BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Beautiful work mate; the care and attention to detail and fitting is certainly paying dividends. cheers Pat
  2. Great result Vossie - so, don't leave us hanging What was the easier way hold them (to stuff the octopus also!) :)? cheers Pat
  3. Great adaption - thanks Keith. cheers Pat
  4. Thanks Keith; you are right it is probably an easy task and just FOMU from me I will give it a go soon. I have one more task to complete before taking a break (overseas holiday) soon and wish to try and finish these 'Rigmaiden' lanyards before I go. The problem I am currently having is bending the top strap through 90 degrees either side of centre (back on itself) such that the pre-etched holes all align and I retain a 'neat' loop at the top though which the wire rigging/shackles were attached. My efforts to date have been inconsistent as can be seen in the two photos of one strap I have tried to bend. I have tired bending the strap around a mandrel (pin in hardwood) then using a pin through the bottom two holes (one either leg) to keep the bottoms aligned, then pressing together with flat-nosed parallel pliers. I have also tried using another pin behind the mandrel to stop the strap moving away from the pin. The problem is that the two legs do not always come together exactly (out by .5mm - which is enough to stop the various pins I need to add from being inserted correctly. I have thought of trying to 'fix' one leg of the strap at a preset length such that the bend will always be at the centre point of the strap but the strap keeps slipping and it is difficult to bend the remaining length. Any ideas/suggestions most welcomed Please note none of these elements have been 'cleaned up' (filed etc) yet and the assembled strap is a crude prototype to show what I am trying to do. The chain plat as you can see has been slotted through the soldered eye. cheers Pat
  5. Thanks for sharing this technique GL; very useful and they look great. cheers Pat
  6. Very nice job on the portholes Keith; they came out very 'smooth' with not a sign of chipping I could see. cheers Pat
  7. Good to see you making sawdust (and boats :)) again Mark. A good outcome with the laser cut spiled planks; not easy to do with such small items but everything learned on this can be applied to the others. cheers Pat
  8. Hi Eberhard, some very sage advice as usual - many thanks. The idea of using the toolpost is one I had not thought of; I will stow that suggestion away for future use My mill head does rotate through 90 but I have never tried it with the fear I would need to realign things all over when reverting to the vertical. Call it FOMU (Fear Of Mucking Up) if you like When I did think of that option though, I was wondering how to mount the vise and keep the work at the right level (low enough) - and finding a slitting blade with a suitable diameter that would still clear the cross-slide. cheers Pat
  9. I can't provide any advice on the drilling as I do not have that level of experience in this area. You have far more experience and you are receiving some great advice from some talented and more experienced (than me) modellers - but I am learning a lot from this discussion. Thank you all. That said, I must declare that I like Dan's idea. Mate, I will stand in the trenches shoulder-to-shoulder with you in defence, should you decide to paint . As you can see from my models, I prefer to paint them as I try to recreate the look and feel of the 'real ship' as she may have looked (and this is my opinion only - everyone has their own ) . I say 'may have looked' as I am a long way off perfecting the 'scale colour' as it is called by more artistically experienced modellers - that is scale the colour tones etc to suit the model scale. There is enough wood remaining in the deck furniture to satisfy my 'love of natural wood' - but each to their own ideas on that. cheers Pat (standing by to receive any incoming )
  10. I have been pondering on what to call the rig also Druxey and had been leaning towards 'Steamer rig' as that is the type of vessel (both paddle and screw driven) it seems be exclusively fitted to. I do like the use of 'transitional' also and perhaps I will add that. I am working on a document at the moment (Word) that collated the research I have done to date and I will make it available via PM (for anyone one interested) or, via this thread, in the very near future for those whom may be interested to comment upon etc. At this point, the research is purely to provide the reasoning for the shaping and structure of the masts, and the rigging/sail plans (and eventually a belaying plan) as I have enough information to draw the masts now I think. I know it is a single stick upper mast (combining the top, topgallant and royal masts) to which I will apply the 'rules of thumb' proposed by Kipping and Fincham with a slight adaption to the head of the royal based on a comment by one of these authors. Once drawn in isolation I will overlay it to onto the lithographs and photograph of the ship and adjust to best fit. Hopefully I will be quite close. The next exercise is to determine the spar furniture and here I will run with the proposals of the same authors for the fittings specific to a steamer and adapted for merchant rather than RN (service) ships. Many thanks for your continued interest and suggestions; it is very much appreciated. cheers Pat
  11. I hope things improve very soon for you Rob. I can empathise with what you are going through and it isn't any fun at all. Get yourself well first mate; GR can wait (unless you leave that door Druxey found open ) cheers Pat
  12. Hi Ed and thanks for your feedback. I had tried inverting it, but I would need to redrill the existing, or get a new, Z-Axis bar to mount the tool to. But even then unfortunately the y-axis table will still strike against the base It was never designed to work in this configuration unfortunately. If I used it more often I would consider doing some modifications but I really only use it for template making and the like now (in a more basic set-up) as I use the Sherline for all my milling etc. I would have used the Sherline if I had a way to turn the work through 90 degrees as I have a slitting saw for that. cheers Pat
  13. Thanks mate. That is a very similar colour used by the RAN fore while and I also need to do some non-slip (Devron) walk areas on my little 'lugger' so will watch with interest. cheers Pat
  14. That serving on your lines for the buoy look great - very nice job. The serving is very tight and even. cheers Pat
  15. Looks a good solid base of colour Greg. What is the actual colour (and Brand) f paint you used for the decks? cheers Pat
  16. Nice progress Pat, the 'inserted' port lids look good. cheers Pat
  17. Great job on the bowsprit/jibboom Alan; they look very well proportioned. cheers Pat
  18. Very nice job on the telegraph and planking Keith. The bulwarks appear to be 'stiff/rigid' enough to be usable, and hold their shape in the photos, probably difficult to know until you remove her from the building frame? cheers Pat
  19. Hi folks, thanks for the interest in my little project. I am still in the learning stages and I am sure some of you more talented/experienced folks could suggest some improvements. Carl; that contraption is a modified "Vanda-lay Industries' milling tool. See http://vanda-layindustries.com/ Keith; thanks the jig works well, I just wish I could have got the cross-table closer to the work (shortened the extension of the holder). p.s. the reason the work is further away is that I had to flip the positioning of the dremel to the back of the tool rather than the front to get the blade rotation (approach to the workpiece) in the right direction so that it minimised the risk of bending/breaking the straps on contact (and there was not enough travel in the y-axis to have it at the front anyway ). Rob; it took a while to sort out the concept, but it was a bit of fun (and frustration) thinking it through. Michael; See link above re Vanda-lay Industry Tools. This was one of my first 'adventures' into tooling and worked fine for a while. However, as I mentioned earlier, I find the tool (as a milling machine - ACRA mill +) much to unstable (too much play in the Y-table especially). However, it is a great tool for other purposes. I asked for a modified plate (L shaped) adapter by which to fix the dremel holders to allow more positioning flexibility and he was happy to produce it for me. I use this with the dremel saw arbor / attachment for many tasks where I prefer to spin the cutter/grinder in a fixed position and offer up the work (making templates and the like especially) It is basically a part from the http://vanda-layindustries.com/html/hold-it_plus_jr_.html which is adapted to fit on the cross-arm of the Z-axis (see here http://vanda-layindustries.com/html/mill_accessories.html ) which I then asked for modified fixing plate rather than straight one that was being offered. I am not quite sure where I picked up the drill arbor/attachment; if I recall I will get back to you. I have no affiliation with the company, merely answering the queries cheers Pat
  20. Hi folks. Not much progress to report as I research the masts and rigging plan. In the meantime I am starting to assemble the 'Rigmaiden Lanyards' which were used in-lieu of deadeys and lanyards. See my earlier post here: I have had most of the brass strap parts photoetched after drawing them up to scale. However, I have had to solder a small ID thin walled tube to the ends of each of the chain plate straps to represent the eye. these were cut off flush to either side after being soldered. The Contract called for "Lang's Eye Plates" so I am assuming this different (to the usual chain plates) arrangement is what is meant but I am open to suggestions To help cut the slot in the eye to accept the bottom part of the Rigmaiden Lanyard, I milled a slot into the end of some brass square stock then made a sleeve to slide up and down to hold the 'plates'. the sleeve weas needed to stop the strap bending as they were half-etched at a few point to facilitate consistent and sharper bending points. This jig was then held in a vise which had been mounted into my Vandalay Milling table adapted to hold my Dremel in the horizontal. For this job, the table was 'adequate' but I would not recommend it for any precision work (simply to much play once the y-axis cross table is added. I think the photos show the principle. I had to use a longer extension of the jig to approach the saw blade due to the very small blade diameter and not being able to get the table to close the distance (obstructed) cheers Pat
  21. Couldn't you simply file it down in situ to a 'thinner' profile a, to me at least the 'diameter' or max OD of the nut is not too big? cheers Pat
  22. Thanks again Carl and Eberhard. Carl, Eberhard has answered re the sprues much better than I could have. The part I am trying to assemble is 5mm long, with 5 x diminishing 'U' shaped supports. The long spine is the prop guard and the supports are equally spaced. By diminishing I mean the central support is 3mm apart at the base where they join the hull, the outr only 1.25mm - so you can see how small these parts (2) are and my frustration in trying to make them. Thanks for the detailed explanation Eberhard; appreciate the better understanding. cheers Pat
  23. Thanks for the feedback Carl and Eberhard. Carl: I haven't tried it on this build as I have not had good results with it (may have been a bad batch?). That said, it may be worth relooking at - thanks. Eberhard: I have a hot air gun with variable settings (range similar to yours) with several nozzles. As above, I think I may have to relook at this. cheers Pat
