fileing the birdsmouths in. Cutting them off the model with a sharp chisel sure does make nicer and tighter joints but I hear what your saying about getting a better run of the ports by doing later, I feel that the aft port is in the right place compared to plans, measured lots of times.
I will have to think about these pros and cons. :huh: ( aka - about to send yet another e-mail to my Mentor! ).
Thanks everybody else for making me think that maybe I'm not as messy as the Admiral would lead me to believe. :P
The long dreaded bollard timbers are next - I can see a few do-overs in my future with these buggers.
ben
Hi Ben, very nice workmanship! Hey if you can get it to work cutting notches off the model then well done. Me I
had to do them afterwards to get them straight. Good luck on the bollard timbers! I'm sure you'll do just fine.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
From personal experience, I find it far easier to cut the sill scores before erecting the frames. The drawback is that one needs to be exceedingly accurate in the positioning of the frames vertically. If 'off', it will throw the line of the ports out of whack.
The reasonable compromise is to temporarily erect the frames, mark the sill line out, take the frames off and then cut the scores to the mark-out. After permanent re-assembly everything should line up perfectly.
Small silly point: bridle is the word for the foremost port, as in horse's bridle. Not bridal, as for something belonging to a principal player in the cast of a wedding!
Hi Druxey,
The compromise you mention is exactly the path I intend to follow, seems to have worked ok on the port I have done.
As for the miss spelling of "bridle" , I apologise from one English born man to another, unfortunately the spell check on my iPhone is American and auto corrects my queens English lol.
Ben
I cut the sills for the gun ports on Atalanta after all of the frames were erected for fear of having the ports out of alignment.  And overall I am happy with the results.  I was also lucky enough to attend David's and Greg's Echo symposium after the framing was completed.  David showed my how to make the perfect birds-mouth and it looks a lot more refined than my approach.  The next model will be made as Druxey suggested.  The frames that require gun and/or oar ports will me mounted temporarily and the notches cut off the model once all the frames have been erected.
Toni
Member IPMS
                           Utrecht-1742
Thanks for the input Toni.
Started on the parts I have feared most up to now, bollard and hawse timbers, pics show what is my first attempt. On advice from my Mentor I will make and temp install the first cant as that is a good reference to use for the angles.
I may well make V2.0 to see if I can get a better fit.
Ben
Looking good Ben.
Wonderful workbench and matching vise!
I see the chisel but what sort of plane are you using?
Alan
Thanks Patrick and Michael and all the likes.
Michael, there is a harbor freight by Dayton mall on Lyons road, they normally have the benches in stock, look out for coupons on their website, I got the bench for $140 on sale.
There are some good write ups on this site under the tools section stating all of its pros/cons, but for $140 you can't beat it IMO.
Ben
You'll need one extra hand, three more temporary supports and a couple extra tall shots of Canadian Club Classic to get this done!
All joking aside, it must feel great when something so difficult finally comes together!
Alan O'Neill
I don't think anyone gets this right the first - or even second - time around. Eventually you will nail it, Ben.
I find that a heavy card square set up on the board aligned with the layout helps a lot.
As the ever-knowledgeable Druxey suggests, something like this setup works. I use thin ply set up at 90 degrees to the building board (wood triangles glued on back) and a steel square. Place the bottom edge of the wooden angle jig (or card) on the face of the line delineating the fore face of the cant and use the steel square to set the height of breadth. This gives you two points of contact to hold the cant while spot gluing in place. Once it's set you might even drill for the treenails. This way you can easily re-position it later on.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Once again a picture is worth one thousand words!
Alan O'Neill
That's a very handy tip and your photo Ben, makes it that much clearer for those of us who are "spatially challenged"! :)
Atta Boy Ben!
Druxey convinced me to try stiff card stock and illustration board a long time ago.  It is cheap and easy to cut into pieces and make into a variety of jig fixtures.  Ply works as well of course, but more costly and needs more than scissors to cut.  Then again, plywood is likely to last longer for future use.
Allan
Card, ply; it doesn't matter which material the square is made from. The important thing is that it's not made of metal, so that if it falls over on the model it won't damage it.
Hi and thanks for all the likes and tips, got home this afternoon after being away all week and went down to the workshop And made up two plywood squares as per all the advice, they are currently drying and it will be using them tomorrow to try and set up the cants for the 4th time, hopefully they will help a lot.
Ben
So here are my framing squares completed, I decided to add pins to the back so I can secure it in position to the build board without fear of losing it's place, now they can be repositioned back in the exact same place.
I then held them up to the plan and marked the horizontal lines of the breadth lines, then they were fitted back to board and the vertical line of the breadth line was marked up to intersect with the horizontal lines, this gives me a perfect crosshair target of where the frame should be.
Ben
Edited by Trussben
Looks Good Ben
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
