@jfhealey
@CiscoH
@jose_b
Hello,
I'm always happy to receive praise for what you do. Thank you very much for that. But of course I would also like to thank everyone for the many LIKES.
Equipment of the fore topsail yard – fore topsail yard truss, fore topsail yard tye block, quarter blocks and blocks for buntlines, Jackstay/ Racage d'une vergue, poulie d'itague et poulies de cargue fond, filière d'envergure
According to my announcement, I am currently working on the equipment of the fore topsail yard. As already mentioned, this is done in the same way as the equipment for the main topsail yard, but in an adjusted size.
The following illustration is intended to show how the truss of the fore topsail truss is covered with leather and how the simple block strops are dressed. The tye block with the attached blocks for the buntlines (L=3.5 mm) is also shown, as is also the enlarged image in the next photo.
The tye block (L = 7 mm) was temporarily attached to the fore topsail yard using rose lashing and the yard truss was temporarily lashed in place.
And as you can see in the last picture, I have already made and attached the jackstays. Only the rope in the thimbles still needs to be pulled in, which of course only makes sense after the double blocks for the clewlines and sheets have been secured.
But more about that soon…
Edited by archjofo
@Vladimir_Wairoa
Hi,
thank you very much for your kind words.
Continuation: Equipment of the Fore topsail yard – quarter blocks / Poulies d'ecoute et Poulies de cargue point
As with the fore topsail yard, the clew lines and sheets each run over a double block, also known as a quarter block.
Here too, I attached these double blocks using rose lashing.
As I pointed out some time ago, I made a suitable tool that makes creating a rose lashing easier.
I saw this and copied it from our model builder colleague. I don't want to adorn myself with other people's feathers here...
Fastening the quarter blocks was followed by pulling in the rope at the jackstay, which was attached to a thimble using a simple eye splice, as can be seen in the following picture.
And last but not least, the result of this work section.
Sequel follows …
Edited by archjofo
Johann, marvelous and fantastic work as usual. I’ve been following this build for years. One question I have is with your rigging or in this case the lashings pulling the Jack stays together, how do you tie off the bitter end (loose end).  I see you eye spliced one end to the thimble with a simple eye spliced, but the other end after passing through the thimbles how do you secure the other end.  Same with many of your other rope work. It is so clean and I never see the other end of the rope how it is finished. Thank you and your build would make an incredible practicum as a book.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
@Dowmer
Hi,
I haven't yet done the lashing of the jackstays in the middle of the fore topsail yard. But I'll show you the detail at the main yard.
As you can see, the end of the rope is wrapped around the lashing ring for a few turns and then secured.
There are also various methods for this, such as this one:
I hope that I have helped with this.
Hello,
wish everyone here in the forum a Screenshot2023-12-20103133.jpg.245b7016206787464263bdc22440a980.jpg.
Completion: Equipping the fore topsail yard - footropes and stirrups / Marchepieds et étriers etc.
By pulling in and tensioning the lanyard, the two halves of the jackstay were tensioned. The loose end of the ropge was carefully wrapped around the lanyard and tightened, as shown in various historical drawings.
The footropes and stirrups for this yard were then made in the same way as for the main topsail yard, but with slightly reduced rope diameters.
The following picture shows the already prepared stirrups. Thimbles are spliced into one end of them, through which the rope of the footrope will later be pulled. The other ends were formed with served eye splices, which are then lashed to the jackstay.
The next picture shows the finished footropes with details.
I continued with the lower blocks for clewlines l = 3.5 mm and the toggles to connect them to the topgallant sheets. As already mentioned, I made these from dogwood, a very hard and fine-grained wood, which is ideal for these small parts.
The following picture shows the stropped blocks for the clewlines, one is connected to a sheet. Next to it is a block for the main braces for comparison.
Here you can see the stropped blocks for the braces before they are placed on the yardarms.
Here you can see how the studding sail booms are attached.
The next pictures show the fore topsail yard equipped with the necessary elements for rigging.
Last but not least, a picture of the yards fitted out so far.
Quite a jumble... 😊
We continue with the cross yard.
To be continued ...
Edited by archjofo
A few quiet minutes between the holidays can be usefully filled...😀
Equipment of the mizzen topsail yard – Vergue de perroquet de fouge
In the meantime I have started equipping the mizzen topsail yard of the La Créole. The first step was to make the necessary blocks and thimbles, as shown in the first picture.
The tye block has a length of 5 mm and is therefore the largest block at the mizzen topsail yard.
The next picture shows the size ratio of the tye block of the mizzen topsail yard to the tye block of the mizzen topsail yard. The difference is clear, as the mizzen topsail yard itself is significantly smaller and therefore lighter.
In the last picture the first rigging elements are already attached, such as the tye block with the stropped blocks for the bunt lines, the truss and the quarter blocks.
I cannot tell from the images available to me to what extent the mizzen topsail yard was equipped with a jackstay. I can't find any information about this in the monograph either. Nevertheless, I tend to equip the mizzen topsail yard with a jackstay.
Up soon …
Wish you all a happy new year!
@giampieroricci
@Nunnehi (Don)
Thank you very much for your interest in my work and the kind words.
I would also like to thank you all for the many LIKES.
A happy new year 2024 to all.
Continuation: Equipping the mizzen topsail yard - Vergue de perroquet de fouge
The last of La Créole's topsail yards, the mizzen topsail yard, has now also been fitted with a jackstay and lashed in the middle.
The next step was to make and attach the footropes with a rope ø 22 mm (model scale ø 0.46 mm). Due to the relatively short spans, one stirrup for each half of the mizzen topsail yard seemed sufficient.
The next step was to make the strops for the yard tackles, which will later be attached to the yardarms.
The next picture shows detailed sections of the rigging elements already mentioned. A comparison with a stirrup for the main yard is also shown.
The following picture shows the finished blocks (each 3.5 mm long) for the braces and the leech lines. As with the other yards, the blocks were attached directly to the yard strops using ø 1.4 mm thimbles ("dog and bitch" connection).
I continued with the strops for the lower blocks of the clew lines (l = 3.5 mm) and making the toggles to connect them to the sheets.
Last but not least, a picture of the current state of the mizzen topsail yard.
Finally, the clew lines, the reef tackles and the sheets are still missing for the final outfitting of the mizzen topsail yard.
See you soon ...
@matiz
@jfhealey
Hello,
many thanks for the nice comments, and also thanks for the LIKES.
Actually, the equipment elements of the individual yards are more or less repeated again and again, except that the further up you go in the rigging, the smaller the dimensions.
So I could deal with this chapter in a condensed form.
But if you know me, you know that I'm merciless until the last yards ... 😁
Completion: Equipping the mizzen topsail yard - Vergue de perroquet de fouge
The clew lines with the corresponding blocks, the sheet and the lifts were added to the final equipment of the mizzen topsail yard.
See the following pictures:
DSC01741.thumb.jpg.66ff52a053ff3217cc20f8a4ab074451.jpgDSC01744.thumb.jpg.ef78c33a01932fb4ef6c9f6c9678e5b2.jpgDSC01747.thumb.jpg.11492a9d7d4578078541b7da84169296.jpg
I'm still not quite sure whether the reef tackles should be simple and with a hook or with a block. I still need to do some research on this. Regardless of this, this yard will now be put to one side with the already equipped yards and work will begin on equipping the topgallant yards.
To be continued ...
Edited by archjofo
Equipment of the topgallant yards– Itague de vergue de grand perroquet
In the meantime I'm working on equipping the topgallant yards.
I'm slowly starting to get the feeling that the higher I get in the rigging, the less information there is about the details; be it from the monograph or from the relevant specialist literature. There is obviously less to be found on the internet. Apparently it is due to the importance or meaning of the components, as a large yard literally has more weight.
Or to put it somewhat jokingly, the higher the air, the thinner the air..., of course, meant the information density... 😊
So I brought together information about the execution of the truss from a wide variety of sources, as can be seen in the following pictures.
Accordingly, from my point of view, I was able to clarify the execution of the tye with the double strop for the top gallant. I think that this detail can also be used analogously for the royals.
Source: Detailed photo detail of the original model Musée national de la Marine – edited / Atlas du Génie Maritime – edited
The implementation for the main topgallant yard of the model then looks like this, as shown. The “mousing” as a hook lock is only attached when the yard is finally equipped.
We then continued with the truss. This was made like the truss for the topsail yards with leather coating.
The following drawing by K. H. Marquardt, but served.
Source: Karl Heinz Marquardt, Masting and Rigging of 18th Century Ships
In the last two pictures you can see the tye and the truss for the main topgallant yard,  which will only be finally lashed to the topgallant mast of the model later.
In the next step I will work on making the quarter blocks as double blocks with a length of 3.0 mm for the topgallant yards, which are used to guide the royal sheets and clew lines.
So, see you soon….
Continuation: Equipment of the main topgallant yard – Vergue de grand perroquet
The next step was the production of the quarter blocks. In the first picture you can see the quarter blocks with a length of 3.0 mm that have already been provided with strops. At the top left of this picture I show these double blocks compared to a guide block that is used on the deck to redirect the topsail sheets.
Here the assembly of the quarter blocks is nearing completion.
Before I started making the footropes for the main topgallant yards, I tried to fundamentally clarify the execution details for the topgallant yards.
In this context, I found what I was looking for in the contemporary specialist literature “Manuel de Greement” by F. A. Coste from 1829 on pages 120/121. Accordingly, the footropes of the top gallantyards of the yardarms each extended slightly beyond the center of the yard, where they were then attached. These footropes could not be tensioned with lanyards like those of the lower yards and topsail yards.
Since the brams of the La Créole did not yet have a jackstays, unlike the lower yards and topsail yards, the stirrups were designed and attached in the conventional manner. This means that the ropes of the stirrups were braided and looped around the yard with two to three turns. The ends of the braids, also known as plating (in German, I don't know the English name), were fastened with flat-headed nails with leather washers.
As F. A. Coste describes, the number of stirrups in the topgallant yards must be chosen depending on the yard length. For a corvette like the La Créole, one stirrup per half of the yard should be sufficient.
To make the stirrups, I was able to find the following in the specialist book “The Ashley Books of Knots” by C. W. Ashley:
Of course I had the ambition to implement this detail for my Corvette too. After tying in the thimble, the braid was made after unraveling the rope of the stirrup. This is how the meaning of the braid became clear to me. Since these were no longer round but flat, they could be wrapped very well and tightly around the yard and securely nailed down.
Since I still had a main topgallant yard as scrap from making the yards, I was able to try out attaching the braids to it. The result can be seen in the next picture.
I think that's how I'll ultimately implement it at the topgallant yards.
Sequel follows …
Edited by archjofo
Dear Johann,
I've been following this masterpiece in religious silence for a long time, but now, for what is worth from a novice like me, I feel the need to compliments with you on this marvelous work of art. It's really a joy to watch and a great inspiration.
Thank you for sharing your journey with us.
Current build: Cutty Sark - Revell - 1:96:   https://modelshipworld.com/topic/25323-cutty-sark-by-bruma-revell-196/
Fantastic work!
The English word you were looking for may have been plaiting, which according to my brief research is simply the British version of the American word for braiding.
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
@druxey
@Bruma
@jdbondy
@shipman
@giampieroricci
Hello friends,
thank you very much for your interest in my build report and for the kind words.
Also many thanks to all of you for the many LIKES.
Continuation: Equipping the main topgallant yard - Vergue de grand perroquet
Once I had clarified the details for the footropes with the stirrups, it was time for the implementation. Thanks to the corresponding preliminary work on a test piece, the stirrups were attached to the yard quickly and without any problems.
Before the eye splices of the footropes could be pulled over the yardarms, the prepared grommets were first put on as chafe protection.
When attaching the footropes in the center of the yard, I used the following example as a guide.
Freiherr_Sterneck_Takelung_und_Ankerkunde_Fupferd_Befestiguhng.jpg.9a194361b0a8ba7047969cbfc60395cb.jpg
Source: Freiherr v. Sterneck, "Takelung und Ankerkunde", 1873
This is what the realization for the model looks like:
I have now also made the mousing to secure the hook for the tye:
The simple buntlines were guided in thimbles at the topgallant yards of the French corvette. These buntlines branched out in the lower area onto two ropes, which were attached to the leeches of the sail. I therefore attached a thimble directly to the tye, as seen on the original Parisian model.
The clewlines for the topgallant sails were normally connected to the clews by means of toggles. Without sails, the clewlines are connected directly to the topgallant sheets.
The single-guided lifts, the braces attached directly with eye splices and the aforementioned sheets complete the equipment of the main topgallant yard. These ropes have a diameter of ø 0.25 mm and served eye splices for laying on the yardarms.
The last two pictures give an overview of the main topgallant yard with all equipment elements and ropes.
I will continue with the fore topgallant yard.
More about that soon ...
Edited by archjofo
Will the yards be getting jack-stays? (d)
I just wonder should the jack-stay eyes be turned that way, or are they just drawn so we can see that they are eyes?
Edited by JerryTodd
Jerry Todd
Click to go to that build log
Hello Jerry,
as explained earlier in my report, the topgallant yards and the royals of my model do not receive any jackstays. In the first years of jackstay use at the beginning of the 19th century, only the lower yards and topsail yards were equipped with jackstays. It was only in later years, around the middle of the 19th century, that jackstays were also used in the upper yards.
I think the illustrator only turned the jackstay eyes a little so that they could be recognized as such.
@albert
Thanks for your interest and the nice comment.
@giampieroricci
Hello,
This illustration is from the book “Takelung und Ankerkunde” by Freiherr v. Sterneck, published in 1873.
Can be downloaded as a PDF from Google Books. This is not quite the time of my corvette, but in conjunction with descriptions from contemporary French specialist literature, these depictions are often a good starting point.
