Everything posted by dgbot
THE 74-GUN SHIP by Jeronimo
dgbot replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Your ports and sills look perfect and the straight edge you used was a stroke of genius. David B- 194 replies
That really looks good Nenad. David B
- 4,151 replies
- cutty sark
- tehnodidakta
Terrific paint job Nils. She is really looking like a grand lady. David B
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Moving along Dan. Treat that tool with the respect it deserves. More people are hurt using table saws than any other tool. When I was still workng two years ago an employe at our Des Moines plant cut off his fingers using one. I am not sure how it happened but when I used on I treated with great care and used push blocks for all the work. Nice David B
Second Planking
dgbot replied to Chuckaug's topic in Building, Framing, Planking and plating a ships hull and deck
Chuck, if you have a vice use that to hold the strip while you are shaping the plank. Take your time as the stuff supplied in most kits leave much to be desired. If you are lucky enough to have a Woodcraft nearby that would be great in that their veneers are top notch. David B -
1/10-scale Japanese Fishing Boat kit from Thermal Studios
dgbot replied to catopower's topic in Wood ship model kits
Sounds like you are in for an adventure in Ship modeling. Have a good time and keep the peanut gallery open please. David B -
I echo everyone else Bob, a lovey shape. Are you going to stain or paint her? David B
- 348 replies
- pequot
- cable ship
I pray that your loved one heals soon. Because of my problems I have a fracture in my lower back and understand pain pills. They come in handy when needed but I will not get behind a wheel or operate a machine when I take one. The biggest drawback is basically what you used to take for granted no longer works for you and you feel helpless. David B
Nice work Dave and am happy that you are doing okay. Question I like the look of hard maple but have never planked with it. How pliable is it or is it on the brittle side? David B
- 209 replies
- cheerful
- Syren Ship Model Company
I picked up a Sherline years ago and have added collets and a jewelers tool rest with it both are very useful. David B
Using modeling clay is a very good idea Peter thanks for the heads up. David B
- 92 replies
- Cutty Sark
- Billing Boats
Nothing wrong with furled sails. To make the bundle closer to scale just remove half the sail and furl it. Experiment and take a look at ships with their furled sails to get an idea for what you are going to do. David B
- 389 replies
- scottish maid
- artesania latina
Echo by Maury S - FINISHED - Cross-Section
dgbot replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Like Danny said to much deflection needing either steady or follower rest. Plus I use and independent 4 jaw chuck for the odd shapes I get into. It depends on what I am doing and the material and the thickness of the part. As the old saying goes there are many ways to skin a cat. David B- 324 replies
Use a plane or a knife and shave the corners into an octagon. Then smooth it out and start over again. Time consuming but you do not have to worry about the deviation in a lathe. I have also used a moto tool to round it out as well. David B
- 335 replies
- 18th century longboat
- Finished
Making a mast on a lathe can be frustrating. The easiest way is to use a plane and a fixture. You have better control and it is safer and more accurate. A self centering 4 jaw is defeating the purpose. I have an independent 4 jaw that is used for irregular shapes etc. David B- 324 replies
Looks good Patrick what about a red or white stripe along the hull to contrast with the black? David B
- 1,083 replies
My brother in law packed up all of my power tools so I have not seen my lathe for a long time. I used Turtle Wax after cleaning it with WD40. I do not have the strength at the moment to dig it out for a look see. At work we used 10w30 on the ways on the lathe there and that did the job. When I get the strength to open my case I will be looking at this wax. David B
