Thanks everyone.
Druxey I had not thought of burs probably because they really have not been part of my modelwork tool chest agency. I shall have to look into what is available from the jewelers tool shop in Edmonton when I have a few pennies to spare. I do have a Dremel with a flex shaft, but mostly it never occurs to me to use it. Perhaps I should do a bit of out of the box thinking and plug it in occasionally.
PS it is still snowing traffic is evidently rather snarly in Edmonton till this system passes.
Michael
Again Thanks for all the positive support and likes.
I mounted the hinges today first on the ridge.  small awl first made a location for the drill and then drilled with the #68 drill mounted in a pin chuck to drill the holes then one of the rivets pushed home.
Once all the hinges were mounted I used tiny drops of thicker ACC glue Gorilla brand to temporarily hold the hinges onto the lights I will wait till the morning before opening them to add the rivets to them once they have set.
The blue tape is just to hold them overnight from sliding until the glue completely hardens.
Michael
Sweet. Masterpiece. I like it!!!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Very nice, looks fantastic
Best Regards,
Pete
Edited by Pete48
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
excellent Fitting on that Skylight Michael,
a wonderful model work of wooden and metal parts
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful light, Michael.
Bob
Current build:  SS_ Mariefred
Beautiful skylight Michael. Impressive scale hinges also. I envy your skill.
Jack
Current buildUS Constellation
again,  your metal work astounds me.......hinges look really neat!   skylight is looking great!  ;)   didn't know Judy was in the Hospital........so sorry to hear.  I hope she is doing better and on the road to recovery.
snow.........oh, the word be deaf to thy ears.........we haven't seen it yet.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for all the positive comments and likes they are really appreciated.
I just got home from the Hospital, Judy is improving.
This morning i had a little time before heading into Edmonton to work on the skylight. I created a crude jig on a sheet of paper with a couple of blocks stuck down with some masking tape. This was to enable working on the light while temporarily attached with the glue.
When the lights were opened up one of the temporary glue joints let go so I started the hole drilling with the hinge that was still glued to ensure that the position of the light remained fixed relative to the ridge and central divider between the lights.
Because of the set up angle I was able to drill the holes for the rivets in the lights.
The rivets were pressed in and then glued with some thin Acc glue
After completing the lights on the first side I set it up to see how they looked......not good they did not sit down fully
This was one of those moments that had intuitively crossed my mind earlier when making the slots for the hinges in the top ridge. one of the thoughts was to set the hinges into the ridge the full depth of the folded hinge to eliminate the hassle of getting the notches perfect on the lights. It also allowed the lights to seat up fully well almost fully to the ridge.
The thing that I had completely failed to really understand was the minute amount of the rivet heads was enough to prevent the hinges from fully closing....what to do?  the hinges were set with pins and glued. I decided to deal with this later and made a change with the second side. The change involved setting up the lights so that the hinges could be mounted so that from the top when the light were closed thee looked clean, but that they would be slightly open underneath to allow for the heads.
The second side was drilled as the first side and the countersinks were made just a little larger then the hinges were unglued with a number 11 blade after marking their positions.
Then using the jewelers saw I cut them back at an angle from the topside to the bottom side.
then using the #11 I removed the slight wedge and cleaned it up with a needle file.
The next pic shows the one on the right has been modified and the one on the left is next to be done.
After fitting the first one and testing it to see if my fix would work I was satisfied that it would.
Then completed the second one, all that remains is to un-glue the well glued ones that I did first. the next pic shows the lights seated down fully on the second set.
Moral of the story... do a test first! but then you all knew that didn't you ;)
Michael
Glad to hear that Judy is improving Michael.
Fantastic work on the lights/hinges, but I'm glad you made a mistake - that's actually very encouraging for the rest of we lesser mortals! ;):)
Hello Michael, as a friend wrote to my log: "A man's invention comes from his previous errors". Your skylights looks superb.. :) A beautiful work Michael.
All the best
Dimitris
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
I am glad Judy is getting better and your solution to the skylight windows was ingenious.  With that redo you gave me hope to increase my skills in miniature joinery.
David B
Beautiful Butterfly Hatches Michael, They look Amazing, Superb workmanship
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
So very happy to hear that Judy is improving.  At times our minds see things work but then the unexpected crops up and we experience the "oh cr-p moment" ;)  Good recovery!  Hope the already cemented and pinned parts will come off unscathed.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
It all turned out beautiful in the end.
Oh yes and "measure twice, cut once"  and all the other hard earned lessons we all learned over the years. Still I tend to forget them very quickly and I don't know why. Maybe a shipwright is stubborn, luckily I'm very skilled at redo's ;-)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Glad to hear Judy is improving.  Skylights look great even with the OOPS moment.
Jack
Sorry to hear about Judy, but good to hear she's improving, give her my best wishes. Take care driving though!!!
I'm enjoying the build of that skylight tremendously!!! It does look stunning ... the nice thing about an 'end product', people can't see those oops moments, they just see that marvelous build ...
Carl
Great news about Judy
Remember that only the pope is supposed to be infallible and as far as I know the Vatican isn't in Canada, glad to know you're mortal
Thanks everyone for your well wishes for Judy. All is well now.
I have to hunt through my scraps of thin lexan for the "glass" in the skylights, I did have some 1/16th cell-cast acrylic that was left over from some architectural models. The interesting thing about cell-cast is because of the nature of the manufacture it is not super consistently even as far as thickness goes varying about 25 thousands over the sheet in random ways. we used to call it thick or thin whatever the main denomination was.
The reason I used the cell cast is because It cut much more cleanly without gumming or fracturing the way the extruded acrylic did.
So I need to find a bit of thin 1/16th failing that I will buy some new 1.5mm lexan
Michael
Hi Michael
Pleased to hear your good lady is on the mend and will be home for Christmas.
I'm don't know what lexon is but for for my windows I use a CD case.
I make the windows with a front and back which are identical then make a ply piece which will go between these two which is cut out slightly larger than the window apertures and left open at the top, this allows for the clear plastic to be slid down between the inner and outer sheet. One big advantage of this particularly on wheelhouses is that the whole thing can be painted or stained without getting it on the plastic, it also rules out having to glue them in and avoids the risk of fogging.
To both of you and anyone else who reads this Rosemary and I wish you all a very happy Christmas and a fantastic New Year..............Happy building and sailing in 2016.
Mike.
Laurence thank you for your kind words and the link.
Michael
Thanks Druxey, and thank you as well Mike for the tip about the CD cases, I shall have a look at that.
Michael
