Everything posted by glbarlow
Great detail in the partners, and I just decided to paint Cheerful’s hatches black. Did you use Admiralty paint Flat Iron or Dull Black?
- 642 replies
- winchelsea
- Syren Ship Model Company
Fascinating as always. Are thos SM61 and SM62 blades? I’ve noted your using them before, do yo favor them over a good pair of wood working micro chisels?
- 261 replies
- muirneag
- vanguard models
2nd planking, tapering is important as is plank bending. Follow Chucks video you’ll be fine. Start at the top and work your way down about a third of the way. Then go to the bottom and do the bottom couple coming up 2-3 planks then go back up to the top and finish coming down. Why? Because if you’re not perfect and have to do some filling in you’ll be doing it in a place that can’t be seen once painted and mounted.
- 26 replies
- First Build
- lady nelson
Chuck has sheets cut especially for ripping planks. I learned to rip my own, it's quite rewarding. I don't think you're going to find sources in the US for any pre-ripped planks anymore and especially not Alaskan Cedar, I believe it's a bit of a Syren specialty. It's a topic that's been around for awhile, the US sources simply couldn't make a go of it. The Lumberyard is not a good source for wood despite the name in my experience. I ordered boxwood from there is was so bad I sent it back. There are some European sources for maple and a few other woods, but definitely not Alaskan Cedar.
This, as you’ll read in the log, is why I drill those holes at the very beginning of the build. The first time my model set on this board was when it was nothing but a keel, the second time when it was just a skeletal frame. The third time was for these photos. I don’t use glue, I epoxy the pedestals and the rod inside them to the base, then epoxy the ship to the rod and pedestals when the ship is ready for rigging. I also drill so the rods go past the keel into the frame, 25mm into the ship in Cheerful’s case. I will admit a certain tension drilling those holes, but it’s offset and much easier by being done early in the process. I wouldn’t want to be holding a completed model in my hand upside down doing it. I have 9 models sitting around my house, every one was mounted this same way. So far they are still tight to their boards, though admittedly I don’t sling them around to test their soundness. I also add a brass plaque to the board with the ship’s and my name along with the completion year, just in case I forget any of those three things😁.
- 778 replies
- cheerful
The pedestals and the mounting board (as unfinished walnut which I sanded and applied WOP) both came from modelexpo.com. They didn’t fit the width of Cheerful’s keel however. I had to spend some time with my Dremel to widen the slots. You can also see I used two different height pedestals with the way Cheerful lays out. Hope that helps.
- 778 replies
- cheerful
I don't think I could get through the fairing with tall the little steps before I fell off my chair. I'm looking forward to see your build to see how the hull comes out. It certainly is a different model
I’m always amazed by the small details you add, and the creative ways you come up with to add them. I knew I was saving all those old Pegasus parts for a reason.
- 261 replies
- muirneag
- vanguard models
My model has both those names depending on what day it is.😁
- 221 replies
- queen anne barge
Thank you. It may get another coat before I’m done. I’m glad I didn’t tree nail it and the WOP seeping between the seams does a nice job of distinguishing the planking runs. I came to like the little bit of variation in the wood color. The only thing Annapolis would want with it is target practice, but it’s a nice thought. 😁
- 778 replies
- cheerful
The poly does transform the cedar, I’ve lost track of how many coats it has at this point.
- 778 replies
- cheerful
Your turn to get Cheerful now😁
- 221 replies
- queen anne barge
Thanks guys! I thought I’d get my good camera and flash gear out for today, it does beat iPhone on the messy workbench photos for a change. I haven’t exercised my other hobby in a while.
- 778 replies
- cheerful
Thank you everyone. I really appreciate the kind words, comments and likes.
- 778 replies
- cheerful
After 5 months of work I’ve completed my Cheerful’s hull. I thought I’d pause a minute and share a few photos (sitting temporarily on its future base) before moving on to the deck. I’ve written in this log about the many things I’ve learned from this semi-scratch build, so many things I’d never done before. I have many more such challenges ahead, I’m looking forward to what's next. Thank you for all the likes, follows, and comments, I appreciate them all. The fun continues.
- 778 replies
- cheerful
I just ordered my own barge, had to hurry while it was still in stock.
- 221 replies
- queen anne barge
