HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Amazing!  Absolutely fantastic, making the model tell the story of how the men worked the ship is a lofty goal.  One that you are meeting.
Superb my friend,    have you been to Pompy  to see Victory?
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you Sirs :-)
@Frank: I found them on my cutting board underneath the scalpel ;-)
XXXDAn
Daniel,
your messenger-and anchor cable handling crew is a real tutorial for all who intend to rigg the anchor cables. Beautiful illustration work !
Looks like tere are always enough hands on a heavy ship like HMS Victory with training, dicipline, and a strong command
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Daniel,
Absolutely fascinating. I can see plenty of jobs there that risked trapped fingers and limbs.
BTW I am a great believer in understanding how things actually work when making models. In my view it leads to better modeling - which your fantastic models clearly show. :)
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
On the preserved Victory they do walk around tours, but nothing compared to this even if it is in minature, on the real thing it would take a very large cast of renactors to get across something like this,,,again Superb
OC
Current builds
Completed works.
super diorama you've set up there....very well done!  the figures look superb  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Last warning!
...tic-tac-tic-tac...
... be sure, the guided tour will continue :-)
XXXDAn
PS; Thank you all for the nice comments!
Edited by dafi
At the very beginning, I was desperately searching for crew. Still have the HÄT ones floating around some where ...
... but too big, too clumsy in form, too little and wrong positions ...
... then found the Preiser. First planed to make some and cast replicas - but first quite challenging casting in this scale and second, would have end up with a multitude of same positions.
Now I know that the change goes quite fast and I can give them custom postures - just whatever their duty needs :-)
Here some more pics from along the way. Last charge  were too clean and were too lollypop-like on deck so I had to filthy them up in situ. Here the latest press with before and after, but remember, the originals are a mere 18 mm, this means the eye is more lenient :-)
The last gentlemen is very serious about occupational safety - he got himself a jockstrap as the steel helmets to sit on were not invented yet ;-)
Also some gents with an immigrant background are finally to be spotted, something documented quite often.
XXXDAn
Edited by dafi
Your crew members are fantastic Daniel - very life-like. It's hard to remember, looking at the photos, just how tiny these actually are! Well done, Sir! :)
More amazing work, Daniel.  It will be interesting to see what you do with these lads.
Thank you Sirs, very appreciated!
@Mark:
As usual, I will make them work! The starter is already waiting to bite the last man!
XXXDAn
Edited by dafi
Holy cow, we forgot the gun powder ...
... hurry-up, hurry up, I can already hear the sound of the starter ...
... and the smell of the cat´o´nine tails ...
... but how do we now get this stupid ball out of the barrel?
XXXDAn
Sounds like Metallica - Master of Buckets
XXXDAn
"Take my hand ... we're off to Never-Never Land ... "
(Whoops !! Wrong album.)
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
The nice thing on a project like this is, that one can find so many small models that coincidentally gives a nice Vic.
One of those things are the gunport lids, haven´t yet tried the lower gunport lids with the scuttles :-)
First preparing parts and erasing the wooden grains and old fittings ...
... and think.
First doubling for extra thickness. Did not want to cut the hole before assembly for positioning reasons. So made a steel stamp and used it first to give a color mark on the appropriate place.
Used a 1 mm drill to give the depth and a scalpel for approx. shape and then used the stamp for the right form. Gives a nice and crisp edges and also flattens the bottom of the hole.
Then used my etch parts ...
... the parts can be positioned easily, the split line for the scuttle was cut with scalpel and needle ...
... and first color test.
Than tinkered the rings out of etch eyebolts and 0,2 mm copper thread ...
... and folded lovingly together by the help of two pliers.
Still showed the planking , mounted the rings and imitated the bolts from the fittings ...
... and done.
Edited by dafi
And then the assembly, taking measure by putting the lid on the barrel, marking the positions with a needle ...
... drilling and fitting test.
Still missing the lanyards . Took my drilled and streched sprue ...
... a template gives the right distances ...
... open the holes with drills step by step ...
... introduced the tubes ...
... still spliced the lanyards to the rings and introduced them into the tubes ...
... and with some luck ...
... one gets ...
... something like that.
XXXDAn
Some more petiteness:
The salt box for the cartridges ...
... used my etch monograms and pressed them with my vice into the wood to be more leveled, nice side effect is that they became less high :-)
Glued the fittings and afterwards some red paint - careful, explosive!
The buckets from Master of Buckets were wooden ones from the lath with brass eyelets and copper handles, for the small ones I wanted to try something else.
2 mm poly rod, drilled open and milled out ...
... and then shaped them with a conical device pressed into it.
Then cut and filled with PVC and we have a nice water bucket for the small boy, that is supposed to have a wet wipe up on all remains of powder on the floor.
Then I realised - too much space - pillars were missing ...
Tja und dann etwas bemerkt: Soo viel Platz war da gar nicht Mal, denn das dafi hatte in seiner großen Weitsicht noch nicht die Stützen platziert ...
... so I had to replace some of the stuff
Two more shots for the subject: red salt box for the cartridge, round transport case, wad, multi purpose water bucket and a barrel with slow burning matches in case the flint lock does not work, everything as far off the guns as possible.
In P. the wads are hanging in a netting in between the hammocks, I omitted that, as there was not enough space for that.
XXXDAn
Absolutely brilliant...
Just a query about the salt boxes and brass monograms. While I'm sure I've got more than enough thanks to your kit. Do you think that once embossed that the recess could be filled with fine powdered brass and CA? Or is the recess to small?
Love the workmanship and attention to details I can only wish for.
Ongoing builds,
SCutty Sark Revell 1/350 (Mini Nannie)
Cutty Sark Airfix 1/130 (Big Sis)
Will (Everard) Billings 1/65 but with wooden bottom, because I can
love it Daniel!.........wonderful imagination!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Happy birthday dear Vicci!
Today 250 years ago, dear little Vic was taken out of the dock :-)
I had the honor to prepare the laudatory speech for the german daily magazine Modellmarine.de
http://www.modellmarine.de/index.php?option=com_content&view=article&id=4236:07-mai-1765-250-geburtstag-der-hms-victory&catid=364:jahrestag
Please find here the google translation :-)
https://translate.googleusercontent.com/translate_c?depth=1&hl=de&ie=UTF8&prev=_t&rurl=translate.google.de&sl=de&tl=en&u=http://www.modellmarine.de/index.php%3Foption%3Dcom_content%26view%3Darticle%26id%3D4236:07-mai-1765-250-geburtstag-der-hms-victory%26catid%3D364:jahrestag&usg=ALkJrhiPT4Bvw0qW2hY2O1ROJDRrkda-DQ
Cheers and all the best for the future to our dear Vicci, Daniel
Edited by dafi
So, the public already took place ...
... and is wondering what to come ...
... and also my little seed of maggots looks like is ready to be harvested :-)
Ok, let´s clean the stage up :-)
XXXDAn
